Arduino Forum
Topics => Home Automation and Networked Objects => Topic started by: pisayjames on Jan 22, 2013, 11:38 am
Title: Home automation project
Post by: pisayjames on Jan 22, 2013, 11:38 am
i was able to make a simple webserver that could control relays.. now i have have pushbuttons to have a second option in controlling the same relays, my problem is how will i be able to update my webserver with the status of my relays when i use pushbuttons as manual control...( i know webservers only send datas,so any ideas to my problem? hopefuly you can help me with the codes too because im still newbie with arduino thank you)
Title: Re: Home automation project
Post by: Kong on Jan 22, 2013, 07:38 pm
Wat's exactly the problem?
I assume you've connected the relays to an output pin of your webserver (which you control by a webbrowser).
Now you've connected a pushbutton to your webserver, also to control the relays.
In that case you still know the position of the relay (i.e. the status of the output pin).
Post by: Arrch on Jan 22, 2013, 08:21 pm
Why do you keep making new threads about the same issue, despite getting the answer in multiple threads?
Post by: pisayjames on Jan 25, 2013, 03:34 pm
what i mean is if i use my pushbuttons, theres nothing happening to my browser.. what i want to happen is that if i use my pushbuttons the state of relays that are displayed on my browser will also change.. but unfortunately i dont know the codes etc..
