Arduino Forum
Products => Arduino Due => Topic started by: henrimontreal on Apr 08, 2013, 03:28 am
Title: The frequency slows down continously but takes time to spped up!
Post by: henrimontreal on Apr 08, 2013, 03:28 am
Hi guys,
You helped me to solved some problems of the code but now I got stuck somewhere else!  :smiley-yell:
As you know I had decided to use our buddy, "Serial Monitor" to change the frequency of blinking.
Here is the final code as follows.
volatile boolean l;
//unsigned int integerValue=0;  // Max value is 65535
//char incomingByte;
void TC0_Handler()
    long dummy=REG_TC0_SR0; // vital - reading this clears some flag    --- Status REG
                            // otherwise you get infinite interrupts
    l= !l;
    //REG_TC0_CCR0=0b101; //Start counter
//void setFrequen
void setup(){
  Serial.begin(57600);
  pinMode(13,OUTPUT);
void loop(){
       digitalWrite(13,l);
if (Serial.available() > 0) {   // something came across serial
   char buffer[] = {' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL'};
Serial.readBytesUntil('\n', buffer, 20);
int  incomingValue = atoi(buffer);
   Serial.println(incomingValue);
   pinMode(2,OUTPUT);    // port B pin 25
  analogWrite(2,255);
   REG_PIOB_PDR = 1<<25; // disable PIO, enable peripheral
  REG_PIOB_ABSR= 1<<25;
     REG_TC0_CMR0=0b00000000000010011100010000000000;
  REG_TC0_IER0=0b00010000;
  REG_TC0_RC0 = incomingValue*1000000;
  NVIC_EnableIRQ(TC0_IRQn);
This works perfectly and each time when I put a new value for "incomingValue", it changes the frequency by changing the amount of "REG_TC0_RC0".
But I can only count up. What does this mean. I mean as follows:
1
8
20
40
80
100
Then I can see the frequency slows down and the LED beats slower and this change is instantly ..... But what if I go this way
1
8
1
Surprisingly it does change it instantly .... from 1 to 8 it is immediately but from 8 to 1 it takes 2 minutes!!!
I look for "COUNT DOWN/UP"  in the datasheet and found the following register:
REG_TC0_SMMR0
which is responsible for count down and up
but I guess the problem is something else...
I am totally confused!
The problem is the "Serial monitor" and the way I used the buffer or NO! The problem is the Register configuration itself?
What do you think?
Any idea about this?
I really appreciate your kind and prompt reply in advance!  :)
Title: Re: The frequency slows down continously but takes time to spped up!
Post by: el_supremo on Apr 08, 2013, 04:22 am
It doesn't even compile.
Pete
Post by: henrimontreal on Apr 08, 2013, 04:43 am
Please try again. I just edited two minor mistake.
Post by: el_supremo on Apr 08, 2013, 05:43 am
It still doesn't compile. Why not post the working code?
Pete
Post by: henrimontreal on Apr 08, 2013, 06:09 am
No this works properly. Check out the IDE you work with.
Thanks anyway.
Post by: JimboZA on Apr 08, 2013, 06:18 am
Thanks anyway.
sketch_apr08a.cpp: In function 'void TC0_Handler()':
sketch_apr08a:9: error: 'REG_TC0_SR0' was not declared in this scope
sketch_apr08a.cpp: In function 'void loop()':
sketch_apr08a:42: error: 'REG_PIOB_PDR' was not declared in this scope
sketch_apr08a:43: error: 'REG_PIOB_ABSR' was not declared in this scope
sketch_apr08a:44: error: 'REG_TC0_CMR0' was not declared in this scope
sketch_apr08a:45: error: 'REG_TC0_IER0' was not declared in this scope
sketch_apr08a:47: error: 'REG_TC0_RC0' was not declared in this scope
sketch_apr08a:48: error: 'TC0_IRQn' was not declared in this scope
sketch_apr08a:48: error: 'NVIC_EnableIRQ' was not declared in this scope
To me, that doesn't look like it works perfectly....
Post by: henrimontreal on Apr 08, 2013, 06:37 am
This is strange but I use an ARDUINO IDE on mac and it works!
And I have got it from here:
http://arduino.cc/forum/index.php?topic=130423.0
So there must be something wrong on your IDEs.
Post by: JimboZA on Apr 08, 2013, 06:50 am
Whatever, but I won't be exploring that.
Post by: UKHeliBob on Apr 08, 2013, 08:30 am
Henri, what board and IDE are you using ?
Post by: nickgammon on Apr 08, 2013, 08:35 am
Doesn't compile for me:
sketch_apr08b.ino: In function 'void TC0_Handler()':
sketch_apr08b:9: error: 'REG_TC0_SR0' was not declared in this scope
sketch_apr08b.ino: In function 'void loop()':
sketch_apr08b:42: error: 'REG_PIOB_PDR' was not declared in this scope
sketch_apr08b:43: error: 'REG_PIOB_ABSR' was not declared in this scope
sketch_apr08b:44: error: 'REG_TC0_CMR0' was not declared in this scope
sketch_apr08b:45: error: 'REG_TC0_IER0' was not declared in this scope
sketch_apr08b:47: error: 'REG_TC0_RC0' was not declared in this scope
sketch_apr08b:48: error: 'TC0_IRQn' was not declared in this scope
sketch_apr08b:48: error: 'NVIC_EnableIRQ' was not declared in this scope
It would help to specify what board you have selected, this isn't supposed to be a guessing game.
And please don't use the variable name "l".
Can you see the difference between:
foo = 1;  // the number one
foo = l;  // lower-case L
I can't, easily.
Post by: henrimontreal on Apr 08, 2013, 05:48 pm
I use Arduino Due and IDE is 1.5.2.
Post by: UKHeliBob on Apr 09, 2013, 08:17 am
It would have been easier if you had said that in the first place.
Post by: stimmer on Apr 09, 2013, 01:22 pm
You need to reset the counter whenever you change the period. What can go wrong is, if you shorten the period, the counter might have already gone past the new period value, and then it won't trigger the interrupt until it has counted all the way to 0xFFFFFFFF, wrapped around to 0 and got to the new period value - which is why it takes a while to speed up.
The line REG_TC0_CCR0=0b101; restarts the counter. You need to put it just after REG_TC0_RC0 = incomingValue*1000000;
Post by: henrimontreal on Apr 13, 2013, 05:24 am
Stimmer! You are awesome! The problem got solved! Special thank to you!  :)
Now, I have one more question and I wonder if you or anyone who reads this can kindly answer to it. As you can see here and the page 871 and 872 of Datasheet for Arduino Due (AT91SAM), there are some special pins to enable the Timer.
Here we use TC0 Channel 0 and pins 2 1nd 13.
I tried Pin 61 and 62 (For PA2 and PA3 for the AT91SAM ) and TC0 channel 1  to get another independent frequency. For example
instead of REG_TC0_SR0 I have used REG_TC0_SR1. But this approach seems doesn't work properly. Do I need to apply other changes?
Do you know how I can get a couple of unique and completely independent frequency out of this?
Thank you for your help.
