Arduino Forum
Products => Arduino Due => Topic started by: Joegi on Apr 11, 2015, 02:51 pm
Title: string doesn't change
Post by: Joegi on Apr 11, 2015, 02:51 pm
If I compile the following program
  printOnDisplay("This is a test");
void printOnDisplay(char *string) {
  string[4] = 0;
  Serial.println(string);
on an ARDUINO DUE (and maybe on other ARDUINOS, too) the output is not as expected "This", but "This is a test"!? Why is the character-array "This is a test" not changeable. - Is it located in flash-memory?
Thanks for the answers in advance!
Title: Re: string doesn't change
Post by: waski on Apr 11, 2015, 02:59 pm
Post your complete code.
Post by: PaulS on Apr 11, 2015, 03:20 pm
What are you expecting to see, when the function outputs the data? I expect to see "This" followed by a carriage return and line feed.
What are you actually seeing?
Post by: waski on Apr 11, 2015, 03:40 pm
So i think this
string[4] = 0;
should be :
string[4] = '\0';
Post by: Joegi on Apr 11, 2015, 03:42 pm
As strings are "0"-terminated and I added a "0" after "This", I would expect "This" as output!?
Post by: PaulS on Apr 11, 2015, 03:43 pm
Both '\0' and 0 store the same value in the array.
OP, when I uploaded your code, after adding a loop() function, to my Arduino (Duemilanove), I get Test as the only output.
What do YOU actually get? On which Arduino, using which version of the IDE?
Post by: Joegi on Apr 11, 2015, 03:49 pm
I'm using an ARDUINO DUE (IDE version 1.6.3)!
The following code
  while(1);
  string[4] = 0;
  if (string[4]) Serial.println("String hasn't changed!");
  else Serial.println("String has changed!");
leads to the output:
"This is a test"
Post by: Joegi on Apr 11, 2015, 03:57 pm
When I compile it for an ARDUINO UNO it works as expected with the output:
"This"
Post by: PaulS on Apr 11, 2015, 03:58 pm
If you change:
  while(1);
to
   char test[] = "This is a test";
  printOnDisplay(test);
  while(1);
do you get the same (apparently incorrect) output?
Post by: Joegi on Apr 11, 2015, 04:05 pm
If you change:
  while(1);
to
  while(1);
With your change it now works as expected!
Post by: PaulS on Apr 11, 2015, 05:45 pm
So, apparently, on the DUE, literals are stored in a read-only portion of memory. I'd expect an attempt to alter a read-only portion of memory to generate an error at compile time - or at least a warning. But, since we are to be "protected" from our mistakes, warnings are disabled, so we never see them. Pretty stupid, in my opinion.
Post by: Joegi on Apr 11, 2015, 06:00 pm
...I added the "problem" to the bug-report list on GitHub. Maybe it is not a bug, but at least surprising inconsistency!
Post by: christop on Apr 11, 2015, 08:50 pm
This is a known "gotcha" with C/C++. Back in the day before C had the "const" keyword, a read-only string literal was passed around as a pointer to char. You weren't allowed to modify the string, but that couldn't be enforced by the compiler--it had no way to differentiate a string that could be modified from one that couldn't when all you had was a pointer to char.
So now we have a language that still permits you to pass a read-only string literal to a function that takes a pointer to char without throwing a compiler error for the sake of backwards compatibility.
In any case, modifying a string literal is undefined behavior. It's not a bug as it's perfectly legal for the Uno to have different behavior than the Due. It would also be legal for the program to crash, if the implementation happened to work that way.
