Arduino Forum
Using Arduino => Motors, Mechanics, and Power => Topic started by: rinze on Nov 18, 2012, 02:58 pm
Title: HDD needle PID controller 2 PIDs 1 working
Post by: rinze on Nov 18, 2012, 02:58 pm
Hello there,
Im trying to control an HDD needle. I made a PID current controller to control the current trough the coil of the needle. as postion sensor i''m using a "transmissive optical sensor" (tcst2103) the more licht the needle block less current flows throucht the fototransistor. passing the current through a resistor gives a voltage that can be measured.
the follwing is my problem. after i got the current PID working i wanted to add the position PID i can eddit the tunings (i know this because getkp() works). But strangly is does not giv an output. i added the code in the attachment. does anybody know the problem ?
under this follows the code
thanks in advance !
#include <PID_v1.h>
double posSetpoint = 0;
double posInput = 0;
double posOutput = 0;
double curSetpoint = 0;
double curInput = 0;
double curOutput = 0;
double positionkp = 0;
double positionki = 0;
double positionkd = 0;
double currentkp = 0;
double currentki = 0;
double currentkd = 0;
#define  currentkpAdress 0
#define  currentkiAdress 4
#define  currentkdAdress 8
#define  positionkpAdress 12
#define  positionkiAdress 16
#define  positionkdAdress 20
PID positionPID(&posInput, &posOutput, &posSetpoint, positionkp, positionki, positionkd, DIRECT);
PID  currentPID(&curInput, &curOutput, &curSetpoint,  currentkp,  currentki,  currentkd, DIRECT);
long previousMillis = 0;
long interval = 2000;
  pinMode(3, OUTPUT);
  pinMode(12, OUTPUT);
  positionPID.SetSampleTime(5);
  positionPID.SetOutputLimits(-150, 150); //the values chosen so that the voicecoil will ont be overloaded with curent 203 ~= 0.185A the range is chosen below the maximum for safety
  positionPID.SetMode(AUTOMATIC);
  currentPID.SetSampleTime(1);
  currentPID.SetOutputLimits(0, 255); //the values chosen to be in the range of analogwrite wich has the exactly the same range as the current PIDcontroller
  currentPID.SetMode(AUTOMATIC);
  currentkp = EEPROMReadDouble(currentkpAdress);
  currentki = EEPROMReadDouble(currentkiAdress);
  currentkd = EEPROMReadDouble(currentkdAdress);
  positionkp = EEPROMReadDouble(positionkpAdress);
  positionki = EEPROMReadDouble(positionkiAdress);
  positionkd = EEPROMReadDouble(positionkdAdress);
  positionPID.SetTunings(positionkp, positionki, positionkd);
   currentPID.SetTunings( currentkp,  currentki,  currentkd);
  analogReference(INTERNAL);
  TCCR2B = TCCR2B & 0b11111000 | 0x01;  //this modifies the PWM frequency of the arduino
  positionLoop(); //this loop regulates the postion of the needle, thus the setpoint for the currentPID control loop
  currentLoop(); //this loop regulates the current going through the voicecoil of the needle, thus the setpoint for the currentPID control loop
  serialcomm();
  positionPID.Compute();
  currentPID.Compute();
   //this is a interval secuence for debugging. it makes te setpoint vary per interval
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval)
    previousMillis = currentMillis;
    if (posSetpoint == 500)
      posSetpoint = 100;
      posSetpoint = 500;
    Serial.println("current setpoint");
    Serial.println(curSetpoint, DEC);
    Serial.println("current output");
    Serial.println(curOutput, DEC);
    Serial.println("current input");
    Serial.println(curInput, DEC);
    Serial.println("");
    Serial.println("position setpoint");
    Serial.println(posSetpoint, DEC);
    Serial.println("position output");
    Serial.println(posOutput, DEC);
    Serial.println("position input");
    Serial.println(posInput, DEC);
    Serial.println("");
void currentLoop()
  curInput = analogRead(2) -82;
  analogWrite(3, abs(curOutput));
  digitalWrite(12, HIGH);
void positionLoop()
//  posInput = analogRead(5);
  posInput = 300;
  if(posOutput < 0)
   digitalWrite(12, LOW);
  if(posOutput > 0)
  //curSetpoint = abs(posOutput);
this is the Serialcomm part, this allows me to eddit the parameters via the terminal. and saves them in the EEprom
#include <EEPROM.h>
int PIDidentifier = 0;
#define  noPID  0
#define posPID  1 //position PID controller
#define curPID  2 //current PID controller
void serialcomm()
  if (Serial.available() > 0)
    char recstring[8] ="     ";
    char numberstring[7] = "    ";
    Serial.readBytes(recstring, 8); // p10.000
    for(int i; i<=4; i++)
      numberstring[i] = recstring[i+1];
    double number = atof(numberstring);
    if(recstring[0] == 'S' && recstring[1] == '-' && recstring[2] == 'p' && recstring[3] == 'o' && recstring[4] == 's')
      Serial.print("setting");
      Serial.println("values in positionPID");
      PIDidentifier = posPID;
    if(recstring[0] == 'S' && recstring[1] == '-' && recstring[2] == 'c' && recstring[3] == 'u' && recstring[4] == 'r')
      Serial.println("values in currentPID");
      PIDidentifier = curPID;
    if(recstring[0] == 'p')
      Serial.print("p");
      Serial.println(number, DEC);
      Serial.println("-");
      if(PIDidentifier == posPID)
        positionkp = number;
      if(PIDidentifier == curPID)
        currentkp = number;
    if(recstring[0] == 'i')
      Serial.print("i");
        positionki = number;
        currentki = number;
    if(recstring[0] == 'd')
      Serial.print("d");
        positionkd = number;
        currentkd = number;
    if(recstring[0] == 'G' && recstring[1] == '-' && recstring[2] == 'p' && recstring[3] == 'o' && recstring[4] == 's')
      double poskp = positionPID.GetKp();
      double poski = positionPID.GetKi();
      double poskd = positionPID.GetKd();
      Serial.println("");
      Serial.println("PID value of PositionPID:");
      Serial.print("p");
      Serial.print(poskp, DEC);
      Serial.println("");
      Serial.print("i");
      Serial.print(poski, DEC);
      Serial.println("");
      Serial.print("d");
      Serial.print(poskd, DEC);
      Serial.println("");
      Serial.println("");
    if(recstring[0] == 'G' && recstring[1] == '-' && recstring[2] == 'c' && recstring[3] == 'u' && recstring[4] == 'r')
      double curkp = currentPID.GetKp();
      double curki = currentPID.GetKi();
      double curkd = currentPID.GetKd();
      Serial.println("");
      Serial.println("PID value of CurrentPID:");
      Serial.print("p");
      Serial.print(curkp, DEC);
      Serial.println("");
      Serial.print("i");
      Serial.print(curki, DEC);
      Serial.println("");
      Serial.print("d");
      Serial.print(curkd, DEC);
      Serial.println("");
      Serial.println("");
      currentPID.SetTunings(currentkp, currentki, currentkd);
    EEPROMWriteDouble(positionkpAdress, positionkp);
    EEPROMWriteDouble(positionkiAdress, positionki);
    EEPROMWriteDouble(positionkdAdress, positionkd);
    EEPROMWriteDouble(currentkpAdress, currentkp);
    EEPROMWriteDouble(currentkiAdress, currentki);
    EEPROMWriteDouble(currentkdAdress, currentkd);
void EEPROMWriteDouble(int ee, double value)
  byte* p = (byte*)(void*)&value;
  for (int i = 0; i < sizeof(value); i++)
    EEPROM.write(ee++, *p++);
float EEPROMReadDouble(int ee)
  double value = 0.0;
    *p++ = EEPROM.read(ee++);
  return value;
