Arduino Forum
Products => Arduino Esplora => Topic started by: Grumpy_Mike on Jan 21, 2013, 06:45 pm
Title: EsploraLedShow example error
Post by: Grumpy_Mike on Jan 21, 2013, 06:45 pm
Just going through the examples and came across this error in the EsploraLedShow. That is part of the 1.0.3 IDE
// convert the sensor readings to light levels:
  byte red   = map(xAxis, -512, 512, 0, 255);
  byte green = map(xAxis, -512, 512, 0, 255);
  byte blue  = slider/4;
spot that red and green are mapped to the same axis, it should be:-
  byte green = map(yAxis, -512, 512, 0, 255);
It is fine in the library examples however.
