Hi Peter_n,
Thanks for taking the time to help me.
I have 2 potmeters connected the "master" UNO.
Sending a byte for the sensor and a byte for the value is a great solution that should work.
I will segregate the if statements from the interrupt code.
I've simplified the sketches so you can see the full code for master and slave.
Master:
#include <Wire.h>
const long debounceInterval = 100;
unsigned long previousMillis = 0;
// potentiometers
int potent1Pin = A1; // select the input pin for the potentiometer
unsigned short potent1Value = 0; // variable to store the value coming from the sensor
byte potent1Position = 0; // variable to store the rotary switch position
byte potent1Previous = 0;
int potent2Pin = A2; // select the input pin for the potentiometer
unsigned short potent2Value = 0; // variable to store the value coming from the sensor
byte potent2Position = 0; // variable to store the rotary switch position
byte potent2Previous = 0;
byte x = 0;
// initialize serial communication at 9600 bits per second:
Wire.begin(); // join i2c bus (address optional for master)
potent1Value = analogRead(potent1Pin); // read the value from the sensor
potent2Value = analogRead(potent2Pin); // read the value from the sensor
if (millis() - previousMillis >= debounceInterval) {
if (potent1Value < 205) { // potentiometer position 1
potent1Position = 1;
//Serial.println("potentiometer position = 1");
if (potent1Value > 205 && potent1Value < 410) { // potentiometer position 2
potent1Position = 2;
//Serial.println("potentiometer position = 2");
if (potent1Value > 411 && potent1Value < 615) { // potentiometer position 3
potent1Position = 3;
//Serial.println("potentiometer position = 3");
if (potent1Value > 616 && potent1Value < 820) { // potentiometer position 4
potent1Position = 4;
//Serial.println("potentiometer position = 4");
if (potent1Value > 821 && potent1Value < 1023) { // potentiometer position 5
potent1Position = 5;
//Serial.println("potentiometer position = 5");
potent2Position = map(potent2Value, 0, 1023, 0, 255);
previousMillis = millis();
if (potent1Position != potent1Previous) {
if(potent1Position == 1){
sendCommand(1, 11);
} else if(potent1Position == 2){
sendCommand(1, 12);
} else if(potent1Position == 3){
sendCommand(1, 13);
} else if(potent1Position == 4){
sendCommand(1, 14);
} else if(potent1Position == 5){
sendCommand(1, 15);
potent1Previous = potent1Position;
if (potent2Position != potent2Previous) {
potent2Previous = potent2Position;
sendCommand(2, potent2Position );
void sendCommand (byte sensorID, byte value) {
Wire.beginTransmission(4); // transmit to device #4
Wire.write(sensorID); // id for sensor
Wire.write(value); // sends one byte
Wire.endTransmission(); // stop transmitting
Slave:
#include <Wire.h>
void setup () {
Wire.begin(4); // join i2c bus with address #4
Wire.onReceive(receiveEvent); // register event
Serial.println("setup");
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
With above code I'm run into a new issue, where I only see 1 byte come through on the slave side. When I turn one pot, I see it's ID and no value. Then when I turn the 2nd pot I see nothing. Then when I turn the original pot no new events at all.
If I re add Wire.available() like so:
#include <Wire.h>
void setup () {
while(1 < Wire.available()) // loop through all but the last
int ID = Wire.read(); // receive byte as a character
Serial.print("ID");
Serial.print(ID); // print the character
int val = Wire.read(); // receive byte as an integer
Serial.print("val");
Serial.println(val); // print the integer
I see the IDs and value of my pots. I will set these as global vars and should be good to go. Still not sure why I had to re add Wire.available(). Thanks for pushing me in the right direction.
