Arduino Uno with a 32-bit ARM Cortex-M0, LPC111X NXP microcontroller in 28 pin DIL package instead of Atmega328p
The nice thing about Arduino Uno is that not only it introduces you quickly in the world of 8 bit AVRs (Atmega328p) but after running a few programs, mostly already available examples, you quickly realize you can develop you own boards using stand alone Atmega328ps chips and you no longer need the Arduino Uno, excepting as an ordinary ISP programmer.
Arduino Due is not the same affair. Migrating from it to a stand alone SMD ARM with many pins, like the one installed on Due, is not an easy endeavor. You need serious skills in crafting PCBs to have your own ARM powered controller board, all this because of the hobbyist unfriendly chip package.
However, there is, at least in theory, a 32-bit ARM Cortex-M0, LPC111X NXP microcontroller in 28 pin DIL capsule that is as easy to use as an Atmega328p.
See: http://www.nxp.com/documents/data_sheet/LPC111X.pdf
If it is worth replacing the Atmega328p on Uno with an LPC111X it remains to be seen. There will be a gain in speed, for sure, at least for code requiring many multiplications of 16 bit values integers that can come from the DAC.
What other advantages, disadvantages such a Uno with LPC111X could have?
Do you know if that is a 'skinny' (.3") or 'fat' (.6") 28 pin DIP package?
Lefty
Unfortunately, it is a fat DIL (page 92 in the datasheet).
Yes, too bad. But still a yea for being a DIP!
I have searched for LPC1114FN28/102 DIP (http://www.digikey.ca/scripts/dksearch/dksus.dll?FV=fff40027%2Cfff800cd&k=+LPC1100&vendor=0&mnonly=0&newproducts=0&ptm=0&fid=0&quantity=0&PV16=6533&PV16=13036) but Digikey does not have it in stock. However, it can be found at Mouser (http://ca.mouser.com/Search/Refine.aspx?Keyword=LPC1114FN28%2f102%2c12&FS=True).
It means that LPC1114FN28/102 DIP has gained some market.
One can only imaging why it's a fat DIP in this day and age, .3" DIPs have been out for decades.
Still, kudos for having a DIP at all.
BTW, there's another one now (or at least next year)
http://arduino.cc/forum/index.php?topic=132494.new;topicseen#new (http://arduino.cc/forum/index.php?topic=132494.new;topicseen#new)
______
Rob
It is hard to imagine a modern production run with dip devices.
Personally I never use DIPs these days, but people still like them for prototyping.
______
Rob
There's a lot of people (including me :smiley-sweat: ) that "play" with Arduino and MCUs for hobby at a very early stage, that: are not able to do a home-made PCB; can not solder SMD cases. So DIPs are fantastics because you can use them with breadboards or classic stripboards easily ;)
Somebody has already tried LPC1114FN28/102 DIP28 on a breadboard with a "blink a led" test code.
See: http://www.meatandnetworking.com/tutorials/lpc1114fn28-with-open-source-tools/ for all details.
(http://www.meatandnetworking.com/wp-content/uploads/lpc1114breadboard-300x123.png)
The test just says that this ARM is relatively easy to use by hobbyists. However, it does not prove anything about the performance of LPC1114FN28/102 as compared with an Atmega328p, for example. If it is not 10 times faster, likely AVR funs will not abandon so easily their favorite microcontroller for it.
It wouldn't be even remotely close to being 10x faster.
You use those chips not for speed, or costs, but for lower software costs, a non-factor for the hobbyist markets.
nxp just announced a CM0 chip in 8pdip.
how do you figure? It could easily be 10x faster for SOME purposes.
Say: 32bit integer math. A 32bit add on AVR takes at least 4 instructions at 16MHz, or 250ns. a 32bit add on an LPC1114 takes 1 instruction at 50MHz, or 20ns. More than 10x faster.
Of course, your program will never be all 32bit math, but...
That kind of comparison makes sense if all you do with your mcu is to add 32-bit numbers.
Even in that comparison, what if you wanted to process char or short?
More importantly, for those of us using those chips for a variety of different tasks, you would be hard-pressed to show the cmx chips are 10x faster than a comparable avr (or any other 8-bit mcu).
There is a comparison between ARM Cortex M0 and other controllers including AVR.
see: http://ics.nxp.com/literature/presentations/microcontrollers/pdf/cortex.m0.code.density.pdf
especially pages 41, 42, 43.
Oh, I'll accept "not 10x faster", but I think "not remotely close to 10x faster" is too harsh. I see "almost always faster, and 12x faster for some pretty common operations. "
I think I could come up with non-contrived code that would be significantly more than 12x faster (say by using an array of 32bit constants in flash.)
Of course I'm also in the group that believes an AVR is "fast enough" almost all of the time.
The peripherals are much slower than the mcu: it takes the same time to do 400khz i2c on a 72Mhz CM3 as it does on a 1Mhz avr. Or it takes the same amount of time to wait for a person to press a button, etc.
So the raw speed comparison on a mcu really isn't that meaningful.
I would venture a guess that the CMx chips are no more faster than an avr than their system clocks suggest.
Obviously, that conclusion changes if you are using those chips for some 32-bit intensive tasks (fft for example, or dsp on the cm4s).
Also the ADC for LPC1114FN28/102 is at least 5 times faster than the one on Atmega328p, (for the ARM I am not seeing the maximum conversion time at full resolution which is needed for a more precise comparison).
ARM
The LPC1110/11/12/13/14/15 contain one ADC. It is a single 10-bit successive
approximation ADC with eight channels.
• Measurement range 0 V to VDD.
• 10-bit conversion time >= 2.44 us (up to 400 kSamples/s).
AVR
ATmega48PA/88PA/168PA/328P
Analog-to-Digital Converter
• 10-bit Resolution
• 13 - 260 ?s Conversion Time
• Up to 76.9 kSPS (Up to 15 kSPS at Maximum Resolution)
The voltage range of the Arm is 'Single power supply (1.8 V to 3.6 V)."
A 328 can run up "- 0 - 4MHz@1.8 - 5.5V, 0 - 10MHz@2.7 - 5.5.V, 0 - 20MHz @ 4.5 - 5.5V"
I wonder if the fact an ADC could be required to charge up to the higher VDD on the 328, if that is responsible for some of the time difference?
I haven't looked into the ARMs directly, but the ADC sampling time is usually related to the size of
the sampling cap on the front-end of the ADC, as well as the the value of the external source
resistance.
Slower ADCs usually have a sampling cap in the 20-120 pF range, while for the fast ones it's more
like 4 pF. Also, the faster ones will say something like "source impedance must be 500 ohms max
for maximum sampling rate", while the slower ADCs will say something like 10K max. So, max
sampling rate mainly comes down to RC charging.
Thank you for the explanation!
Mouser had 3907 chips LPC1114FN28/102 DIP on 15 Nov. 2012. Now, 4 days later they have 3899 in stock.
This microcontroller does not seem to have many clients.
It's an interesting chip, but the wide package and "only" 32k of flash make it less than compelling. A PIC32MX150F128 in narrow 28-dip with 128k of flash is more interesting, even if it's $2 more.
Sigh. It's really clear that NXP is serious about trying to displace 8bit CPUs. I wish they were more obviously "on target" with their attempts. 16pin micoBGAs, 28pin wide DIPs, ... nice tries, but not quite what I was hoping for. I can't quite tell whether they're clueless, or whether it really IS that hard to figure out what is really wanted in this nebulous "hobbyist/small manufacturer/mindshare" market space.
It is quite possible that nxp has studied the market and come to the conclusion that this super-duper red-hot "hobbyist" niche is not where they can make sufficient profit to float their boat. Instead, they want to focus instead on this much larger non-sexy industrial applications market for this chip.
Just try to a get a board with through-hole-parts made today and you will understand.
It is probably true that large customer orders don't show up on their web inventory.
I have not studied it too much but the LPC Xpresso IDE, designed for ARMs produced by NXP, seems quite easy to work with.
The IDE hides the internal registers and you work mainly with easy to understand functions that set timers, IO ports, etc..
However, there may be traps, complications. LPC Xpresso IDE does not have a simulator, for instance, like Keil. You need the real hardware to test your code.
LPC Xpresso code example:
* $Id:: PWM16_32test.c 3635 2010-06-02 00:31:46Z usb00423 $
* Project: NXP LPC11xx 16-bit/32-bit PWM example
* Description:
* This file contains PWM test modules, main entry, to test PWM APIs.
* Software that is described herein is for illustrative purposes only
* which provides customers with programming information regarding the
* products. This software is supplied "AS IS" without any warranties.
* NXP Semiconductors assumes no responsibility or liability for the
* use of the software, conveys no license or title under any patent,
* copyright, or mask work right to the product. NXP Semiconductors
* reserves the right to make changes in the software without
* notification. NXP Semiconductors also make no representation or
* warranty that such application will be suitable for the specified
* use without further testing or modification.
#include "driver_config.h"
#include "target_config.h"
#include "timer32.h"
#include "timer16.h"
#include "gpio.h"
extern volatile uint32_t timer32_0_counter;
volatile uint32_t period = 1000; //48Khz PWM frequency
/* Main Program */
int main (void) {
/* Initialize 32-bits timer 0 */
init_timer32(0, TIME_INTERVAL);
enable_timer32(0);
/* Initialize the PWM in timer32_1 enabling match0 output */
init_timer32PWM(1, period, MATCH0);
setMatch_timer32PWM (1, 0, period/4);
enable_timer32(1);
/* Initialize the PWM in timer16_1 enabling match1 output */
init_timer16PWM(1, period, MATCH1, 0);
setMatch_timer16PWM (1, 1, period/8);
enable_timer16(1);
/* Enable AHB clock to the GPIO domain. */
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<6);
/* Set port 2_0 to output */
GPIOSetDir( 2, 0, 1 );
while (1) /* Loop forever */
/* I/O configuration and LED setting pending. */
if ( (timer32_0_counter > 0) && (timer32_0_counter <= 50) )
GPIOSetValue( 2, 0, 0 );
if ( (timer32_0_counter > 50) && (timer32_0_counter <= 100) )
GPIOSetValue( 2, 0, 1 );
while ( timer32_0_counter < 100 ); //wait for
timer32_0_counter = 0;
A nice feature I like is that LPC Xpresso displays explanations about a function, ex. init_timer32 (the meaning of parameters, etc.) if you glide the mouse cursor over its name.
The ide does not hide anything: you can always code the mcu by writing to the registers.
However, in this case, they use a set of libraries from nxp to operate the peripherals. That's not unusual: ST has a set of its own libraries.
Without those libraries working with ARM peripherals is really not practical.
If indeed one have to write all these lines of code to initialize a timer I imagine that not many people would dare to attack ARMs.
** Function name: init_timer
** Descriptions: Initialize timer, set timer interval, reset timer,
** install timer interrupt handler
** parameters: timer number and timer interval
** Returned value: None
void init_timer32(uint8_t timer_num, uint32_t TimerInterval)
if ( timer_num == 0 )
/* Some of the I/O pins need to be carefully planned if
you use below module because JTAG and TIMER CAP/MAT pins are muxed. */
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<9);
LPC_IOCON->PIO1_5 &= ~0x07; /* Timer0_32 I/O config */
LPC_IOCON->PIO1_5 |= 0x02; /* Timer0_32 CAP0 */
LPC_IOCON->PIO1_6 &= ~0x07;
LPC_IOCON->PIO1_6 |= 0x02; /* Timer0_32 MAT0 */
LPC_IOCON->PIO1_7 &= ~0x07;
LPC_IOCON->PIO1_7 |= 0x02; /* Timer0_32 MAT1 */
LPC_IOCON->PIO0_1 &= ~0x07;
LPC_IOCON->PIO0_1 |= 0x02; /* Timer0_32 MAT2 */
#ifdef __JTAG_DISABLED
LPC_IOCON->JTAG_TDI_PIO0_11 &= ~0x07;
LPC_IOCON->JTAG_TDI_PIO0_11 |= 0x03; /* Timer0_32 MAT3 */
#endif
#if CONFIG_TIMER32_DEFAULT_TIMER32_0_IRQHANDLER==1
timer32_0_capture = 0;
#endif //TIMER32_0_DEFAULT_HANDLER
LPC_TMR32B0->MR0 = TimerInterval;
#if TIMER_MATCH
LPC_TMR32B0->EMR &= ~(0xFF<<4);
LPC_TMR32B0->EMR |= ((0x3<<4)|(0x3<<6)|(0x3<<8)|(0x3<<10)); /* MR0/1/2/3 Toggle */
#else
/* Capture 0 on rising edge, interrupt enable. */
LPC_TMR32B0->CCR = (0x1<<0)|(0x1<<2);
#endif
LPC_TMR32B0->MCR = 3; /* Interrupt and Reset on MR0 */
/* Enable the TIMER0 Interrupt */
NVIC_EnableIRQ(TIMER_32_0_IRQn);
#endif
else if ( timer_num == 1 )
/* Some of the I/O pins need to be clearfully planned if
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<10);
LPC_IOCON->JTAG_TMS_PIO1_0 &= ~0x07; /* Timer1_32 I/O config */
LPC_IOCON->JTAG_TMS_PIO1_0 |= 0x03; /* Timer1_32 CAP0 */
LPC_IOCON->JTAG_TDO_PIO1_1 &= ~0x07;
LPC_IOCON->JTAG_TDO_PIO1_1 |= 0x03; /* Timer1_32 MAT0 */
LPC_IOCON->JTAG_nTRST_PIO1_2 &= ~0x07;
LPC_IOCON->JTAG_nTRST_PIO1_2 |= 0x03; /* Timer1_32 MAT1 */
LPC_IOCON->ARM_SWDIO_PIO1_3 &= ~0x07;
LPC_IOCON->ARM_SWDIO_PIO1_3 |= 0x03; /* Timer1_32 MAT2 */
#endif
LPC_IOCON->PIO1_4 &= ~0x07;
LPC_IOCON->PIO1_4 |= 0x02; /* Timer0_32 MAT3 */
#if CONFIG_TIMER32_DEFAULT_TIMER32_1_IRQHANDLER==1
timer32_1_counter = 0;
timer32_1_capture = 0;
#endif //TIMER32_1_DEFAULT_HANDLER
LPC_TMR32B1->MR0 = TimerInterval;
#if TIMER_MATCH
LPC_TMR32B1->EMR &= ~(0xFF<<4);
LPC_TMR32B1->EMR |= ((0x3<<4)|(0x3<<6)|(0x3<<8)|(0x3<<10)); /* MR0/1/2 Toggle */
#else
LPC_TMR32B1->CCR = (0x1<<0)|(0x1<<2);
#endif
LPC_TMR32B1->MCR = 3; /* Interrupt and Reset on MR0 */
/* Enable the TIMER1 Interrupt */
NVIC_EnableIRQ(TIMER_32_1_IRQn);
#endif
return;
Maybe not all the code above is necessary for a particular application. I do not know.
There is another problem, sometimes you have to change the parameters of a timer on the run as fast as possible between two events that are 10-20 clock cycles apart.
It seems like functions as "init_timer32" need more than 20 clk. ticks. Is there workarounds?
The LPC Xpresso IDE is fantastic to work with :)
When I first downloaded it I had a simple test program running in minutes. It's not as turnkey as Arduino but close.
Here's a version of blink that runs on the LPC1227
#include "LARD.h"
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 7; // different pin on the LPC Xpresso board
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
void loop(void) {
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
Look familiar? :)
______
Rob
I guess I and folks I work with are one of those people, :)
Once you build up your own blocks / functional modules by operating on registers, you have built up your own library: once you have written tmr1_set(1000);, you can call it next time to set a period of 2000 or 50199, without knowing much about how it did it, just that you know with confidence that it will do it right.
The beauty of modular programming.
Surprising. Does that mean you don't do any hand assembly yourself these days, or do you do all your hand assembly with SMD?
My experience is that life's just too short to hand assemble SMD. (But I've never claimed to be the quickest person with a soldering iron.)
Truth is I hate prototyping so I put my faith in data sheets and go straight to a PCB.
That said I don't actually make a lot these days but my current project is a dual processor board, I see no reason the design shouldn't be 99% correct as most hardware is quite simple these days. 99% is close enough and at $65 for 10 PCBs it's cheaper than the SMD breakout boards I'd have to buy as many of the components aren't available in PTH.
I'm not that experienced with soldering SMDs but with a hot-air station I haven't found it that hard so far.
______
Rob
possible that nxp has studied the market and come to the conclusion that this ... "hobbyist" niche is not where they can make sufficient profit to float their boat.
Oh, certainly. Just like most of the major chip vendors. But if they had decided to ignore it entirely, I don't think you'd see products like the 28-pin DIP, or even the more-recently announced 20-pin SOIC. They seem to be aiming at some non-traditional customers of SOME kind.
I think it's because "real engineers" of the mega-profit sort don't actually get to spend a lot of time "evaluating" new CPUs. You get handed a decision, or pick your old favorite, or base a decision on non-interesting criteria like raw speed, supplier reliability, or price. An professional engineer who is actually "evaluating" a chip on more artistic technical merits is closer to a hobbyist than most of them will care to admit (admittedly, of the techno-hobbyist type, rather than the less-technical arduino user. But it still sucks to struggle through that first "blink" attempt...)
I am seeing that MikroElektronika site has: C, Basic and Pascal compilers for ARM, PIC, PIC32, AVR, 8051.
see: http://www.mikroe.com/forum/
The question is, are these people serious? They seem to have all major compilers possible for all major microcontrollers on the market.
Example:
Code written for mikroBasic ARM compiler
' * Project name:
' Pwm_Demo (Demo on using mikroE's PWM library functions)
' * Copyright:
' (c) Mikroelektronika, 2011.
' * Revision History:
' 20110105:
' - initial release;
' * Description:
' This is a simple demonstration of PWM library, which is being used for
' control of the ARM's PWM module. The module is initialized and started,
' after which the PWM's Duty Ratios can be adjusted by means of 4 buttons
' connected to pins PA0, PA1, PA2 and PA3. The changes can be monitored on the PWM
' output pins (PB0 and PB2).
' * Test configuration:
' MCU: LM3S9B95
' http://www.ti.com/lit/ds/symlink/lm3s9b95.pdf
' Dev.Board: EasyMx v7 for STELLARIS(R) ARM(R)
' http://www.mikroe.com/eng/products/view/792/easymx-pro-v7-for-stellaris-arm/
' Oscillator: XT-PLL, 80.000MHz
' Ext. Modules: None.
' SW: mikroBasic PRO for ARM
' http://www.mikroe.com/eng/products/view/753/mikrobasic-pro-for-arm/
' * NOTES:
' - Turn off all PORT LEDs except PORTB at SW15. (board specific)
' - Pull-down PORTA at SW1, and put SW16.1 in VCC position (board specific)
program Pwm_Demo
dim current_duty, old_duty, current_duty1, old_duty1 as word
pwm_period1, pwm_period2 as word
sub procedure InitMain()
GPIO_Digital_Input (@GPIO_PORTA, _GPIO_PINMASK_ALL) ' configure PORTA pins as input
end sub
main:
InitMain()
current_duty = 100 ' initial value for current_duty
current_duty1 = 100 ' initial value for current_duty1
pwm_period1 = PWM_CCP0_Init(5000, @_GPIO_MODULE_CCP0_B0)
pwm_period2 = PWM_CCP3_Init(5000, @_GPIO_MODULE_CCP3_B2)
PWM_CCP0_Start()
PWM_CCP3_Start()
PWM_CCP0_Set_Duty(current_duty, _PWM_INVERTED_DISABLE) ' Set current duty for PWM_CCP0
PWM_CCP3_Set_Duty(current_duty1, _PWM_INVERTED_DISABLE) ' Set current duty for PWM_CCP3
while (TRUE) ' endless loop
if GPIO_PORTA_DATA.B0 = 1 then ' button on RA0 pressed
Delay_ms(1)
current_duty = current_duty + 5 ' increment current_duty
if (current_duty > pwm_period1) then ' if we increase current_duty greater then possible pwm_period1 value
current_duty = 0 ' reset current_duty value to zero
end if
PWM_CCP0_Set_Duty(current_duty, _PWM_INVERTED_DISABLE) ' set newly acquired duty ratio
end if
if GPIO_PORTA_DATA.B1 = 1 then ' button on RA1 pressed
Delay_ms(1)
current_duty = current_duty - 5 ' decrement current_duty
if (current_duty > pwm_period1) then ' if we decrease current_duty greater then possible pwm_period1 value (overflow)
current_duty = pwm_period1 ' set current_duty to max possible value
end if
end if
if GPIO_PORTA_DATA.B2 = 1 then ' button on RA2 pressed
Delay_ms(1)
current_duty1 = current_duty1 + 5 ' increment current_duty1
if (current_duty1 > pwm_period2) then ' if we increase current_duty1 greater then possible pwm_period2 value
current_duty1 = 0 ' reset current_duty1 value to zero
end if
PWM_CCP3_Set_Duty(current_duty1, _PWM_INVERTED_DISABLE) ' set newly acquired duty ratio
end if
if GPIO_PORTA_DATA.B3 = 1 then ' button on RA3 pressed
Delay_ms(1)
current_duty1 = current_duty1 - 5 ' decrement current_duty1
if (current_duty1 > pwm_period2) then ' if we decrease current_duty1 greater then possible pwm_period1 value (overflow)
current_duty1 = pwm_period2 ' set current_duty to max possible value
end if
end if
Delay_ms(1) ' slow down change pace a little
wend
end.
Call me non-interesting, but I think supplier reliability and price actually tend to concentrate the mind over and above other more "artistic" features, at least when when a "real" product is involved. Particularly supplier reliability.
Fair enough, but PCBs don't assemble themselves!
Even with a hot-air station, are you putting all your boards together by hand, or are you sending them out to a service for assembly? I'm wondering at what volume this becomes economical these days...
They've been around for a long time. $249 for a C compiler is not cheap these days, but maybe it's worth it if you get a stack of working libraries for the hardware that port between platforms.
Are those function calls the same in the C version?
Does the same code work on an LPC if you just change the target or something simple?
______
Rob
I've only done a few in this life as an EE. Previously I worked for a company that had a production line and in those days there was no SMDs anyway. I had to load 1 maybe 2 prototype boards but after that I got the assembly people to do them.
In this life I'm retired and only do a few boards for myself every year or so. However my current project may get serious and require a lot of boards. I do have an associate in the US that is happy to load boards but I would think after 10 or 20 he'd rather get a life as well.
So if it gets that far I'll have to find an assembling company.
A friend of mine in NZ did a run of about 10 large boards with a lot of SMDs. Is was worth getting a local firm to load the SMDs for him and he finished off. I can't remember the prices though.
I have also in the past talked with both US and Chinese companies that sell boards. They are often prepared to make and sell them on a royalty basis. For that matter Sparkfun will do that. But this of course means that they have to buy into you product and you in turn lose a lot of control.
That's not necessarily a bad thing though, in fact to me that would be a good thing, I can think of nothing worse than making and testing 100 boards.
______
Rob
A different question,
Can a source code (including the libraries) written in LPC Xpresso be ported, preferably in an easy manner, to Keil uVision4 for ARM?
Reason: LPC Xpresso does not have a simulator while Keil has so the code can be debugged without using the real hardware.
The answer is a little bit difficult.
An ide (uVision or EWARM or Code Red / eclipse) can have different compilers, particularly for an open source ide like eclipse: you can hang actually mdk or iar arm compilers now to eclipse.
IDE is simply an interface to integrate all little pieces together for better productivity.
Libraries are compiler-specific, as a result, not ide-aware.
So if the libraries in question are written for a compiler to be ported to, your code utilizing that library can be easily ported, short of your usual struggle with some syntax issues.
Now, most of the oem libraries on the arm are written for gcc, mdk and iar. The issue is likely cmsis: they may have been built on different versions of cmsis that your target platform may not support. In those cases, you can either sort it out or migrate with the host cmsis.
They are more powerful than AVRs but these ARM Cortex-M micro-controllers do not seem easy to work with. See this discussion: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=127016
Too many vendors, too many types of ARMs, too many different peripherals, too many ways to set them.
The huge diversity of ARMs seems to be their main enemy.
There is such a thing as too much choice that's for sure and I reckon that must put people off.
However once you decide on a family (in my case LPC) the chips are actually very easy to use, well the smaller ones anyway. The ability to MUX functions on pins is good and bad, I find that with a large chip (144 or 217 pins) I need a spread sheet to keep track of what function I have on what pin, that can quickly get to be a nightmare.
But as I say the smaller chips are pretty easy to work with, I downloaded LPCXpresso and had a working test program running in minutes.
Once you get your head around a particular family you are right, but if you flit from vendor to vendor you will go nuts.
Truth is the fact that there's an ARM core is irrelevant to most people, it's the peripherals that you deal with and unfortunately they are all different.
FWIW I think the SAM used in the Due is about the best chip in that size, it has some neat features that the Due does not use. But I prefer LPCs because they have a larger range so that what I learn will be largely portable from 8 pins to 217 pins. If I get a Due that will mean learning a whole new set of peripherals (or keeping to high-level code).
______
Rob
Have you tried ARMwizard (http://alexan.edaboard.eu/index.php?page=armwizard)?
If not (because I am seeing that you have experience with LPC family from NXP) can you try it, when you have time, and tell if this tool for setting ARM peripherals really simplify the work of programmers.
Yes I have, very useful program I think.
I used it when it first came out but at the time it didn't support the 12xx chips and that's what I'm using.
I know it now does but I've since written a HAL framework so don't need it so much however I haven't written drivers for many of the peripherals yet so I think I'll be revisiting ARMwizard to help with that.
_____
Rob
That's the part many people don't understand. As most people write code for those chips with C/C++, the arm core is actually transparent to them. The tasks of working with the peripherals remain the same.
As such, I firmly believe this whole transition to arm is more marketing driven.
You're wrong. Even if your app is not about 32 bit math, remember that most ADCs conversions are 10 bits or more. You should remember too that you don't take a single conversion, but 4 or eight or more, then you average the result. In a 32-bit core like Cortex-M0 this is piece of cake:
for (sum = 0, i = 0; i < 16; i++) {
sum += ADC(channel0);
result = sum / 16;
In fact, there is no div operation at all, but 'sum' is right offset 4 positions. Overall result? Code faster and smaller.
A 8-bit core will take a lot of code just to make the 10-bit integrations inside the loop. Even if you think you are not to use 32-bit math, it will show up quicly whenever you want to implement a sensor-fusion (accelerometer + gyro + compass) in your Arduino.
Another important point that must be taken into account are the 32-bits timers inside the LPC1114. What are they good for? For example, in a servo-controller you gain a better granularity (finer steps).
It's said, though I don't remember the source, that the LPC1114 DIP version was developed focusing in the chinese market. And that makes sense: Not all the electronics in the world is SMD. A really big portion of the cake is still PTH. And China is the major electronics maker now a days. So NXP made its move.
BTW, NXP is not making chips for hobbysts like us, as Microchip has always done. I mean, ARM chips from NXP, Freescale, ST, etc. are for production, while PICs are just for fun (I haven't used PICs ever, and I don't plan to do so ever).
