Arduino Forum
Using Arduino => Programming Questions => Topic started by: ScottCaval on Feb 14, 2013, 01:06 am
Title: Timing Issues
Post by: ScottCaval on Feb 14, 2013, 01:06 am
I am trying to have a fan trigger at an value stored in a array. After the 3rd hour and starts to through a negative number. Any ideas?
int FanTimeArray[9] = {
 24,24, 23, 22, 21, 20,19,18,24};
void FanRelay(){
 relayTriggerInterval=86400000/FanTimeArray[Day];
   if(Day<8){
     if(millis() - relayMillis > relayTriggerInterval){
     relayMillis=millis();
Title: Timing issues
Post by: ScottCaval on Feb 14, 2013, 01:20 am
I am trying to have a fan trigger at an value stored in a array. After the 3rd hour starts  it begins to give me a negative number. Any ideas?
void FanRelay(){
   if(Day<8){
Title: Re: Timing issues
Post by: nickgammon on Feb 14, 2013, 01:26 am
Post more of your code please. How is relayTriggerInterval defined?
Post by: ScottCaval on Feb 14, 2013, 01:32 am
int DayCount;
float relayMillis;
float Hour,Minute,Second,ms;
float Day;
unsigned long start, finished, elapsed;
  0,24, 23, 22, 21, 20,19,18,24}; // In Hours
  pinMode(12,OUTPUT);
  intiatClock();
  FanRelay();
void intiatClock()
  unsigned long over;
  start=millis();
  elapsed=finished-start;
  Hour=1+int(start/3600000);
  over=start%3600000;
  Minute=1+int(over/60000);
  over=over%60000;
  Second=int(over/1000);
  ms=over%1000;
  Day=1+int(start/86400000);
void FanRelay(){
  long relayTriggerInterval;
  long relayTriggerInterval_after8;
  int intDay;
  intDay=Day; //Change to int
  relayTriggerInterval=86400000/FanTimeArray[intDay];
    if(intDay<8){
        relayMillis = millis();
     else{
       //Do nothing
Title: Re: Timing Issues
Post by: PaulS on Feb 14, 2013, 01:33 am
In the absence of directives to the contrary, literal constants are interpreted as ints. That doesn't look like a value that would fit in an int.
You might try
  relayTriggerInterval=86400000UL/FanTimeArray[Day];
Post by: billroy on Feb 14, 2013, 01:36 am
I don't know if this is your bug, but it is curious that relayMillis is declared float.  What happens if you make it unsigned long?
-br
Edit: Hour, minute, second, etc could all be int, too, yes?
Post by: JChristensen on Feb 14, 2013, 01:40 am
Cross-posted ... please delete one or the other.
http://arduino.cc/forum/index.php/topic,148841.0/topicseen.html
Post by: JChristensen on Feb 14, 2013, 01:41 am
http://arduino.cc/forum/index.php/topic,148838.0.html
Post by: PaulS on Feb 14, 2013, 01:41 am
How is this different from your post in Project Guidance?
Post by: nickgammon on Feb 14, 2013, 01:43 am
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Post by: ScottCaval on Feb 14, 2013, 01:45 am
Thank you for merging the w posts. It will not happen again.
Post by: nickgammon on Feb 14, 2013, 01:48 am
What does 'finished' do? It never changes.
Post by: nickgammon on Feb 14, 2013, 01:50 am
You might try
Not if they won't fit into an int.
Test:
void setup ()
  Serial.begin (115200);
  unsigned long relayTriggerInterval=86400000;
  Serial.println (relayTriggerInterval);
  }  // end of setup
void loop () { }
Output:
86400000
Post by: nickgammon on Feb 14, 2013, 01:53 am
In this example, though, what PaulS said applies:
void setup ()
  unsigned long relayTriggerInterval=864 * 100 * 1000;
  }  // end of setup
void loop () { }
Output:
23552
Since each number in the expression fits into an int, the whole thing is evaluated as an int, giving incorrect results.
Post by: CrossRoads on Feb 14, 2013, 01:57 am
This is backwards too:
 start=millis();
Should always be this format:
elapsed time = (most recently captured millis/micros) - (earlier capture millis/micros);
Then when millis/micros roll over, the result be expected number, for example
millis after rollover - millis before rollover = elapsed millis :
0x00000100 - 0xFFFFFF00 = 0x00000200
Post by: ScottCaval on Feb 14, 2013, 02:06 am
One other thing I failed to mention, Day 1 should stay the same for 24 hours and should point to the second position in the array. As soon as it puts out a negative number (at the 3rd hour) it also starts to point to a different position in the Fan array. As you can tell I am new to this so I apologize if the answer is completely obvious.
Post by: CrossRoads on Feb 14, 2013, 02:25 am
if the time related variables are all type unsigned long, there will be no negative numbers.
just comes down to logic flaws at that point.
