Arduino Forum
Using Arduino => General Electronics => Topic started by: tsunamy_boy on Apr 13, 2014, 06:49 pm
Title: [Solved]Measure a battery amps
Post by: tsunamy_boy on Apr 13, 2014, 06:49 pm
How can i get to know the maximum amps of a battery?
Is it possible to measure that with a multimeter or something?
Title: Re: Measure a battery amps
Post by: CrossRoads on Apr 13, 2014, 06:54 pm
You can measure the amps being drawn - put your meter in Amp mode, or mA mode for lower currents.
Red probe connects to + of battery, black probe to where the battery + would have gone, so your meter is in series with the current flow.
Start off in Amp mode.
Post by: retrolefty on Apr 13, 2014, 07:15 pm
While a simple question there is not a simple answer. The maximum current a battery can supply at a given terminal voltage mostly depends on it's built in internal resistance. This is a specification that most battery manufacture don't publish or make easily available, but if it's a 'name brand' battery you might be able to find a datasheet published somewhere.
Note that where this is a very important specification as in radio controlled electric motor powered aircraft or the such where current demand can be very high and total flight time is measured is mins rather then hours. A battery's total charge capacity is measured in amp/hours or millamp/hours, but that doesn't tell you the maximum current you can draw for a short time. The newer specification for max current draw is so called C rating as specified in some Li-Po cells where they might say it can support a 10C or 20C or even higher value. What that says is that a cell that is say rated as a 1 amp/hour can supply (for a very short time) 10 amps or 20 amps peak current. I've only seen those ratings on some Li-po cells, although auto 12volt batteries often give a short time high current capability as 'peak cranking amps' which is effectively the same kind of spec.
Don't know if that helps, and if you can give us more information about what you require in current demand, duration, and what specific battery you are considering maybe a better answer can surface.
Post by: tsunamy_boy on Apr 13, 2014, 08:12 pm
I did that and i just discharged a Lipo Battery completely (0v now)
Maybe i can't do that with lipo batteries.
It's a chinese (from ebay) nokia battery but it looks like it's not 750mA because when i charge it with my charger (TP4056 - with a resistor of 1.6k) the final voltage is 4.1v. But when i use the Nokia itself i get 4.2v.
I look up online and those Chinese batteries can stand more than one type of amps
Post by: CrossRoads on Apr 13, 2014, 08:17 pm
Charge control chips can be set to different voltage levels to finish at.
MAX1811 for instance, a pin high or low determines what level is used.
Post by: retrolefty on Apr 13, 2014, 08:19 pm
Correct and you most likely destroyed the battery cell. Li-po cells should never be allowed to discharge below 3.0 volts.
I think you should research more about li-po batteries before you do anymore 'experimentation'. Li-pos have very specific charging and discharging rules and one can easily destroy them and even cause fires.
Post by: tsunamy_boy on Apr 13, 2014, 09:16 pm
Ok, so after a lipo battery charging, if the battery is low than 4.2V, this means that the battery is not fully charged right? So in other words, it will not overcharge if i keep charge it the same way over and over?
Post by: CrossRoads on Apr 13, 2014, 09:19 pm
4.1, 4.2 - depends on the charger.
4.1 is going to be pretty charged.
Post by: tsunamy_boy on Apr 13, 2014, 09:43 pm
Cool, so it looks to you that there would be no problem? If i got 4.4 for example, this would be a problem (is this what it's called over charging?)?
Post by: CrossRoads on Apr 13, 2014, 09:51 pm
4.4 would be a problem.
Post by: tsunamy_boy on Apr 13, 2014, 11:03 pm
Understood, thank you and thank you all.
Have a nice day guys
Post by: jbarchuk on Apr 15, 2014, 01:55 am
Quote from: tsunamy_boy link=topic=233021.msg1678764#msg1678764
date=1397422989
What I'm going to write here may seem a little terse and rude, but I'm trying to get your ATTENTION! Please don't take it personally but this is your life and/or your family's life were talking about.
No, not 'understood' at all. I don't know if realise the implications of '4.4 - would be a problem.' A lipo burns a 2000F and shoots flames up to 6'. Anything within reach that is potentially combustable instantly combusts. That includes your face.
Back in the day lipos got a very bad reputation for causing fires, generally caused by crappy chargers. Lately, most fires are caused by overcharging, or trying to keep using damaged batteries.
The mere fact that you ask question says that you are not an engineer, and are therefore not qualified to 'know' (measure) the A of a battery.
The mAh of a battery is a shell game. It is essentially determined by how many potential -cycles- a battery will have.
The cycles are determined partly by how hard you draw the current, and how far down you run the voltage.
A lipo is fully charged at 4.2V. Notice though that when you buy one brand new it's at 3.65-3.75V. That's the nominal voltage, the 3.7 that's printed on the label. That's what the factory charges the battery to to give the longest life when sitting on a retail store shelf for a year or two.
When they say that 4.2 is the maximum, they mean that anything beyond that risks fire/explosion. (OK 4.25 or whatever but who wants to risk it.)
Beyond 4.2 the battery doesn't necessarily immediately go 'poof.' It starts to get warm, probably it puffs, the chemicals degrade, it gets hotter, there's a thermal runaway and -then- it goes poof. The only lipo fire I ever saw personally was a 'moderate impact' helicopter crash. walking over to it, and then looking for a bit, it had to be somewhere between 1 and 2 minutes before it actually caught fire, 3' flames. A multicell battery fire can -appear- to go out, then catch fire a minute later as another cell catches.
These numbers aren't cast in stone either. Manufacturers vary, chemistries vary, production processes vary. Stay on the *safe* side of all the numbers and you'll have the best chance of not suffering a disaster. But the reason I'm being LOUD about all this is that so far you're playing on ALL the UNSAFE sides of the numbers.
The point being that once you go past 4.2x, or give it a severe shock/impact, you're holding a grenade in your hand, the pin is pulled, you just haven't released the  yet. But the the detonator is not under your -control-, it's a chemical reaction that will light up sooner or later.
...i just discharged a Lipo Battery completely (0v now)
BTW you just destroyed the lipo. Yes there're potentially ways to 'revive' them but it is severly damage, will have a drastically shortened lifespan, and every time you charge it you're playing 'pull the pin on the grenade and see if it lights up this time.'
Not necessarily, and probably not, because you haven't mentioned what you're charging it with, also given some of the treatment you give them such as discharging down to 0V. A damaged battery -may- not have the ability to be fully recharged to 4.2. The fact that it won't go to 4.2 -may- be a sign of damage. A reputable charger, first, won't let a battery charge past 4.2, and if it doesn't reach 4.2 won't let it charge past a certain time limit.
The C rating of a battery is not cut and dried. Again, it is a shell game number picked by the manufacturer to get an 'OK' number of cycles from the battery by the average consumer. 100 cycles is generally assumed to the target cycles. (As was mentioned, manufacturers don't publish -real- specs.) You can, for instance, discharge a 10C battery at 20/30/40/whatever rate you want, but it may work only 20 or 5 times, or only once. OTOH I've heard of rare instances of mocel aircraft catching fire in flight because they pushed a battery too hard.
Battery usage isn't supposed to be measured by mA, it's supposed to be measured by V. The 'ABSOLUTE maximum discharge' is -generally- touted at 80% or about 3.4V. But, that will give you the fewest usable cycles. One fellow I read about, whose -job- it is to manage battery systems, said he got -600- cycles by dischargong to the nominal 3.7 / 50%.
Regardless the topic really was about charging. You didn't mention what size batteries you're using. Common consumer toys come with a charger, and shouldn't be messed with by either using a different charger or using the charger on other batteris unless you *KNOW* what you're doing. Here's a good reference about overcharging and the 4056. http://www.rcgroups.com/forums/showpost.php?p=27249411&postcount=334
One more BTW. NEVER leave a charger unattended. There was a story this past Xmas about a new toy, got used a few times in the morning, and was left on the charger while the family went out. They came home and the house was burned down. It was -probably- a 10-15 minute charger, that -probably- had a warning label on it that said 'do NOT leave on charge for more than one hour.' Misuse = 'poof.' Junky charger = 'poof'
Post by: cjdelphi on Apr 15, 2014, 02:07 am
I ended up building my own lithium ion charger circuit using simply 5v, arduino powered.
Post by: polymorph on Apr 15, 2014, 05:05 am
I think there was a misunderstanding and the OP connected his meter set on Amps directly across the battery.
Post by: tsunamy_boy on Apr 19, 2014, 03:17 pm
Ok, i'm scared now!!
So by this, tell me what's the best way to charge a lipo battery.
I've followed this topic: http://forum.arduino.cc/index.php?topic=230870.0
Do you think i'm ok with that?
It looks scary for me :P do you have a schematic and the source that you can share with this community?
It would be awesome.
Also tell me, can you charge any kind of lipo battery (i have an idea that each mA need a different situation)?
Well, yeh  :smiley-eek:
Post by: jbarchuk on Apr 19, 2014, 05:35 pm
The way the -battery- -manufacturer- says to, for the part number printed on the battery. Wikipedia lists 24 different 'lithium' chemistries. Lithium is the family name -lithium ion and lithium polymer are not necessarily synonyms. Voltages and charge/discharge characteristics vary *DRASTICALLY*.
That looks like the straight dope.
Post by: CrossRoads on Apr 19, 2014, 06:30 pm
MAX1811 is easy to use for a LiPo.
Here I used one to charge a 1000mAH LiPo in my RF remote control.
I used 3AA battery pack for development, then connected the LiPo when I get the other parts in.
Has been running since ~Jan 2011.
Post by: tsunamy_boy on Apr 19, 2014, 08:04 pm
Why  :smiley-roll-sweat:
Do you have the need to setup resistors based on the amps that your batteries have?
Post by: CrossRoads on Apr 19, 2014, 09:02 pm
No. Lower left resistor is there to set Enable High or Low depending on whether external power is available. Upper right resistor is there to limit current to the charge indicator LED for brightness control.
Pins 1 & 2 determine whether it charges to 4.1V or 4.2V, and at 100mA rate or 500mA rate.
Post by: tsunamy_boy on Apr 19, 2014, 09:13 pm
The IC does that automatically?
(...) at 100mA rate or 500mA rate.
This means that i can't charge a battery bellow 100mA or above 500mA?
Post by: retrolefty on Apr 19, 2014, 09:19 pm
Yes, and yes.
Post by: CrossRoads on Apr 19, 2014, 09:21 pm
Yes, the chip controls the level.
100 & 500mA are the rates supported by this chip. USB as the current source.
I suppose if the source can't supply that much, it will use whatever is available.
Post by: tsunamy_boy on Apr 19, 2014, 09:23 pm
Yes, and yes.
Thank you :)
Thank you, is there any other chip like that that can handle until 1Amp?
Post by: CrossRoads on Apr 19, 2014, 10:11 pm
Don't know. Search "battery management" at www.maxim-ic.com
or www.maximintegrated.com
My chrome is having a hard time connecting to maxim right now for some reason.
Post by: CrossRoads on Apr 19, 2014, 10:15 pm
This will do 1A, need to have the exposed pad connected for cooling.
http://www.digikey.com/product-detail/en/BQ24090DGQT/296-25863-1-ND/2237301
Post by: tsunamy_boy on Apr 19, 2014, 10:30 pm
If i understood it charges batteries at 10mA min and 1000mA max right?
What does this means: "Pin Selectable USB 100mA and 500mA" cuz i'm confused about this
Post by: CrossRoads on Apr 20, 2014, 12:21 am
Read the Pin Functions on page 7:
ISET2, pin 7:
Programming the Input/Output Current Limit for the USB or Adaptor source:
High = 500mAmax,
Low = ISET, (another pin, see below)
FLOAT = 100mA max.
ISET, pin 6:
Programs the Fast-charge current setting. External resistor from ISET to VSS defines fast charge current value. Range is 10.8k (50mA) to 540 ? (1000mA).
Also read more about these 2 pins on pages 18, 19.
Post by: tsunamy_boy on Apr 20, 2014, 01:05 am
ISET2, pin 7:
High = 500mAmax,
FLOAT = 100mA max.
ISET, pin 6:
And i have to calculate a resistor to different battery amps right?
Post by: retrolefty on Apr 20, 2014, 01:06 am
ISET2, pin 7:
High = 500mAmax,
FLOAT = 100mA max.
ISET, pin 6:
Yes
Post by: tsunamy_boy on Apr 20, 2014, 01:52 am
humm then i already have similar to that =)
I would go with a charger that doesn't need changes :P
Post by: jbarchuk on Apr 20, 2014, 05:14 am
You are free to add a tiny board that adds a DIP switch that patches in different resistors.
You are free to add an digitally controlled potentiometer that switches the resistors under keypad/LCD control.
You are free to plug all that into an Arduino with a library of battery specs, that you pick the battery and it knows how to set the digital pot.
Orrrrr you can go buy a charger that already has those features in it. Well, not the library of specific batteries, but you tell it the mA and it does the rest.
Arduino is all about the 'exercise for the student.' If you want to be the student and design/build it, then do it. If you just want the device to use it, then it's already available.
Post by: Zapro on Apr 20, 2014, 10:28 pm
Matbe you overlooked the fact that OP is using a Nokia-pack, and therefore (if it's not one of those clones that's extremely dangerous) it's a protected pack. These kind of batteries are almost idiot- and fool-proof. Over-discharge them, and they'll go open circuit until you try to charge them again. Short-circuit them, and they'll go open circuit. Over-charge them and they will go boom though :D
// Per.
Post by: tsunamy_boy on Apr 21, 2014, 02:15 am
Ok no, it was a cheap lipo ebay battery, but once i add current back again it got back to life instantly.
But yes, it might have become a clock bomb :O
Post by: polymorph on Apr 21, 2014, 05:25 pm
What exactly do you want to know?
How many Amp-hours are in the battery? We can help you with that.
What is the maximum current you can safely draw from that battery? For that, you need to ask the seller or find the manufacturer of the battery and ask them.
Post by: tsunamy_boy on Apr 21, 2014, 06:00 pm
Well if you could explain it with more detail i would be grateful yes :)
Post by: polymorph on Apr 22, 2014, 03:31 pm
Ah or Ahr is Amps times hours. So if a battery is 1Ah, you can draw 1A from it for one hour if starting from a full charge.
However, batteries are normally rated by drawing enough current to last 10 hours, then multiplying that by 10. The faster you draw current from a battery, the less efficient it is, so a 1Ah battery may only give you 1A for 45 minutes before it is empty, but go 10 hours on 100mA.
So you need to start with an approximate number. How large is the battery? What kind of battery?
Post by: tsunamy_boy on Apr 22, 2014, 04:04 pm
Well i have a lot of kinds of batteries, but i got your idea and it was great because i learned something more. I didn't know that thing about 10 hours 100mA.
Thanks mate :)
