Arduino Forum
Using Arduino => LEDs and Multiplexing => Topic started by: tolisn63 on Dec 30, 2013, 06:01 pm
Title: display time on MAX7219 base matrix display ???
Post by: tolisn63 on Dec 30, 2013, 06:01 pm
Hi
I'm trying to get a dox matrix that uses 6 matrix displays driven by MAX7219 chips to display the time.
My setup also includes an RTC based on PCF 8563. Everything is connected to an arduino Mega 2560.
So far I got the matrix to display a 3 line string of characters and the RTC time displayed in the serial monitor.
Can someone help so I can display the time on the matrix display ?
The code is below and is based on parola library and a code for the RTC that I found online.
// Program to demonstrate the MD_Parola library
// For every string defined by pc[] iterate through all combinations
// of entry and exit effects.
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <Wire.h>
#include <Rtc_Pcf8563.h>
//init the real time clock
Rtc_Pcf8563 rtc;
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define MAX_DEVICES 6
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// set to 1 if we are implementing the user interface pot
#define USE_UI_CONTROL 0
#if USE_UI_CONTROL
#define SPEED_IN A0
#endif // USE_UI_CONTROL
#define PAUSE_TIME 1000
#define SPEED_DEADBAND 5
uint8_t frameDelay = 25; // default frame delay value
MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
#define SPEED_TIME 10
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
// Global variables
uint8_t  curText;
char *pc[] =
 "This is",
 "Just a",
 "Test",
uint8_t  inFX, outFX;
MD_Parola::textEffect_t effect[] =
 MD_Parola::PRINT,
 MD_Parola::SCROLL_LEFT,
 MD_Parola::WIPE,
 MD_Parola::SCROLL_UP,
 MD_Parola::OPENING_CURSOR,
 MD_Parola::BLINDS,
 MD_Parola::CLOSING,
 MD_Parola::WIPE_CURSOR,
 MD_Parola::DISSOLVE,
 MD_Parola::OPENING,
 MD_Parola::CLOSING_CURSOR,
 MD_Parola::SCROLL_RIGHT,
 MD_Parola::SCROLL_DOWN,
 MD_Parola::SLICE,
void setup(void)
 Serial.begin(57600);
 //clear out the registers
 //rtc.initClock();
 //set a time to start with.
 //day, weekday, month, century(1=1900, 0=2000), year(0-99)
 // uncomment to set
 //rtc.setDate(30, 1, 12, 0, 13);
 //hr, min, sec
 //uncomment to set
 //rtc.setTime(18, 42, 0);
 P.begin();
 P.setInvert(false);
 P.displayText(pc[curText], MD_Parola::CENTER, SPEED_TIME, PAUSE_TIME, effect[inFX], effect[outFX]);
void loop(void)
   Serial.print(rtc.formatTime());
   Serial.print("\r\n");
 if (P.displayAnimate()) // animates and returns true when an animation is completed
   // Set the display for the next string.
   curText = (++curText) % ARRAY_SIZE(pc);
   P.setTextBuffer(pc[curText]);
   // When we have gone back to the first string, set a new exit effect
   // and when we have done all those set a new entry effect.
   if (curText == 0)
     outFX = (++outFX) % ARRAY_SIZE(effect);
     if (outFX == 0)
       inFX = (++inFX) % ARRAY_SIZE(effect);
if (inFX == 0)
P.setInvert(!P.getInvert());
     P.setTextEffect(effect[inFX], effect[outFX]);
   // Tell Parola we have a new animation
   P.displayReset();
Title: Re: display time on MAX7219 base matrix display ???
Post by: marco_c on Dec 30, 2013, 08:46 pm
The code you have there is from the demo to show the different text effects, so you will get a whole lot of different in and out text. I am assuming that you managed to get the display of the test message working ok?
This only just displays the date & time to the serial monitor (why didn't you use Serial.println(), by the way?)
You actually need to strcpy() the date and time to a character buffer (array of characters) and then pass that to the Parola library for display, instead of the test message. The rest should work ok.
You may want to consider showing the date on one pass of the display and the time on the next display (like the test code shows the sentence split up).
Post by: tolisn63 on Dec 30, 2013, 08:58 pm
Hi Marco
Can you help me out on this, my coding skills are very limited ?
Post by: marco_c on Dec 30, 2013, 09:13 pm
I don't have your RTC library and have not compiled tested this code, but it should display whatever was in the serial printout.
// Display current date and time using Parola library
#include <Wire.h>
Rtc_Pcf8563 rtc;
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
#if USE_UI_CONTROL
#define SPEED_IN A0
// Global variables
char szDateTime[20] = {""};
  MD_Parola::PRINT,
  MD_Parola::WIPE,
  MD_Parola::BLINDS,
  MD_Parola::CLOSING,
  MD_Parola::OPENING,
  MD_Parola::SLICE,
void setup(void)
  //rtc.initClock();
  // uncomment to set
  //hr, min, sec
  //uncomment to set
  P.begin();
  P.setInvert(false);
  P.displayText(szDateTime, MD_Parola::CENTER, SPEED_TIME, PAUSE_TIME, effect[inFX], effect[outFX]);
void loop(void)
  strcpy(szDateTime, rtc.formatTime());
   P.setTextBuffer(szDateTime);
    if (outFX == 0)
      if (inFX == 0)
    P.displayReset();
Post by: tolisn63 on Dec 30, 2013, 09:59 pm
Marco, your example works ok but it only shows the time. Is there any way to show text and then the time and then again the text ?
Post by: marco_c on Dec 30, 2013, 10:00 pm
Sure there is. What exactly are you trying to achieve?
Post by: tolisn63 on Dec 30, 2013, 10:32 pm
Im trying to acheive the following.
Type in a required text,then the matrix shows the text. When the text is finished, the time is shown.when the time is finished the text is shown again and the cycle repeats.
Post by: marco_c on Dec 30, 2013, 11:02 pm
Same caveats as before.
// Display text on the matrix followed by the time and the cycle repeats.
#include <Wire.h>
Rtc_Pcf8563 rtc;
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
#if USE_UI_CONTROL
#define SPEED_IN A0
// Global variables
uint8_t  curText;
char  szDateTime[20];
char *pc[] =
  "This is",
  "Just a",
  "Test",
  szDateTime,
  MD_Parola::PRINT,
  MD_Parola::WIPE,
  MD_Parola::BLINDS,
  MD_Parola::CLOSING,
  MD_Parola::OPENING,
  MD_Parola::SLICE,
void setup(void)
  //rtc.initClock();
  // uncomment to set
  //hr, min, sec
  //uncomment to set
  P.begin();
  P.setInvert(false);
void loop(void)
    if (curText == 0)
      if (outFX == 0)
if (inFX == 0)
    P.displayReset();
Post by: tolisn63 on Dec 31, 2013, 12:23 am
Now it is working as required. Thanks for your help, much appreciated.
As a next step, I will try to add bluetooth input to add the text.
Post by: marco_c on Dec 31, 2013, 12:54 am
When you do that you will need to change the strings from constants to character arrays, like for the datetime.
Good luck.
Post by: tolisn63 on Jan 02, 2014, 02:44 pm
Here is a new code that shows the time, date and reads the serial input so it can print a message. The problem is that the message is too long and cannot be displayed on the matrix. Only a part of it is displayed.
How do I go about showing all the message ?
#include <Wire.h>
Rtc_Pcf8563 rtc;
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
#if USE_UI_CONTROL
#define SPEED_IN A0
// Global message buffers shared by Serial and Scrolling functions
#define BUF_SIZE 75
char curMessage[BUF_SIZE];
char newMessage[BUF_SIZE];
bool newMessageAvailable = false;
void readSerial(void)
static uint8_t putIndex = 0;
while (Serial1.available())
newMessage[putIndex] = (char)Serial1.read();
if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE-3)) // end of message character or full buffer
// put in a message separator and end the string
newMessage[putIndex++] = ' ';
newMessage[putIndex] = '\0';
// restart the index for next filling spree and flag we have a message waiting
putIndex = 0;
                       strcpy(curMessage, newMessage); // copy it in
// Just save the next char in next location
newMessage[putIndex++];
// Global variables
uint8_t  curText;
char  szTime[9];
char  szDate[11];
char  szYear[5];
char *pc[] =
 "The Time",
 "is",
 szTime,
 "The Date",
 "is",
 szDate,
 szYear,
 curMessage,
 MD_Parola::PRINT,
 MD_Parola::WIPE,
 MD_Parola::BLINDS,
 MD_Parola::CLOSING,
 MD_Parola::OPENING,
 MD_Parola::SLICE,
void setup(void)
 Serial1.begin(9600); //bluesmirf default baud rate=9600
 //rtc.initClock();
 // uncomment to set
 //rtc.setDate(2, 3, 1, 0, 14);
 //hr, min, sec
 //uncomment to set
 //rtc.setTime(13, 35, 0);
 P.begin();
 P.setInvert(false);
void loop(void)
  readSerial(); // read serial input
   strcpy(szTime, rtc.formatTime()); //gets the complete time and stores the complete time in format 23:30:54
   strncpy(szDate, rtc.formatDate(RTCC_DATE_WORLD),5); //Gets the complete date in the format 15/12/2013 and stores only
   //the day and date in the format 15/12
   strncpy(szYear,&rtc.formatDate(RTCC_DATE_WORLD)[6],4); //Gets the complete date in the format 15/12/2013
   //and stores only the year in the format 2014
   if (curText == 0)
     if (outFX == 0)
if (inFX == 0)
P.setInvert(false);
   P.displayReset();
Post by: marco_c on Jan 02, 2014, 08:43 pm
The software can scroll the message onto the screen so someone looking can read it. If that is not good enough then get a bigger matrix or make shorter messages.
Post by: tolisn63 on Jan 02, 2014, 09:12 pm
As the code is now, If I type in a message "Hello Arduino" all I can see is a message "Hello Ard". The rest is cut. When the message scrolls not all the message is shown but only "Hello Ard"
Post by: marco_c on Jan 02, 2014, 09:32 pm
1. Check (by printing) that the message is what you think it is.
2. Set the animation to just scrolling and see if the message appears.
You are either cutting off the message in the buffer or you are not displaying the whole thing. No other possibilities that I can see.
Post by: tolisn63 on Jan 26, 2014, 01:19 pm
Hi
I have add some code to the sketch that uses a I2C temperature sensor to read the temperature.
The code as it it shows the temperature using the serial monitor.
How can I send the temperature reading to the matrix ?
#include <Wire.h>
Rtc_Pcf8563 rtc;
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
#if USE_UI_CONTROL
#define SPEED_IN A0
#define BUF_SIZE 100
int tmpAddress = B1001000;
int ResolutionBits = 10;
      putIndex = 0;
// Global variables
uint8_t  curText;
char  szTime[9];
char  szDate[11];
char  szYear[5];
char *pc[] =
  "The Time",
  "is",
  szTime,
  "The Date",
  "is",
  szDate,
  szYear,
  curMessage,
  //  MD_Parola::PRINT,
  //  MD_Parola::WIPE,
  //  MD_Parola::SCROLL_UP,
  //  MD_Parola::OPENING_CURSOR,
  //  MD_Parola::BLINDS,
  //  MD_Parola::CLOSING,
  //  MD_Parola::WIPE_CURSOR,
  //  MD_Parola::DISSOLVE,
  //  MD_Parola::OPENING,
  //  MD_Parola::CLOSING_CURSOR,
  //  MD_Parola::SCROLL_RIGHT,
  //  MD_Parola::SCROLL_DOWN,
  //  MD_Parola::SLICE,
float getTemperature(){
  Wire.requestFrom(tmpAddress,2);
  byte MSB = Wire.read();
  byte LSB = Wire.read();
  int TemperatureSum = ((MSB << 8) | LSB) >> 4;
  float celsius = TemperatureSum*0.0625;
  Serial.print("Celsius: ");
  Serial.println(celsius);
void SetResolution(){
  if (ResolutionBits < 9 || ResolutionBits > 12) exit;
  Wire.beginTransmission(tmpAddress);
  Wire.write(B00000001); //addresses the configuration register
  Wire.write((ResolutionBits-9) << 5); //writes the resolution bits
  Wire.endTransmission();
  Wire.beginTransmission(tmpAddress); //resets to reading the temperature
  Wire.write((byte)0x00);
void setup(void)
  SetResolution();
  //rtc.initClock();
  // uncomment to set
  //hr, min, sec
  //uncomment to set
  P.begin();
  P.setInvert(false);
void loop(void)
  getTemperature();
    if (curText == 0)
      if (outFX == 0)
        if (inFX == 0)
          P.setInvert(false);
    P.displayReset();
Post by: marco_c on Jan 26, 2014, 07:46 pm
The temperature needs to be converted to a string of characters (look up how to use the sprintf() function) and then that string given to the Parola library to display.
Post by: tolisn63 on Jan 27, 2014, 06:37 pm
I tried using the sprintf() function but I always get "?" printed so I used the dtostrf() function.
Below is the complete code that works now.
#include <Wire.h>
Rtc_Pcf8563 rtc;
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
#if USE_UI_CONTROL
#define SPEED_IN A0
      putIndex = 0;
// Global variables
uint8_t  curText;
char  szTime[9];
char  szDate[11];
char  szYear[5];
char tmp100[6];
char *pc[] =
  "The Time",
  "is",
  szTime,
  "The Date",
  "is",
  szDate,
  szYear,
  "The Temp",
  "is",
  tmp100,
  curMessage,
  //  MD_Parola::WIPE,
//sprintf(tmp100,"%f",celsius);
dtostrf(celsius,4,1,tmp100);
void setup(void)
  SetResolution();
  //rtc.initClock();
  // uncomment to set
  //hr, min, sec
  //uncomment to set
  P.begin();
  P.setInvert(false);
void loop(void)
  getTemperature();
    if (curText == 0)
      if (outFX == 0)
        if (inFX == 0)
          P.setInvert(false);
    P.displayReset();
