Arduino Forum
Using Arduino => Interfacing w/ Software on the Computer => Topic started by: ariesking on Mar 29, 2014, 05:36 pm
Title: PROCESSING + ARDUINO
Post by: ariesking on Mar 29, 2014, 05:36 pm
Hi everyone,
can you guide for me the way to create 2 line segments (joint together) on processing.
Each segment simulate for 1 sensor as the figure below.
thanks!
Title: Re: CREATE SEGMENT ON PROCESSING
Post by: PaulS on Mar 29, 2014, 05:42 pm
can you guide for me the way to create 2 line segments (joint together) .
I don't think the Arduino is capable of creating line segments. Processing has it's own forum (and a shitload of examples).
Post by: ariesking on Mar 29, 2014, 05:51 pm
i also ask on processing forrum but i see they don't have enthusiasm as arduino forum.
i thinh arduino and processing be alway together in transfer data  to diisplay and in this forum: someone will have many experience about processing.
So, i decide ask in this forum.
hope that someone can help me.
Post by: PaulS on Mar 29, 2014, 06:11 pm
Where is your code, and what have you tried? Drawing a line is trivial.
Post by: ariesking on Mar 29, 2014, 06:20 pm
i haven't writen code because i don't know how to draw it.
i wanna send data from sensor to '' segment'' on processing to simulate it as figure i attach .
could you guide for me?
Post by: PaulS on Mar 29, 2014, 06:35 pm
    line(x1, y1, x2, y2);
All you need to do is supply values for x1, y1, x2 and y2.
What sensor?
Post by: ariesking on Mar 29, 2014, 06:40 pm
i wanna joint 2 lines, not 1 line.
each line is (GY -521 + GY271)
Post by: PaulS on Mar 29, 2014, 06:52 pm
So, go right ahead. Call the function twice.
Post by: ariesking on Mar 29, 2014, 06:58 pm
i don'n understand.
Post by: PaulS on Mar 29, 2014, 07:57 pm
Put this in draw() and see what it does.
int x1=0;
int y1 = 0;
int x2 = 2;
int y2 = 2;
int x3 = 5;
int y3 = 2;
line(x2, y2, x3, y3);
Two calls to line()!
Post by: ariesking on Apr 12, 2014, 10:39 am
int x1=0;
int y1 = 0;
int x2 = 2;
int y2 = 2;
int x3 = 5;
int y3 = 2;
I don't know how to send data ( euler angle) from arduino to sengment on processing.
please tell me.
Title: Re: SEGMENT ON PROCESSING + ARDUINO
Post by: PaulS on Apr 12, 2014, 05:39 pm
Then this project is not for you.
Post by: ariesking on Apr 15, 2014, 04:20 pm
After i can read the pitch, roll, yaw from arduino code
i try  to run processing code :
But it have some mistake:
error, disabling serialEvent() for //./COM4
java.lang.reflect.InvocationTargetException
   at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
   at java.lang.reflect.Method.invoke(Method.java:597)
   at processing.serial.Serial.serialEvent(Unknown Source)
   at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
   at gnu.io.RXTXPort.eventLoop(Native Method)
   at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 1
   at ds.serialEvent(ds.java:105)
   ... 8 more
Could you guide me to repair it?
Title: Re: PROCESSING + ARDUINO
Post by: PaulS on Apr 15, 2014, 09:29 pm
float stringKalmanX, stringKalmanY,stringKalmanZ;
This was as far as I read. If the variable IS a float, get rid of string from the name. These names look stupid, which reflects on you!
   println(Serial.list()); // Use this to print connected serial devices
What did this show? Is your Arduino really connected to the second port in the list?
Post by: ariesking on Apr 16, 2014, 06:38 am
It is a variable name, so it doesn't effect.. When it is: String stringKalmanX, stringKalmanY,stringKalmanZ;>>> error>> so, i change it to float but i forgot change the name of it from stringkalman to  kalman
here is code to draw a plane but it shows a black table.
i'm sure it is connected to COM which i setup.
Post by: ariesking on Apr 16, 2014, 09:53 am
import processing.serial.*;
Serial myPort;
float [] hq = null;
float [] kalman = new float [3]; // psi, theta, phi
byte[] inBuffer = new byte[22]; // this is the number of chars on each line from the Arduino (including /r/n)
PFont font;
//final int VIEW_SIZE_X = 1024, VIEW_SIZE_Y = 768;
final int VIEW_SIZE_X = 800, VIEW_SIZE_Y = 600;
  size(VIEW_SIZE_X, VIEW_SIZE_Y, P3D);
  textureMode(NORMAL);
  fill(255);
  stroke(color(44,48,32));
  myPort = new Serial(this, Serial.list()[1], 115200);
  myPort.bufferUntil('\n'); // Buffer until line fee d
  // The font must be located in the sketch's "data" directory to load successfully
  font = loadFont("CourierNew36.vlw");
  // Loading the textures to the cube
  // The png files alow to put the board holes so can increase  realism
  delay(100);
  myPort.clear();
  myPort.write("1");
float decodeFloat(String inString) {
  byte [] inData = new byte[3];
  if(inString.length() == 8) {
    inData[0] = (byte) unhex(inString.substring(0, 2));
    inData[1] = (byte) unhex(inString.substring(2, 4));
    inData[2] = (byte) unhex(inString.substring(4, 6));
  int intbits = (inData[2] << 16) | ((inData[1] & 0xff) << 8) | ((inData[0] & 0xff) );
  return Float.intBitsToFloat(intbits);
void readQ() {
  if(myPort.available() >= 18) {
    String inputString = myPort.readStringUntil('\n');
    //print(inputString);
    if (inputString != null && inputString.length() > 0) {
      String [] inputStringArr = split(inputString, ",");
      if(inputStringArr.length >= 4) {
        kalman[0] = decodeFloat(inputStringArr[0]);
        kalman[1] = decodeFloat(inputStringArr[1]);
        kalman[2] = decodeFloat(inputStringArr[2]);
void buildBoxShape() {
  //box(60, 10, 40);
  noStroke();
  beginShape(QUADS);
  //Z+ (to the drawing area)
  fill(#00ff00);
  vertex(-30, -5, 20);
  vertex(30, -5, 20);
  vertex(30, 5, 20);
  vertex(-30, 5, 20);
  //Z-
  fill(#0000ff);
  vertex(-30, -5, -20);
  vertex(30, -5, -20);
  vertex(30, 5, -20);
  vertex(-30, 5, -20);
  //X-
  fill(#ff0000);
  vertex(-30, 5, 20);
  //X+
  fill(#ffff00);
  vertex(30, -5, 20);
  vertex(30, 5, 20);
  vertex(30, 5, -20);
  //Y-
  fill(#ff00ff);
  vertex(30, -5, 20);
  //Y+
  fill(#00ffff);
  vertex(30, 5, -20);
  vertex(30, 5, 20);
  vertex(-30, 5, 20);
  endShape();
void drawCube() {
  pushMatrix();
    translate(VIEW_SIZE_X/2, VIEW_SIZE_Y/2 + 50, 0);
    scale(5,5,5);
    // a demonstration of the following is at
    // http://www.varesano.net/blog/fabio/ahrs-sensor-fusion-orientation-filter-3d-graphical-rotating-cube
    rotateZ(-kalman[2]);
    rotateX(-kalman[1]);
    rotateY(-kalman[0]);
    buildBoxShape();
  popMatrix();
void draw() {
  background(#000000);
  fill(#ffffff);
  readQ();
  if(hq != null) { // use home quaternion
    text(" ", 20, VIEW_SIZE_Y - 30);
  else {
  textFont(font, 20);
  textAlign(LEFT, TOP);
  text("kalman Angles:\nYaw (psi)  : " + degrees(kalman[0]) + "\nPitch (theta): " + degrees(kalman[1]) + "\nRoll (phi)  : " + degrees(kalman[2]), 200, 20);
  drawCube();
I modify code on internet and try apply for my project but when i move sensor > >> my processing doésn't change.
Post by: Grumpy_Mike on Apr 16, 2014, 10:28 am
See that commented out print statement in the readQ function. Un comment it an see if anything is being recieved from your arduino.
You. Eed to post your arduino code as well.
Post by: ariesking on Apr 16, 2014, 10:46 am
here is  arduino code
#include <Wire.h>
#include "Kalman.h"
#define RESTRICT_PITCH // Comment out to restrict roll to ±90deg instead - please read: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf
Kalman kalmanX, kalmanY, kalmanZ; // Create the Kalman instances
const uint8_t MPU6050 = 0x68; // If AD0 is logic low on the PCB the address is 0x68, otherwise set this to 0x69
const uint8_t HMC5883L = 0x1E; // Address of magnetometer
/* IMU Data */
double accX, accY, accZ;
double gyroX, gyroY, gyroZ;
double magX, magY, magZ;
int16_t tempRaw;
double roll, pitch, yaw; // Roll and pitch are calculated using the accelerometer while yaw is calculated using the magnetometer
double gyroXangle, gyroYangle, gyroZangle; // Angle calculate using the gyro only
double compAngleX, compAngleY, compAngleZ; // Calculated angle using a complementary filter
double kalAngleX, kalAngleY, kalAngleZ; // Calculated angle using a Kalman filter
uint32_t timer;
uint8_t i2cData[14]; // Buffer for I2C data
// TODO: Lav zero rutine til accelerometer, magnetomer og gyroscope
#define MAG0MAX 603
#define MAG0MIN -578
#define MAG1MAX 542
#define MAG1MIN -701
#define MAG2MAX 547
#define MAG2MIN -556
float magOffset[3] = { (MAG0MAX + MAG0MIN) / 2, (MAG1MAX + MAG1MIN) / 2, (MAG2MAX + MAG2MIN) / 2 };
double magGain[3];
 delay(100); // Wait for sensors to get ready
 Wire.begin();
 TWBR = ((F_CPU / 400000L) - 16) / 2; // Set I2C frequency to 400kHz
 i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
 i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
 i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s
 i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g
 while (i2cWrite(MPU6050, 0x19, i2cData, 4, false)); // Write to all four registers at once
 while (i2cWrite(MPU6050, 0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode
 while (i2cRead(MPU6050, 0x75, i2cData, 1));
 if (i2cData[0] != 0x68) { // Read "WHO_AM_I" register
   Serial.print(F("Error reading sensor"));
   while (1);
 while (i2cWrite(HMC5883L, 0x02, 0x00, true)); // Configure device for continuous mode
 // TODO: Sæt sample rate
 delay(100); // Wait for sensors to stabilize
 /* Set Kalman and gyro starting angle */
 updateMPU6050();
 updateHMC5883L();
 updatePitchRoll();
 updateYaw();
 kalmanX.setAngle(roll); // First set roll starting angle
 gyroXangle = roll;
 compAngleX = roll;
 kalmanY.setAngle(pitch); // Then pitch
 gyroYangle = pitch;
 compAngleY = pitch;
 kalmanZ.setAngle(yaw); // And finally yaw
 gyroZangle = yaw;
 compAngleZ = yaw;
 timer = micros(); // Initialize the timer
 /* Update all the IMU values */
 updateMPU6050();
 updateHMC5883L();
 double dt = (double)(micros() - timer) / 1000000; // Calculate delta time
 timer = micros();
 /* Roll and pitch estimation */
 updatePitchRoll();
 double gyroXrate = gyroX / 131.0; // Convert to deg/s
 double gyroYrate = gyroY / 131.0; // Convert to deg/s
#ifdef RESTRICT_PITCH
 // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees
 if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {
   compAngleX = roll;
   kalAngleX = roll;
   gyroXangle = roll;
 } else
   kalAngleX = kalmanX.getAngle(roll, gyroXrate, dt); // Calculate the angle using a Kalman filter
 if (abs(kalAngleX) > 90)
   gyroYrate = -gyroYrate; // Invert rate, so it fits the restricted accelerometer reading
 kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt);
#else
 if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {
   compAngleY = pitch;
   kalAngleY = pitch;
   gyroYangle = pitch;
 } else
   kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt); // Calculate the angle using a Kalman filter
 if (abs(kalAngleY) > 90)
   gyroXrate = -gyroXrate; // Invert rate, so it fits the restricted accelerometer reading
#endif
 /* Yaw estimation */
 updateYaw();
 double gyroZrate = gyroZ / 131.0; // Convert to deg/s
 // This fixes the transition problem when the yaw angle jumps between -180 and 180 degrees
 if ((yaw < -90 && kalAngleZ > 90) || (yaw > 90 && kalAngleZ < -90)) {
   compAngleZ = yaw;
   kalAngleZ = yaw;
   gyroZangle = yaw;
 } else
   kalAngleZ = kalmanZ.getAngle(yaw, gyroZrate, dt); // Calculate the angle using a Kalman filter
 /* Estimate angles using gyro only */
 gyroXangle += gyroXrate * dt; // Calculate gyro angle without any filter
 gyroYangle += gyroYrate * dt;
 gyroZangle += gyroZrate * dt;
 //gyroXangle += kalmanX.getRate() * dt; // Calculate gyro angle using the unbiased rate from the Kalman filter
 //gyroYangle += kalmanY.getRate() * dt;
 //gyroZangle += kalmanZ.getRate() * dt;
 /* Estimate angles using complimentary filter */
 compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter
 compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;
 compAngleZ = 0.93 * (compAngleZ + gyroZrate * dt) + 0.07 * yaw;
 // Reset the gyro angles when they has drifted too much
 if (gyroXangle < -180 || gyroXangle > 180)
   gyroXangle = kalAngleX;
 if (gyroYangle < -180 || gyroYangle > 180)
   gyroYangle = kalAngleY;
 if (gyroZangle < -180 || gyroZangle > 180)
   gyroZangle = kalAngleZ;
Serial.print(kalAngleX); Serial.print("\t");
  Serial.print(kalAngleY); Serial.print("\t");
 Serial.print(kalAngleZ); Serial.print("\t");
 delay(10);
void updateMPU6050() {
 while (i2cRead(MPU6050, 0x3B, i2cData, 14)); // Get accelerometer and gyroscope values
 accX = ((i2cData[0] << 8) | i2cData[1]);
 accY = -((i2cData[2] << 8) | i2cData[3]);
 accZ = ((i2cData[4] << 8) | i2cData[5]);
 tempRaw = (i2cData[6] << 8) | i2cData[7];
 gyroX = -(i2cData[8] << 8) | i2cData[9];
 gyroY = (i2cData[10] << 8) | i2cData[11];
 gyroZ = -(i2cData[12] << 8) | i2cData[13];
void updateHMC5883L() {
 while (i2cRead(HMC5883L, 0x03, i2cData, 6)); // Get magnetometer values
 magX = ((i2cData[0] << 8) | i2cData[1]);
 magZ = ((i2cData[2] << 8) | i2cData[3]);
 magY = ((i2cData[4] << 8) | i2cData[5]);
void updatePitchRoll() {
#ifdef RESTRICT_PITCH // Eq. 25 and 26
 roll = atan2(accY, accZ) * RAD_TO_DEG;
 pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG;
#else // Eq. 28 and 29
 roll = atan(accY / sqrt(accX * accX + accZ * accZ)) * RAD_TO_DEG;
 pitch = atan2(-accX, accZ) * RAD_TO_DEG;
#endif
void updateYaw() { /
 magX *= -1; // Invert axis - this it done here, as it should be done after the calibration
 magZ *= -1;
 magX *= magGain[0];
 magY *= magGain[1];
 magZ *= magGain[2];
 magX -= magOffset[0];
 magY -= magOffset[1];
 magZ -= magOffset[2];
 double rollAngle = kalAngleX * DEG_TO_RAD;
 double pitchAngle = kalAngleY * DEG_TO_RAD;
 double Bfy = magZ * sin(rollAngle) - magY * cos(rollAngle);
 double Bfx = magX * cos(pitchAngle) + magY * sin(pitchAngle) * sin(rollAngle) + magZ * sin(pitchAngle) * cos(rollAngle);
 yaw = atan2(-Bfy, Bfx) * RAD_TO_DEG;
 yaw *= -1;
Post by: PaulS on Apr 16, 2014, 11:51 am
On the Arduino end:
On the Processing end:
Since you never bother to send a carriage return or line feed, hell is going to freeze over before the serialEvent() method gets called.
Post by: ariesking on Apr 16, 2014, 12:18 pm
can you guide me repair it?
Post by: PaulS on Apr 16, 2014, 12:58 pm
You need to have the Arduino ACTUALLY send a line feed. You can see what you need to send in the Processing program.
The tab (\t) after the last value is useless. It should be a line feed (\n).
Post by: ariesking on Apr 16, 2014, 01:51 pm
Thank for your reply.
i repair it into :
Serial.print(kalAngleZ); Serial.print("\n");
and the result as my attach below:
But when run processing code: 3value I print on arduino not respond with on processing >> so, Object can't move.
Post by: PaulS on Apr 16, 2014, 02:06 pm
You are not trying to run Processing and the Serial Monitor at the same time, are you?
When you use the bufferUntil() method, Processing triggers the serialEvent() method when the appropriate character arrives for the specified port. Your readQ() method is useless
Post by: PaulS on Apr 16, 2014, 02:10 pm
Even if your readQ() method actually read anything, what it reads is strings. Your decodeFloat() function expects that the String passed in consists of 3 bytes of binary data. It does not, so that code is crap, too. Processing knows how to split a tab delimited String into an array of floats. Why don't you just let it? Your Processing code is far more complex (and wrong) than it needs to be.
Post by: ariesking on Apr 16, 2014, 03:13 pm
Serial myPort;
PFont font;
  fill(255);
  myPort.bufferUntil('\n'); // Buffer until line feed
  delay(100);
  myPort.clear();
  myPort.write("1");
void serialEvent (Serial myPort)
   stringKalmanX = myPort.readStringUntil('\t');
   stringKalmanY = myPort.readStringUntil('\t');
    stringKalmanZ = myPort.readStringUntil('\n');
  //box(60, 10, 40);
  noStroke();
  beginShape(QUADS);
  fill(#00ff00);
  vertex(30, -5, 20);
  vertex(30, 5, 20);
  vertex(-30, 5, 20);
  //Z-
  fill(#0000ff);
  vertex(30, 5, -20);
  //X-
  fill(#ff0000);
  vertex(-30, 5, 20);
  //X+
  fill(#ffff00);
  vertex(30, -5, 20);
  vertex(30, 5, 20);
  vertex(30, 5, -20);
  //Y-
  fill(#ff00ff);
  vertex(30, -5, 20);
  //Y+
  fill(#00ffff);
  vertex(30, 5, -20);
  vertex(30, 5, 20);
  vertex(-30, 5, 20);
  endShape();
void drawCube() {
  pushMatrix();
    scale(5,5,5);
    rotateZ(-stringKalmanX);
    rotateX(-stringKalmanY);
    rotateY(-stringKalmanZ);
    buildBoxShape();
  popMatrix();
final int minAngle = 0;
final int maxAngle = 180;
void convert() {
if (stringKalmanX != null) {
    // Trim off any whitespace:
    stringKalmanX = trim(stringKalmanX);
    // Convert to an float and map to the screen height, then save in buffer:
    kalmanX[kalmanX.length-1] = map(float(stringKalmanX), minAngle, maxAngle, 0);
  /* Convert the kalman filter y-axis */
  if (stringKalmanY != null) {
    stringKalmanY = trim(stringKalmanY);
    kalmanY[kalmanY.length-1] = map(float(stringKalmanY), minAngle, maxAngle, 0);
  if (stringKalmanZ != null) {
    stringKalmanZ = trim(stringKalmanZ);
    kalmanZ[kalmanZ.length-1] = map(float(stringKalmanZ), minAngle, maxAngle, 0);
void printAxis() {
  print(stringKalmanX);
  print('\t');
  print(stringKalmanY);
  print('\t');
  print(stringKalmanZ);
  println();
when i change as this. >>>>HAVE an error as my attach below.
Post by: PaulS on Apr 16, 2014, 04:39 pm
Why are you trying to negate a string?
Read the whole string in serialEvent, up to the \n. Then, use split to split the String, and float [] to make an array of floats of the pieces that the String gets split into.
