Arduino Forum
Using Arduino => LEDs and Multiplexing => Topic started by: baselsw on Jul 30, 2012, 02:21 am
Title: Tutorial/Tips: 8x8 LED Matrix + Attiny2313 using Mega ADK
Post by: baselsw on Jul 30, 2012, 02:21 am
Hey everyone!
This is my first topic and post and I hope that some of you find it useful! Well I've learned a lot from this forum and thought it was time to give something back! =)..
My first problem that I kinda bumped in was that I wanted to use my Mega ADK R3 to program a ATtiny2313 with the help of the ArduinoISP sketch. I got a lot of problems with the communication between the ATtiny2313 and the Mega ADK. I disabled the auto-reset feature with the help of a 10uF capacitor but still got the "sync" error and the Device signature error. And all the information that I found was kinda related to the arduino UNO or Duemilanove, nothing useful about the MEGA or MEGA ADK. What I discovered is that the avrdude that comes with Arduino IDE 1.0.1 misses some config files. So what I did is I downloaded and installed WinAVR from http://sourceforge.net/projects/winavr/files/ (http://sourceforge.net/projects/winavr/files/). After that I connected the arduino mega as the following schematic and typed the following in cmd.exe.
avrdude -c stk500v1 -P com9 -p t2313 -b 19200 -v -v
Note that the arduino mega contains an unmodified version of the ArduinoISP sketch.
(http://img821.imageshack.us/img821/9448/megaprogrammerbb.png)
Avrdude was able to communicate with the ATtiny2313 and it gave me the right device signature.
After that was done I reopened Arduino IDE 1.0.1 and successfully burned the "bootloader"/fuses for ATtiny2313 8MHz internal oscillator with "arduino-tiny" installed.
I wanted my ATtiny2313 to display a message on the LED matrix but bumped in the lacking SRAM volume.So what I did is modify my sketch to put all of my large arrays in the flash memory using the PROGMEM library. After successfully uploading the sketch to ATtiny2313, I connected the LED Matrix and power supply as the following schematic.
(http://img443.imageshack.us/img443/2808/connectionsdispbb.png)
And here is the arduino sketch:
LEDMATTINY_DISP by Baselsw 2012. This code uses a ATtiny2313 to directly drive a 8x8 LED matrix.
Please use this code as you wish!! =D Enjoy!
#include <avr/pgmspace.h>
const int row[8]={ //Row pins
  9,14,7,12,0,6,1,4};
const int col[8]={ //Column pins
  13,2,3,10,5,11,15,16};
PROGMEM const byte font8x8[28][8] = { //Font matrix
    0x80, 0x60, 0x18, 0x14, 0x13, 0x3C, 0xC0, 0x00      }
  ,  // Code for char A 0
    0x00, 0xFF, 0x91, 0x91, 0x99, 0x66, 0x00, 0x00      }
  ,  // Code for char B 1
    0x78, 0x84, 0x82, 0x81, 0x81, 0x43, 0x00, 0x00      }
  ,  // Code for char C 2
    0x00, 0xFF, 0x81, 0x82, 0x82, 0x44, 0x38, 0x00      }
  ,  // Code for char D 3
    0x00, 0xFF, 0x89, 0x89, 0x89, 0x89, 0x00, 0x00      }
  ,  // Code for char E 4
    0x00, 0xFF, 0x09, 0x09, 0x09, 0x01, 0x00, 0x00      }
  ,  // Code for char F 5
    0x78, 0x84, 0x92, 0x91, 0x91, 0x51, 0x32, 0x00      }
  ,  // Code for char G 6
    0x00, 0xFF, 0x08, 0x08, 0x08, 0x08, 0xFF, 0x00      }
  ,  // Code for char H 7
    0x81, 0x81, 0xFF, 0x81, 0x81, 0x00, 0x00, 0x00      }
  ,  // Code for char I 8
    0x60, 0x80, 0x81, 0x81, 0xFF, 0x01, 0x01, 0x00      }
  ,  // Code for char J 9
    0x00, 0xFF, 0x18, 0x24, 0x42, 0x81, 0x00, 0x00      }
  ,  // Code for char K 10
    0x00, 0xFF, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00      }
  ,  // Code for char L 11
    0xC0, 0x38, 0x07, 0x38, 0xC0, 0x38, 0x07, 0xF8      }
  ,  // Code for char M 12
    0x00, 0xFF, 0x02, 0x0C, 0x10, 0x20, 0x40, 0xFF      }
  ,  // Code for char N 13
    0x00, 0x7C, 0x82, 0x81, 0x81, 0x81, 0x41, 0x3E      }
  ,  // Code for char O 14
    0x00, 0xFF, 0x21, 0x21, 0x1E, 0x00, 0x00, 0x00      }
  ,  // Code for char P 15
    0x00, 0x3C, 0x42, 0x81, 0xA1, 0x41, 0x81, 0x7E      }
  ,  // Code for char Q 16
    0x00, 0xFF, 0x11, 0x31, 0x4E, 0x80, 0x00, 0x00      }
  ,  // Code for char R 17
    0x00, 0x40, 0x86, 0x89, 0x89, 0x89, 0x71, 0x00      }
  ,  // Code for char S 18
    0x01, 0x01, 0x01, 0xFF, 0x01, 0x01, 0x01, 0x00      }
  ,  // Code for char T 19
    0x00, 0x7F, 0x80, 0x80, 0x80, 0x80, 0x7F, 0x00      }
  ,  // Code for char U 20
    0x00, 0x07, 0x78, 0x80, 0x78, 0x07, 0x00, 0x00      }
  ,  // Code for char V 21
    0xFF, 0xE0, 0x30, 0x18, 0x18, 0x70, 0xC0, 0xFF      }
  ,  // Code for char W 22
    0x81, 0x42, 0x24, 0x18, 0x24, 0x42, 0x81, 0x00      }
  ,  // Code for char X 23
    0x01, 0x06, 0xD8, 0x30, 0x0E, 0x01, 0x00, 0x00      }
  ,  // Code for char Y 24
    0xC1, 0xA1, 0x91, 0x89, 0x85, 0x83, 0x81, 0x00      }
  ,   // Code for char Z 25
    0x0E, 0x1F, 0x7F, 0xFE, 0xFE, 0x7F, 0x1F, 0x0E     }
  , // Code for HEART 26
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00    } // Code for SPACE 27
  for(int i=0;i<8;i++){
    pinMode(row[i], OUTPUT);    //Set row pins as output
    pinMode(col[i],OUTPUT);     //Set column pins as output
    digitalWrite(row[i], LOW);   // turn off rows
    digitalWrite(col[i], HIGH);   // turn off columns
void display_char(int character ){
  for (int i=0;i<8;i++){ //Cycle through columns
    byte coldata = pgm_read_byte(&font8x8[character][i]); //read column data from PROGMEM
    digitalWrite(col[i],LOW); //Allow current flow in the i'th column
    for(int j=0;j<8;j++){ //cycle through row data
      int x = bitRead(coldata,j); //Read the first bit from the byte (coldata)
      digitalWrite(row[j],x);     // Set the row to 1 or 0
    delayMicroseconds(300);  //Delay for 300us between each segment/column. Don't go bellow 300us!!
    clearOutput(); //turn off display
void clearOutput(){
    digitalWrite(row[i],LOW); //Turn off rows
    digitalWrite(col[i],HIGH); //Turn off columns
  byte msg[]={8,27,26,27,20,27,9,0,2,10,11,8,13,4}; //Message to be displayed. Numbers corresponds to the position of each letter in the font matrix.
                                                    // In this case the message would be "I 'HEART' U JACKLINE"
for(int i = 0;i<14;i++){ // For each character in msg (total of 14 characters)
    int count=0;
  while(count<250){
    display_char(msg[i]); //Show the same letter 250 times ~ 250*8*300us = 0.6s for each letter.
    count++;
  delayMicroseconds(100); //Delay between each character for stability
And that's it!! I know this was kinda brief but I didn't want to go into a lot of details. If you got any questions I'll be more than happy to answer them!!
This is my finished product ;)!!
(http://img580.imageshack.us/img580/6498/61620810151971703290511.jpg)
//Basel
