Arduino Forum
Using Arduino => Motors, Mechanics, Power and CNC => Topic started by: backbone on May 24, 2014, 08:33 am
Title: (Solved) accelstepper code for stepper with constant speed in 2 directions
Post by: backbone on May 24, 2014, 08:33 am
I had to take two steps back in my project.
Combining various actions led to misbehaviour.
So I first have to get all parts seperate to work before trying to combine them.
Now this one is very basic and is using the accelstepper.h lib.
I found as new bie the explanations and samples not satisfactionary and web searches for something simpel to understand I could not found.
So lets start with this basic.
run a stepper motor with 2 button control in 2 directions.
The reason for the ON/OFF function in either direction is that I need to use the stepper motor as a regular DC motor.
No need to count steps just power and rotate as long as the function tells it to do.
To know the EXACT position I will be using an encoder disk.
In the sample code:
Button one starts the stepper motor CW
Next press on the same button stops the motor.
Button two starts the stepper motor CCW
How can I get the motor to run CW or CCW?
I looked the .h classes and find DIRECTION mentioned but no sample how to add it.
http://www.airspayce.com/mikem/arduino/AccelStepper/classAccelStepper.html (http://www.airspayce.com/mikem/arduino/AccelStepper/classAccelStepper.html)
Current code like this.
// Push On - Push Off sketch to move stepper motor in clockwise CW or counter clokcwise CCW direction.
// motor keeps turning as long as the flag1 or flag2 is high
#include <AccelStepper.h>
AccelStepper stepper(4,4,5,6,7); //bipolair stepper 4 wire on pin 4,5,6,7
boolean buttonstateUp = 0;
boolean buttonstateDown = 0;
boolean LeftTurn = 0;
boolean RightTurn = 0;
boolean flag1 = 0;
boolean flag2 = 0;
int Analog2 = 16; // Use analog port on shield for push button to control movement and direction
int Analog3 = 17; // Use analog port on shield for push button to control movement and direction
 stepper.setMaxSpeed(1000);
 stepper.setSpeed(300);
 LeftTurn = digitalRead(Analog3);
 RightTurn = digitalRead(Analog2);
 buttonstateUp = LeftTurn;
 buttonstateDown = RightTurn;
 if (buttonstateUp == 1)
   flag1 = 1;
 if (buttonstateUp == 1 & flag1 ==1)
   flag1 = 0;
 while (flag1 == 1)
   stepper.runSpeed();  //run motor clockwise CW
 if (buttonstateDown == 1)
   flag2 = 1;
 if (buttonstateDown == 1 & flag1 ==1)
   flag2 = 0;
 while (flag2 == 1)
   stepper.runSpeed(); //run motor counter clockwise  CCW
Title: Re: Basic accelstepper.h behaviour for stepper constant speed 2 directions
Post by: raschemmel on May 24, 2014, 08:38 am
What's your question ?
Post by: backbone on May 24, 2014, 10:15 am
1] Question was imbedded......How can I get the motor to run CW or CCW?
So how to change direction using this lib at constant speed..
2] Above code start by the button press and motor runs in one direction, but second button push does not stop the motor.
Thanks, Paco
Post by: raschemmel on May 24, 2014, 03:19 pm
If you are using the AccelStepper library did you ever look at the code in the only example in the library ?
//This is an example of how you would control 1 stepper
int motorSpeed = 9600; //maximum steps per second (about 3rps / at 16 microsteps)
int motorAccel = 80000; //steps/second/second to accelerate
int motorDirPin = 2; //digital pin 2     < ===THIS IS A DIRECTION PIN
int motorStepPin = 3; //digital pin 3
//set up the accelStepper intance
//the "1" tells it we are using a driver
AccelStepper stepper(1, motorStepPin, motorDirPin);
void setup(){
 stepper.setMaxSpeed(motorSpeed);
 stepper.setSpeed(motorSpeed);
 stepper.setAcceleration(motorAccel);
 stepper.moveTo(32000); //move 32000 steps (should be 10 rev)
void loop(){
 //if stepper is at desired location
 if (stepper.distanceToGo() == 0){
   //go the other way the same amount of steps  <= "go the other way" sounds like a direction change to me.
   //so if current position is 400 steps out, go position -400
   stepper.moveTo(-stepper.currentPosition());   <= THAT LOOKS LIKE A "-"SIGN IN FRONT OF THE  "stepper.currentPosition()"
 //these must be called as often as possible to ensure smooth operation
 //any delay will cause jerky motion
 stepper.run();
Post by: backbone on May 24, 2014, 04:03 pm
I looked at all the sample codes in the lib. that are in the top bar.
http://www.airspayce.com/mikem/arduino/AccelStepper/examples.html (http://www.airspayce.com/mikem/arduino/AccelStepper/examples.html)
There are many samples havent fond the one you describe.
Or do I mis something?
I opted for the constant speed sample as I need to use the steppermotor as an regular DC motor.
I know that sounds opposite for what a stepper is used for. :-)
The stepper steps are not accurate in my application so my steps are counted by an encoder disk.
Should I call stepper.move (10000000)  and run.steppr so it keeps moving indefenetly (almost) untill I tell the motor to stop and then tell the motor to call stepper.move(-10000000) and run.stepper so it keeps moving indefenetly (almost) untill I tell the motor to stop?
BTW I found out the buttons need a debounce but that is an other issue I have to tackle.
Post by: raschemmel on May 24, 2014, 04:08 pm
Attached is the only AccelStepper Library I am aware of. I don't know why you couldn't find the example I posted. It is the only example in the library. Do you know where the Library is (the folder?) Did you look in that folder ? Did you try "File\Examples\Accelstepper\one_stepper_example" ?
In the sample code:
I haven't received my stepper motor driver yet so I can't test it but I think you need to have code that executes a command statement based on which button is pressed. With a dc motor driver it would be a simple matter of reversing the direction bits but with a stepper you need some way to control the number of steps used in the command. I haven't done any stepper motor coding yet so all I can do to help you is to recommend that you google "arduino AccelStepper direction control"
Post by: backbone on May 24, 2014, 06:23 pm
OK,
Got it sorted out and to be honest the solution was easy as always.
You have to look through it. :-)
I used your sample and reworked it.
Here is the code that uses serialmonitor to send the button presses as this makes the button debounce for debugging obsolete. I hope someone can use it in the future as reference.
I used it with a L298 stepper board so AccelStepper stepper uses more and different pins as an Easy Driver board.
Thanks for the assistance and the pointers.
//This is an example of how you would control 1 stepper with constant speed and direction
// to be used if stepper need to act as DC motor and the steps to be taken are irrelevant
int motorSpeed = 1000;
int motorAccel = 800;
int LeftTurnUp = 0;
int RightTurnDown = 0;
int incomingByte = 0;   // for incoming serial data
int enablePin10 = 10;  // switch off coils when not in use
AccelStepper stepper(4,4,5,6,7); // set up the stepper as 4 wire bipolair on pin 4,5,6,7
  pinMode(enablePin10, INPUT);
  if (Serial.available() > 0)
    incomingByte = Serial.read();
      if (incomingByte == '1')
        digitalWrite(enablePin10, HIGH);
        LeftTurnUp = 1;
        RightTurnDown = 0;
      if (incomingByte == '2')
        RightTurnDown = 1;
        LeftTurnUp = 0;
      if (incomingByte == '3')
        LeftTurnUp = 0;
        RightTurnDown = 0;
        stepper.moveTo(0);
        digitalWrite(enablePin10, LOW);
  if (LeftTurnUp == 1)  //left turn
    stepper.moveTo(1000000); //move many steps - more then mechanical needed
  if (RightTurnDown == 1)  //right turn
    stepper.moveTo(-1000000); //move many steps - more then mechanical needed
  stepper.run();
Title: Re: (Solved) accelstepper code for stepper with constant speed in 2 directions
Post by: raschemmel on May 24, 2014, 06:40 pm
Your welcome. Thanks for the code. I'll try it when I get my driver in the next few days.
Post by: morelg on Jun 21, 2014, 04:55 am
Dear backbone,
I am trying to work a somehow similar project as yours but I am facing difficulties and it would be great if you could help with an advice.  I am trying to operate a valve driven by a small stepper using Uno and EasyDrive board. At the closed position the valve hits a limit switch. I am using a another switch to tell the valve to open (.i.e. motor CW)   or close (i.e. motor CCW).  I would like to implement the following logic: In case an open command is received the motor should turn 8000 steps to one side. In case a close command is received the motor should turn 8000 steps to the other side (-8000). Then, in case the limit switch is not activated I would like to turn an additional  (-1000) steps. I would like to use AccelStepper library because I plan to operate more than one valve in parallel.
Anyhow the code without the limit switch seems to work fine, but I am not able to make the limit switch to work  see below:
void loop ( )  {
  cmdVent = digitalRead (cmdPinVent); //Read the Vent Valve command to OPEN (LOW) or to CLOSE (HIGH)
   if (ventValve1.distanceToGo ( ) == 0) {
    //Check for OPEN command
    if ( cmdVent == LOW && cmdVentOld == HIGH ) {
      ventValve1.move (stepNumber);
      cmdVentOld = cmdVent;
    //Check for CLOSE command
    if ( cmdVent == HIGH && cmdVentOld == LOW) {
     ventValve1.move (-stepNumber);
      switchVent1=digitalRead (switchPinVent1);
      if (switchVent1 != HIGH) {
      ventValve1.move (-1000);
  ventValve1 .run( );
Base on your experience with the AccelStepper library, do you have and advice on how to sort this out?
Thank you,
Morel
