Arduino Forum
Topics => Robotics => Topic started by: gicren on Aug 25, 2014, 08:45 pm
Title: A robotic controller with built-in Arduino UNO
Post by: gicren on Aug 25, 2014, 08:45 pm
I want to introduce a robotic controller to everybody. Features are as follows:
(1) Built-in Arduino UNO R3
(2) Built-in 24 channels PWM-Style servo controller (the latest version of SoftServo controller from Gicren Robotics and Electronics)
(3) Most of the digital and analog ports are extended in JST-PH2.0-3P (Digital ports: 10 / Analog ports:4), which make it easy to connect sensors
(4) The power supply of JST-PH2.0-3P can be selected flexiblely (Digital ports: 5V or Vin / Analog ports: 3.3V or 5V)
(5) The remaining pins for extended applications are led out in headers (pitch:2.54mm 2x14Pin)
And so on,
Title: Re: A robotic controller with built-in Arduino UNO
Post by: daniellyall on Aug 29, 2014, 06:38 am
web site?
Post by: JimboZA on Aug 29, 2014, 07:31 am
Do you mean that literally, or do you mean it has the functionality of an Uno?
If the former, well I wonder how you managed to fit it inside there; if the latter, you need to be careful of your wording for copyright reasons.
Post by: gicren on Aug 31, 2014, 08:13 am
Arduino is an open source project. It is allowed to do everything(modify,manufacture,and so on) except to use their registered trademark.
Arduino UNO is very excellent, famous and popular. I hope the technology of Arduino to be infiltrated as wide as possible.
ManShow-RC1 combines servo control system and Arduino UNO together reasonably, which make it easier to control robot(such as humanoid robots, bionic robots and arms).
Finally, I appreciate the spirit of open source of Arduino team, and thank them for their contributions.
Post by: JimboZA on Aug 31, 2014, 08:16 am
You didn't answer my question:
Do you mean that literally [Built-in Arduino UNO R3], or do you mean it has the functionality of an Uno?
Post by: gicren on Aug 31, 2014, 08:43 am
The internal structure of ManShow-RC1
Post by: JimboZA on Aug 31, 2014, 09:04 am
So.....
.... is actually not true.
It might be compatible with a Uno, or be in some ways functionally similar, but you didn't actually take an Arduino factory-built Uno and build it in to your product.
Post by: JimboZA on Aug 31, 2014, 10:25 am
web site?
I found this: http://www.gicren.com/
As web sites go, is pretty ummm, shall we say, empty?
Post by: gicren on Aug 31, 2014, 11:48 am
1: Properly speaking, ManShow-RC1 is a UNO compatible controller in terms of functionality.
2: Currently, I do not have enough time to build a full website. The existing data are shared on onedrive(Please click the sixth button on the home page, thank you!)
Post by: JimboZA on Aug 31, 2014, 12:15 pm
Ah.....
Then if I were you, I would correct your thread title and original post in this forum, and also at robotshop's forum (http://www.robotshop.com/forum/post-p113277) because you do not have a "built-in Arduino UNO".
edit.... and you should possibly rethink your product labeling. But I'll let the copyright holders follow up on all of this...
Post by: gicren on Aug 31, 2014, 03:40 pm
Arduino UNO is not just a circuit board. It really shows a connection between components, and functions can be achieved. I hope you can agree with me, thank you!
Post by: JimboZA on Aug 31, 2014, 04:14 pm
I know exactly what an UNO is, and you don't have one inside your product. At most your product is compatible with an UNO, but it doesn't have the R3 form factor afaics, so it's not that compatible.
My opinion is that you're using the Arduino name improperly, but that's a fight for the Arduino founders not me. Meantime I emailed them about your product and if they have issue with your use of the phrase "built-n Arduino UNO"  or not, that's their call.
I'm out....
