Arduino Forum
Development => Other Software Development => Topic started by: Asvaldr on Jul 08, 2013, 04:16 am
Title: [SOLVED] AVRDude Not supporting Mega2560 (Eclipse Arduino Plugin)
Post by: Asvaldr on Jul 08, 2013, 04:16 am
Hi All,
I've been unable to find a solution to a problem no one else seems to have had.
I'm trying to get the Eclipse Arduino Plugin to function; all is well until upload time.
I've followed the easy install instructions on http://www.baeyens.it/eclipse/Install.html and the project creation http://www.baeyens.it/eclipse/UsethePlugin.html .
Problem is, when i go to use the AVR button to upload to my Mega2560 R3, i get the following error: (also shown in the picture attached)
"AVRDude does not support the project target MCU [Atmega2560]
Please select a different target MCU and try again if you want to use AVRDude"
Has anyone got any ideas on how to help me with this; it would be greatly appreciated. Also it will be up here for anyone else with the issue.
Thanks in advance.
Title: Re: AVRDude Not supporting Mega2560 (Eclipse Arduino Plugin)
Post by: THX_RoG on Jul 08, 2013, 04:25 am
i was having this problem but cant remember how i get out of this
if i remember correct u can re-install this plugin and the problem will go away or if not u can simply change the MCU val
MCU is the clock of u board if im not mistaken
Post by: Jantje on Jul 08, 2013, 02:04 pm
I'm using the Mega 2560 in half of my projects. So this works  :D.
Can you dump the console output? and provide the version you are using of the plugin?
Best regards
Jantje
Post by: Asvaldr on Jul 09, 2013, 03:18 am
Thanks both of you for the replies. I've had this same problem using eclipse Kepler and Juno; currently i'm trying juno with the following
The Arduino Eclipse Plugin is Version 1.2.5.5
The Eclipse IDE is 1.5.2.20130211-1820
I'm using 32bit Juno on a Win7x64 machine.
The arduino IDE does sucessfully program the board.
The console output from eclipse when building the project is quoted below. (with verbose)
11:19:25 **** Build of configuration Release for project MySketch ****
make all
Building file: ../MySketch.cpp
Invoking: AVR C++ Compiler
avr-g++ -I"D:\Programs\arduino-1.0.5\hardware\arduino\cores\arduino" -I"D:\Programs\arduino-1.0.5\hardware\arduino\variants\mega" -I"D:\Workspace_Arduino\MySketch" -D__IN_ECLIPSE__=1 -DUSB_VID= -DUSB_PID= -DARDUINO=105 -Wall -Os -ffunction-sections -fdata-sections -fno-exceptions -v -g -mmcu=atmega2560 -DF_CPU=16000000UL -MMD -MP -MF"MySketch.d" -MT"MySketch.d"  -c -o "MySketch.o" -x c++ "../MySketch.cpp"
Using built-in specs.
Target: avr
Configured with: ../gcc-4.3.2/configure --enable-win32-registry=WinAVR-20081205 --with-gmp=/usr/local --with-mpfr=/usr/local --prefix=/c/WinAVR --target=avr --enable-languages=c,c++,objc --with-dwarf2 --enable-doc --disable-shared --disable-libada --disable-libssp --disable-nls --with-pkgversion='WinAVR 20081205' --with-bugurl='URL:http://sourceforge.net/tracker/?atid=520074&group_id=68108&func=browse'
Thread model: single
gcc version 4.3.2 (WinAVR 20081205)
COLLECT_GCC_OPTIONS='-ID:\Programs\arduino-1.0.5\hardware\arduino\cores\arduino' '-ID:\Programs\arduino-1.0.5\hardware\arduino\variants\mega' '-ID:\Workspace_Arduino\MySketch' '-D__IN_ECLIPSE__=1' '-DUSB_VID=' '-DUSB_PID=' '-DARDUINO=105' '-Wall' '-Os' '-ffunction-sections' '-fdata-sections' '-fno-exceptions' '-v' '-g' '-mmcu=atmega2560' '-DF_CPU=16000000UL' '-MMD' '-MP' '-MFMySketch.d' '-MTMySketch.d' '-c' '-o' 'MySketch.o'
d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../libexec/gcc/avr/4.3.2/cc1plus.exe -quiet -v -ID:\Programs\arduino-1.0.5\hardware\arduino\cores\arduino -ID:\Programs\arduino-1.0.5\hardware\arduino\variants\mega -ID:\Workspace_Arduino\MySketch -imultilib avr6 -iprefix d:\programs\arduino-1.0.5\hardware\tools\avr\bin\../lib/gcc/avr/4.3.2/ -MMD MySketch.d -MFMySketch.d -MP -MTMySketch.d -MQ MySketch.o -D__IN_ECLIPSE__=1 -DUSB_VID= -DUSB_PID= -DARDUINO=105 -DF_CPU=16000000UL ../MySketch.cpp -quiet -dumpbase MySketch.cpp -mmcu=atmega2560 -auxbase-strip MySketch.o -g -Os -Wall -version -ffunction-sections -fdata-sections -fno-exceptions -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\agibson\AppData\Local\Temp/ccJNh9mT.s
ignoring nonexistent directory "d:/programs/arduino-1.0.5/hardware/tools/avr/lib/gcc/../../avr/include/c++/4.3.2"
ignoring nonexistent directory "d:/programs/arduino-1.0.5/hardware/tools/avr/lib/gcc/../../avr/include/c++/4.3.2/avr/avr6"
ignoring nonexistent directory "d:/programs/arduino-1.0.5/hardware/tools/avr/lib/gcc/../../avr/include/c++/4.3.2/backward"
ignoring nonexistent directory "d:/programs/arduino-1.0.5/hardware/tools/avr/lib/gcc/../../avr/sys-include"
#include "..." search starts here:
#include <...> search starts here:
d:\programs\arduino-1.0.5\hardware\tools\avr\bin\../lib/gcc/avr/4.3.2/include
d:\programs\arduino-1.0.5\hardware\tools\avr\bin\../lib/gcc/avr/4.3.2/include-fixed
d:/programs/arduino-1.0.5/hardware/tools/avr/lib/gcc/../../lib/gcc/avr/4.3.2/include
d:/programs/arduino-1.0.5/hardware/tools/avr/lib/gcc/../../lib/gcc/avr/4.3.2/include-fixed
End of search list.
GNU C++ (WinAVR 20081205) version 4.3.2 (avr)
   compiled by GNU C version 3.4.5 (mingw-vista special r3), GMP version 4.2.3, MPFR version 2.3.2.
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
Compiler executable checksum: a5eaa4751655043614dbbfd845ac39f8
d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/as.exe -mmcu=atmega2560 -o MySketch.o C:\Users\agibson\AppData\Local\Temp/ccJNh9mT.s
COMPILER_PATH=d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../libexec/gcc/avr/4.3.2/;d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../libexec/gcc/;d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/
Finished building: ../MySketch.cpp
Building target: MySketch.elf
LIBRARY_PATH=d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr6/;d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr6/;d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/;d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/;d:/programs/arduino-1.0.5/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/
Invoking: AVR C++ Linker
avr-gcc -Os -Wl,--gc-sections  -L"D:\Workspace_Arduino\Arduino_Mega_2560_or_Mega_ADK/Release" -mmcu=atmega2560  -o"MySketch.elf"  ./MySketch.o   -l"Arduino_Mega_2560_or_Mega_ADK" -lm
Finished building target: MySketch.elf
Invoking: AVR Create Extended Listing
avr-objdump -h -S MySketch.elf  >"MySketch.lss"
Finished building: MySketch.lss
Create Flash image (ihex format)
avr-objcopy -R .eeprom -O ihex MySketch.elf  "MySketch.hex"
Finished building: MySketch.hex
Create eeprom image (ihex format)
avr-objcopy -j .eeprom --no-change-warnings --change-section-lma .eeprom=0 -O ihex MySketch.elf  "MySketch.eep"
Finished building: MySketch.eep
Invoking: Print Size
avr-size --format=avr --mcu=atmega2560 MySketch.elf
AVR Memory Usage
Device: atmega2560
Program:    1660 bytes (0.6% Full)
(.text + .data + .bootloader)
Data:         11 bytes (0.1% Full)
(.data + .bss + .noinit)
Finished building: sizedummy
11:19:26 Build Finished (took 1s.29ms)
Post by: Jantje on Jul 09, 2013, 09:15 am
I meant the console output from the upload.
Post by: Asvaldr on Jul 09, 2013, 09:26 am
Upon clicking the AVR button, the error pop up is immediate and there is not console print what so ever.. which is odd i suppose.
I use the console window option to see both the CDT global and CDT build console prints and they are blank.
Post by: Asvaldr on Jul 09, 2013, 09:48 am
Just got a hold of a UNO. It does the same thing.......
Something is wrong obviously. I found an option to output AVR dude to the console and when trying to to do the UNO, the console prints
Launching D:\Programs\arduino-1.0.5\hardware\tools\avr\bin\avrdude -p?
Output:
avrdude: can't open config file "": Invalid argument
avrdude: error reading system wide configuration file ""
avrdude execution aborted
Post by: Asvaldr on Jul 09, 2013, 10:03 am
SOLUTION
Got it, from looking at that console output; i noticed that the AVR Dude setttings under Preferences/Arduino/AVR were not set.
So i manually set them to whats shown in the image. I pointed to an avrdude.conf i found by using windows search.
My understanding of the Arduino instructions and FAQ gave me the impression that clicking "Use Arduino IDE Tools in eclipse" did this sort of thing.. was i wrong or a bug in the plugin?
NOTE i'd also rolled back to the Arduino plugin 1.2.4 though this isn;t the reason i fixed it.
Thank you both Jantje and THX_RoG for taking the time to help me out.
Title: Re: [SOLVED] AVRDude Not supporting Mega2560 (Eclipse Arduino Plugin)
Post by: Jantje on Jul 09, 2013, 12:46 pm
"Use Arduino IDE Tools in eclipse" should set those. If it didn't this is a bug.
Jantje
Post by: Asvaldr on Jul 10, 2013, 01:50 am
if there is any other info you need, just let me know.
Post by: Jantje on Jul 10, 2013, 10:16 pm
If you have steps to reproduce :-)
Post by: Asvaldr on Jul 14, 2013, 10:57 pm
I found that when setting up the plug in that if I set all the preferences in one go then it wouldn't work.
But if I set the paths only, then applied changes, then exited preferences, then reopened preferences and St The use arduino ide setting... It would then work.
Also note all my earlier attempts and these ones were all done on fresh Eclipse installs.
Also your plug in works on kepler eclipse.
Thabk you for making such a plugin.
Post by: Jantje on Jul 15, 2013, 12:29 am
In Version V1 there is indeed inconsistency's when changing preference settings. These are fixed in V2 beta (Arduino IDE 1.5.2 beta only)
Best regards
Jantje
Post by: tcbetka on Jul 28, 2013, 08:17 pm
Could someone familiar with using AVRDude from Eclipse please post the details from their programmer specifications page for the Mega2560? I am not using the plugin, but I do have Eclipse working for the Uno...I just cannot seem to get it to upload for the Mega. I got the settings from the boards.txt file, but even with those the upload fails. There is indeed an error window that pops up for about 100ms, but it's gone way too fast to get any idea what the issue is. Then when I try to go back into the project's preferences to edit the programmer preferences, I get a message to the effect of
The currently displayed page contains invalid values.
This generally appears when I select the AVR > AVRDude menu option there in the lefthand page. However there's really no indication as to which values(s) is(are) invalid...
So if someone could share the settings they've gotten to work with AVRDude and the Mega2560, I would greatly appreciate it.
Thanks in advance.
TB
