Arduino Forum
Using Arduino => General Electronics => Topic started by: JimboZA on Jan 12, 2013, 07:07 pm
Title: Breadboard-friendly power connectors?
Post by: JimboZA on Jan 12, 2013, 07:07 pm
Hey all,
I have a couple of the connector thingies shown in the attached pic- sorry for quality but it shows the problem which is that they don't fit breadboard power rails.
I know I can jam the wires into the holes, but that doesn't work with stranded wire. What do others do for power connections to breadboard? (No electronics required- I've just hacked an ATX PSU so I have various voltages (3v3, 5v and 12v) available.)
Title: Re: Breadboard-friendly power connectors?
Post by: spycatcher2k on Jan 12, 2013, 07:11 pm
I bonded one of these to a breadboard, and soldered jumper wires to the pins, and inserted them into the rails.
Post by: JimboZA on Jan 12, 2013, 07:15 pm
Yeah I was thinking something along those lines... blob of Araldite should do it.
Post by: spycatcher2k on Jan 12, 2013, 07:20 pm
Yip - I got 2 - one on each power rail - can do 5V & 12V on same board ;-)
Post by: larryd on Jan 12, 2013, 07:27 pm
1. Mount the protoboard on a piece of plastic then add binding posts. Use a wire from the posts to the protoboard.
posts (https://www.google.ca/search?q=binding+post+terminals&hl=en&tbo=u&rlz=1T4GZAZ_enCA411CA411&tbm=isch&source=univ&sa=X&ei=bafxUOuHOqK6igLZqoGQCA&ved=0CEwQsAQ&biw=979&bih=378)
2. Use male headers on the protoboard. Solder wires to and use female headers on the male  :smiley-sweat:
3. Make small PCB with male headers on the bottom. Mount the terminal block you show on the top of the PCB.
Post by: JimboZA on Jan 12, 2013, 07:30 pm
Make small PCB
As the lady on 9gag says, "Ain't nobody got time for that!"  8)
Post by: larryd on Jan 12, 2013, 07:33 pm
Or use:
http://en.wikipedia.org/wiki/Stripboard
Post by: JimboZA on Jan 12, 2013, 07:35 pm
Or use:
Now that I have....
Post by: keeper63 on Jan 12, 2013, 07:51 pm
Then use solid core wire - or use a thin-enough gauge of stranded wire that you can tin the ends (and the tinned section will still fit).
I typically do one of the above, and use alligator clip jumpers from the PSU to the board. I generally will run the inputs to the positive and negative rails on opposite sides (so the alligator clips have less of a chance of shorting), then jumper on the opposite end of the board the other rails.
