Arduino Forum
Community => Exhibition / Gallery => Topic started by: wildview on Sep 10, 2013, 12:31 am
Title: Arduino Geophone Application
Post by: wildview on Sep 10, 2013, 12:31 am
For those interested in attaching a Geophone to an Arduino board. Here is an example w/ an op-amp circuit. I used a breadboard shield and an amplifier circuit for my Geophone test application. The circuit allows you to set an offset so the Geophone output will always be positive for the Arduino analog input. I set the voltage offset to around 2.5V so the analog input signal can transition +/- 2.5V from the offset. I'm actually going to solder the parts onto a proto shield and mount the shield on an Aurdiuno board with a wifi shield so I can monitor movement from a remote location =)
Have fun.
Title: Re: Arduino Geophone Application
Post by: masalinas on Jun 27, 2016, 02:56 pm
Hello,
  Thanks for the circuit, but do you have a schema with fritzing for example, because I don't understand so well the IC741 from R1, R2 and Rg in the diagram.
Regards
Post by: Abhinav580 on Feb 21, 2018, 07:42 pm
Sir/Madam , please give me the detailed circuit diagram of using geophone with arduino
Post by: acesped on Apr 16, 2018, 07:28 pm
A basic question...
Why geophone should not be connected directly to Arduino?
