Arduino Forum
Products => Arduino Esplora => Topic started by: coda87 on Jul 15, 2013, 05:04 am
Title: getting avrdude error when uploading sketches
Post by: coda87 on Jul 15, 2013, 05:04 am
whenever i try to upload a sketch, i get this error:
avrdude: error: buffered memory access not supported. maybe it isn't a butterfly/AVR109 but a AVR910 device?
i just got the Esplora and even the esplorablink wont work
Title: Re: getting avrdude error when uploading sketches
Post by: TheKitty on Jul 16, 2013, 05:50 pm
Ensure you follow the steps at http://arduino.cc/en/Guide/ArduinoEsplora to include using the latest non-1.5.x IDE version (1.0.5 as of today) and selecting Esplora as the target board in the IDE.
Post by: coda87 on Jul 26, 2013, 05:26 am
thanks! just a quick question, how do you do this? i cant get anything to work with the new drivers
Post by: StevenHoogslag on Dec 08, 2013, 04:20 pm
Esplora an Leonardo are programmable through USB port directly. They can also function as a human Interface device when connected. They seem prone to receive 2 com ports which makes it a little bit more difficult to target them on the correct serial port.
After several errors on a Windows Vista notebook I swapped to another usb connection port which solved the problem there. Give it some time as drivers may re-install themselves on the back ground.
Board type should be set correctly to Leonardo / Esplora. Programmer type is USBasp.
Post by: OlawaleJegede on Jan 15, 2014, 06:40 am
Hello,
I also encountered this error while uploading the Esplora Temperature Sensor example:
"Binary sketch size: 6,472 bytes (of a 28,672 byte maximum)
Found programmer: Id = "B«f"; type = "
Software Version = . ; Hardware Version = .
avrdude: error: buffered memory access not supported. Maybe it isn't a butterfly/AVR109 but a AVR910 device?"
What could the problem be and how can I correct this?
I also noticed that the Serial Monitor closes as soon as I start to upload the program.
How can I correct this?
Also I want to know does the board already have an inbuilt temperature sensor, or do I have to connect a physical temperature sensor for the program to work?
Thank you.
David.
Post by: TheKitty on Jan 17, 2014, 02:59 am
Make sure in Programmer -> Tools you have the first one checked.  Make sure you have a good USB cable.
