Arduino Forum
Using Arduino => Programming Questions => Topic started by: 012anonymousxyz on Feb 12, 2013, 06:13 pm
Title: Problem: I2C Configuration Between Two Arduinos
Post by: 012anonymousxyz on Feb 12, 2013, 06:13 pm
Hello and thank you all! Here are my codes:
Arduino Master:
#include <Wire.h>
int counter = 0;
  Wire.begin();
  Wire.beginTransmission(1);
  Wire.write(counter);
  Wire.endTransmission();
  counter++;
Arduino Slave:
#include <Wire.h>
int val = 0;
  Wire.begin(1);
  val = Wire.read();
  Serial.println(val);
My problem is that the serial monitor only prints -1 repeatedly, indicating that I'm not receiving any data (I had a while loop waiting for serial data (Wire.available()==0) but got rid of it because there was no printing going on period.
I think it might be a physical configuration thing:
I have both the A5 pins connected to a rail on my breadboard, which is connected to high via a 10k ohm resistor.
I have both the A4 pins connected to a rail on my breadboard, which is connected to high via a 10k ohm resistor.
I have the ground pins on my two Arduinos connected to each other.
I have a ground pin from my slave Arduino connected to my breadboard.
I have one 5V output pin from my slave Arduino connected to my breadboard
Title: Re: Problem: I2C Configuration Between Two Arduinos
Post by: PaulS on Feb 12, 2013, 06:27 pm
On the slave, you should have an onRequest event handler registered. That gets called when the master wants to talk to the slave.
I2C is not serial. That Wire.available() never reported a value greater than 0 should be a clue that the devices are not talking.
Show a picture or schematic of your setup.
This does not sound right. The I2C pins should not be connected the +V rail.
Post by: MaLi on Feb 12, 2013, 06:35 pm
Google Nick Gammon. He wrote a nice master/slave routine for sending data between two arduinos.
hope it helps,
MaLi
