So far I've already played around with the pitches.h library and hooked up a small 8ohm 0.1w speaker directly to the arduino (using a 150ohm resistor too) So far that has worked fine with my program.
But my goal for part of my project is to hook up a larger more powerful speaker (I have a 4" 8ohm 10w or a 2" 8ohm 3w speaker that I'd prefer to use) and get loud audio (simple tones really). So, I need some kind of amplifier.
I've started to search around the forum and on google but I just get more confused as I look at amp circuits. I tried making the audio amplifier from the Aduino Basic Connections guide http://arduino.cc/forum/index.php/topic,154549.0.html
(http://www.gammon.com.au/images/Arduino/Arduino_forum_amplifier_query.png)
Although I didn't have a BC337 on hand. I used a P2N2222 instead. (I also have some BC328, BC549, and BC550 lying around) I did get some audio out of the speaker, but it isn't what I'd call loud.
I also tried making this: (found it searching google)
(http://freecircuits.org/wp-content/uploads/2011/05/Transistor-Cascading-Amplifier-circuit.png)
but that was even worse, as I didn't get any audio from the speaker.
Poking around I do see CrossRoad's circuit using IRF3707Z MOSFET http://arduino.cc/forum/index.php/topic,157647.msg1184322.html#msg1184322, but I'd have to order one (would prefer to use components I already have if possible).
I also see this post http://arduino.cc/forum/index.php/topic,114094.msg858503.html#msg858503
(http://www.electronics-tutorials.ws/amplifier/amp21.gif)
but there is no guidance on what values are needed for the resistors and capacitors. I would try making it, but what components do I use? (I have a fairly good assortment of resistors/capacitors and the 4 transistor types I mentioned) I'll also be powering my project from a 12v battery, so would prefer to use that as the voltage level for the speaker (but could just as easily step it down, since I have a 12v-5v switching voltage regulator)
Looking for help XD
the 2222 is not that great for amplification applications, have you tried your other transistors? (look at the datasheets, like the 328 is a PNP, the 549 and 550 are npn)
and loud is depending on the source, some hard nasty square waves though a single transistor amp is going to be brutal, music on the other hand may not be as noticeable.
personally I am not that good with amp's, I just kind of throw crap at it until its to my tastes (in the case of your third circuit), both cap's are electrolytic, c1 blocks DC and depending on what size it is will cut off frequencies, not entirely sure what C2 does but its probably for clarity of some form
The both circuits OP post does not work.
FYI
Here is the one might beat a lot of Audio Amps which is sold at Bestbuy since they are Class-AB.
Pure Class-A 2SK1058 MOSFET Audio Amplifier
(http://s21.postimg.org/jkre5nk07/class_A.jpg)
2SK1058 is one type power MOSFET suitable for audio power amplifier, and it has very high Ron (~15 Ohms).
Substitute power MOSFET with power JFET will push this to beat a lot of semiconductor Class-A amplifier, very close or match with tube Class-A amplifier.
Don't use this with Arduino, Arduino sounds terrible.
If you just want to amplify tones generated by the Arduino, try the attached schematic. It will deliver about 0.3W into 8 ohms. If you need more volume than that provides and you want to run the amplifier from 5V, then I suggest this chip http://www.ti.com/lit/ds/symlink/lm4871.pdf (http://www.ti.com/lit/ds/symlink/lm4871.pdf) or someting similar.
[EDIT: corrected transistor types]
If you just want to amplify tones generated by the Arduino, try the attached schematic. It will deliver about 0.3W into 8 ohms. If you need more volume than that provides and you want to run the amplifier from 5V, then I suggest this chip http://www.ti.com/lit/ds/symlink/lm4871.pdf (http://www.ti.com/lit/ds/symlink/lm4871.pdf) of someting similar.
Never thought to make audio amp that easy, cool.
It's simple because it only has to amplify square waves of a fixed amplitude, which is what comes out of an Arduino digital pin or PWM pin. It's no good for amplifying general audio signals, or the outputs from the DACs on the Due.
I made the amp that you drew up. Works ok and puts out more audio than before. I'll order some parts this week for a more powerful amp.
Surely all you need to do is treat your speaker like any other PWMed load selecting appropriate voltage to not blow the speaker. You could use a low pass filter to try and round off the square wave but that could get tricky if your using different frequencies
I use LM386N8's, easy to put down on either perf board or dead bug and DIP8 chip's are available... Just don't hit it with too much audio drive. The fet amp with the 2SK part would be best described as self biased class A (Gate bias is derived from the drain current only). It also draws an inordinate amount of current for what it needs to do.. These guys are semi local to me and the prices are good too http://www.oddwires.com/chip-amps/ (http://www.oddwires.com/chip-amps/) I always keep 3 or 4 of the LM386's just for this reason... One unusual use is to make the chip oscillate and rectify the output for a neg bias supply with some current available. All in all, Low voltage use, gains from 20 to 200 and operation from 4 to 12V (use 9V or less, 5V is OK but NEEDS a big supply bypass capacitor (220 to 470 uF) make it a fine choice. For many years I used one as an audio signal tracer and many times was very handy for digital work as well. Use your imagination.
Doc
I use LM386N8's...
I tried downloading your PDF but it doesn't open. Have another link for it?
I studied some electronics YEARS ago so I can get a feel for some of his design but I can't see what is gained by dropping half the power across a 40W resistor.
Advantages of class-A Audio amplifiers
Class-A designs are simpler than other classes; for example class-AB and -B designs require two devices (push-pull output) to handle both halves of the waveform; class A can use a single device single-ended.
The device is never shut off completely there is no "turn on" time, little problem with charge storage, and generally better high frequency performance and feedback loop stability (and usually fewer high-order harmonics).
The point at which the device comes closest to being cut off is not close to zero signal, so the problem of crossover distortion associated with class-AB and -B designs is avoided.
Disadvantage of class-A audio amplifiers
They are very inefficient. A theoretical maximum of 50% is obtainable with inductive output coupling and only 25% with capacitive coupling.
Class A amplifiers, wiki (http://en.wikipedia.org/wiki/Amplifier#Advantages_of_class-A_amplifiers)
Basic OP list 2 failed class-A Audio amplifiers circuits, I post one working class-A audio amplifiers for reference.
that and the cost of a 40 watt resistor could feed your family dinner
Well, at 40W you would be 60W short of being able to use it for you Suzy Homebaker Oven. Alas, the 100W bulbs are now a thing of the past though. ;)
How many watt resistor does your family dinner cost? 8)
OK. I think this is the part I was missing. That and forgetting what the basic classes did. Thanks for taking the time to answer this for me.
I use one of these:
http://adafruit.com/products/987
to drive a couple of speakers. Use only one channel if need be.
Being class D they are efficient too while having plenty of power for their size.
Another, less powerful, class D one here:
https://www.sparkfun.com/products/11382
I onow this is an old thread, sorry to bother you, but i was wondering: shouldn't there be a resistor between the arduino and the transistors here? And one between the 5v and the cap? I ask because i'm having troubles in my project . The speaker is causing short outs.
I use this in my fencing scoring machines to make a loud 2-tone warble when a touch is scored.
The switch & resistors act as sort of a Hi/Lo volume control (wife says both are too loud).
The box has a bunch of holes drilled in front of it to act as guard against errant things that might be tossed that way.
You can make out the MOSFET and 68 ohm resistors at the lower right of the board.
http://crossroadsfencing.com/BobuinoRev17
(http://crossroadsfencing.com/scoring_machine_minimal_front.jpg)
Thank you. Can you explain how the capacitor functions to avoid a short?
By the way, the link does not work.
There is no need for a resistor between the Arduino and the transistors, because the transistors are in the emitter follower configuration. The effective load resistance seen by the Arduino pin is the load resistance (8 ohm speaker) multiplied by the hfe of the transistors (at least 30, and probably much higher than that). I don't understand why you would want to add a resistor between 5V and the cap.
(fixed typo in link)
Capacitors only let changing signals thru - think of it like charging up, and once charged no more current flows.
http://en.wikipedia.org/wiki/Capacitive_coupling
Because it'll create a short between +5 and ground? Even though the speaker is just 8ohm, too much current will flow, it basically fried my 328.
No, something else fried your Arduino. The peak current from the positive rail through the upper transistor will be no more than 500mA, and the maximum average current flow cannot exceed 100mA. You could add another capacitor between +5V and ground to help supply the peak current.
I am not yet fully understanding all this, but thanks for trying to explain. I'll do some experimenting to try and comprehend this.
I'll try to explain my situation. I was using the attached circuit when i said this:
(http://i.imgur.com/0L6GvzKl.jpg)
Notice there's no capacitor in my circuit. When i put a PWM on the pin, the speaker pulled so much current that the whole project (running on batteries) was drained of power causing all sorts of bugs (cpu reset) and heat generation in the 7805, which would otherwise be stable. Using >100 ohm for R2 solved all problems, except the volume was way too low.
So when i saw your solution, with just a capacitor and no resistors, i was wondering why.
Edit: smaller image
I've given up on this part. I settled for a 50 ohm resistor R2 (next to the speaker) to stop my project from self destruction. I've tried a lot of thing to up the volume, including an 12v feed, and NPN/PNP pair AB class and even a TDA7052a amp ic, but all they did was suck too much current (the amp ic was LOUD btw before it took out the fuse). I've had enough frustration for now. I'll be stepping back for a few days/weeks to release the irritation and perhaps regain some enthousiasm.
Thank you all for assisting, even though it backfired on me.
LM386. Can't get much simpler. No series resistor needed, just a volume control on the input and the other requisite parts. Low power draw.
LM386 is also low power output. P=V^2/R = 25/8 or 3W with 5V supply and 8 ohm speaker.
Transistor drops some voltage, so output will be less, say 2.4W if Vce of transistor is 0.6V.
Current draw will be 4.4/8 = .55A if transistor is allowed to turn on & stay on. That's what the capacitor provides - it only allows current flow until it charges up, and then it approaches looking like an open circuit. When it does, the speaker cone starts returning to initial position, and the current flow in the other direction moves the cone in the other direction.
So in my circuit, with the transistor off, the speaker gets driven in the positive direction while the cap charges up, then the transistor turns on and drains the cap allowing the speaker to return to neutral, and repeats the cap charging when the transistor turns on again.
With 12V and the speaker I used, it is loud! Even with the two 68 ohm resistors in series it is loud.
Course, its a 4 ohm speaker, so ideal power would be 12V*12V/4ohm = 36W. I run from a wallwart, so it can supply the current needed: 12/4 = 3A. The 68 ohm resistors help bring that down a lot - and wife says its still too loud!
He said he blew a fuse using a larger amplifier IC. So presumably he needs lower power, just more than he has now. An LM386 can be run from a higher voltage and has the advantage of being simple.
If you need better quality than a single-transistor switch, and more power than an LM386, you might as well buy an amplifier module or "powered speaker" from one of the import vendors...
http://www.ebay.com/itm/New-12V-Mini-Digital-Amplifier-Board-10W-10W-D-Class-PAM8610-/151161261626?pt=LH_DefaultDomain_0&hash=item2331e9ce3a
http://www.newegg.com/Product/Product.aspx?Item=9SIA38V18K5100
Its good to see the responses. Thanks for that. However i've decided to step away for a few days to "chill out", so i might not respond for a few days. But at least i owe you a response...
Perhaps the lm386 is the solution. I don't know. I've tried with the tda7052a (which i heard is a similar amp ic with internal caps) and that didn't solve the 'starvation' issue. With 'starvation' i mean that so much current goes from the battery to the little speaker that my display backlight and led indicators are dimmed. In fact, seen on a scope, it pulls the 5v below 2.8v at which my 328p is saying "no more, i'm off..". I know the circuit is otherwise fine because if i disconnect a single lead from the speaker everything works as it should.
The phone works on a 1400 mAh battery pack and now uses only 45mA on idle. The sound wave is a full 0-5v square wave generated by the Arduino tone() function.
The speaker is very small. It is the original 'handsfree' speaker of the phone that has been in there since the 90's and should be able to provide sufficient noise. Since it mounts in the plastic handset i'm not keen on replacing it.
My feeling is that it should at least make as much noise as a little piezo speaker. That is, i should hear it ringing across the room.
Piezos can be remarkably efficient and loud when driven around their resonant frequency.
The TDA7052A is a bridge amplifier, which means you can't ground either side of the speaker. Also, if you forget the capacitor between the Arduino and the TDA7052A, it may drive the output hard one way. Causing no sound, but a lot of current. And you still need a volume control.
Looking for help XD
Which software do you use in making all those layout circuits?
Thanks
