Arduino Forum
Products => Arduino Yún => Topic started by: YZDYZD on Aug 10, 2015, 08:04 am
Title: The serial monitor cannot dispay the data through wifi
Post by: YZDYZD on Aug 10, 2015, 08:04 am
I try to connect the grove ear-clip heart rate sensor with yun through wifi (without the USB cable), It upload success, but when I open the serial monitor. It shows:
Unable to connect: retrying (1)...
Unable to connect: retrying (2)...
Unable to connect: retrying (3)...
Unable to connect: retrying (4)...
Unable to connect: is the sketch using the bridge?
The same problem when I open the serial monitor after uploading the  WiFi Status(under bridge) through wifi
I want to see the heat rate data display on my serial monitor.
I am sure that the network works, because I can use the Console Pixel program to turn on and off the LED through wifi.
Title: Re: The serial monitor cannot dispay the data through wifi
Post by: Mattse on Aug 10, 2015, 11:26 am
http://playground.arduino.cc/Hardware/Yun#console_cant_connect (http://playground.arduino.cc/Hardware/Yun#console_cant_connect)
I suggest you read everything from that page, a lot of questions find their solutions there.
Take care mate
Matthias
Post by: ShapeShifter on Aug 11, 2015, 12:28 pm
That would be expected since that sketch sends data using the Serial class, which only works over the USB port.
That sketch uses the Console class, which talks to the Serial Monitor over the network.
Keep in mind that while they both talk to the a serial Monitor, the Serial class only talks over the USB port, while the Console class only talks over the network. If you want to talk over the network, your sketch must use a Console for output, not Serial.
