I am using a DS3231 and would like to use the integral temperature monitor. Unfortunately, the code I have been able to scrape together will not negotiate temperatures below freezing, returning a value of "127" at freezing. Since this will be used as an outdoor temperature monitor, I really would need this capability. I have read that this is easily resolved by using a 2's complement solution and adding a 1 to the result when the most significant data bit is 1111. Newbie that I am, I cannot for the life of me get any of the suggested methods to work. I've posted the code without the 2's complement (or rather insult) below. Can anyone suggest a '2s complement solution for this?
#include <Wire.h>
#define DS3231_I2C_ADDRESS 104
byte seconds, minutes, hours, day, date, month, year;
char weekDay[4];
byte tMSB, tLSB;
float temp3231;
Wire.begin();
watchConsole();
get3231Date();
Serial.print(weekDay); Serial.print(", "); Serial.print(month, DEC); Serial.print("/"); Serial.print(date, DEC); Serial.print("/20"); Serial.print(year, DEC); Serial.print(" - ");
Serial.print(hours, DEC); Serial.print(":"); Serial.print(minutes, DEC); Serial.print(":"); Serial.print(seconds, DEC);
Serial.print(" - Temp: "); Serial.println(get3231Temp());
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
void watchConsole()
if (Serial.available()) { // Look for char in serial queue and process if found
if (Serial.read() == 84) { //If command = "T" Set Date
set3231Date();
get3231Date();
Serial.println(" ");
void set3231Date()
//T(sec)(min)(hour)(dayOfWeek)(dayOfMonth)(month)(year)
//T(00-59)(00-59)(00-23)(1-7)(01-31)(01-12)(00-99)T0042061310111
//Example: 02-Feb-09 @ 19:57:11 for the 3rd day of the week -> T1157193020209
seconds = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48)); // Use of (byte) type casting and ascii math to achieve result.
minutes = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
hours = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
day = (byte) (Serial.read() - 48);
date = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
month = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
year = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.send(0x00);
Wire.send(decToBcd(seconds));
Wire.send(decToBcd(minutes));
Wire.send(decToBcd(hours));
Wire.send(decToBcd(day));
Wire.send(decToBcd(date));
Wire.send(decToBcd(month));
Wire.send(decToBcd(year));
Wire.endTransmission();
void get3231Date()
// send request to receive data starting at register 0
Wire.beginTransmission(DS3231_I2C_ADDRESS); // 104 is DS3231 device address
Wire.send(0x00); // start at register 0
Wire.requestFrom(DS3231_I2C_ADDRESS, 7); // request seven bytes
if(Wire.available()) {
seconds = Wire.receive(); // get seconds
minutes = Wire.receive(); // get minutes
hours = Wire.receive(); // get hours
day = Wire.receive();
date = Wire.receive();
month = Wire.receive(); //temp month
year = Wire.receive();
seconds = (((seconds & B11110000)>>4)*10 + (seconds & B00001111)); // convert BCD to decimal
minutes = (((minutes & B11110000)>>4)*10 + (minutes & B00001111)); // convert BCD to decimal
hours = (((hours & B00110000)>>4)*10 + (hours & B00001111)); // convert BCD to decimal (assume 24 hour mode)
day = (day & B00000111); // 1-7
date = (((date & B00110000)>>4)*10 + (date & B00001111)); // 1-31
month = (((month & B00010000)>>4)*10 + (month & B00001111)); //msb7 is century overflow
year = (((year & B11110000)>>4)*10 + (year & B00001111));
else {
//oh noes, no data!
switch (day) {
case 1:
strcpy(weekDay, "Sun");
break;
case 2:
strcpy(weekDay, "Mon");
break;
case 3:
strcpy(weekDay, "Tue");
break;
case 4:
strcpy(weekDay, "Wed");
break;
case 5:
strcpy(weekDay, "Thu");
break;
case 6:
strcpy(weekDay, "Fri");
break;
case 7:
strcpy(weekDay, "Sat");
break;
float get3231Temp()
//temp registers (11h-12h) get updated automatically every 64s
Wire.send(0x11);
Wire.requestFrom(DS3231_I2C_ADDRESS, 2);
tMSB = Wire.receive(); //2's complement int portion
tLSB = Wire.receive(); //fraction portion
temp3231 = (tMSB & B01111111); //do 2's math on Tmsb
temp3231 += ( (tLSB >> 6) * 0.25 ); //only care about bits 7 & 8
temp3231 = (temp3231 * 1.8) + 32.0; // Convert Celcius to Fahrenheit
return temp3231;
else {
//oh noes, no data!
return temp3231;
