Arduino Forum
Using Arduino => Audio => Topic started by: Stella_Beeee on Sep 08, 2015, 02:47 pm
Title: On/Off Button and Volume changing Potientometer
Post by: Stella_Beeee on Sep 08, 2015, 02:47 pm
I have this task where I have to build a simple musical device that plays the Chorus of our school song, every time a button is pushed. A second button (or a potentiometer) will fade the volume up or down. I have no idea on what to do and the rest of the class is stuck on the same thing. I have got the song down pat, all I need is the coding and layout for the volume and the 'on' button. It doesn't need to turn it off. We can also use a button to change the volume.
I would really appreciate it if someone could help because I am absolutely HOPELESS
(If you want to see my coding, please just ask. There will be some errors in there and I will be delighted if you could pick them up)
Title: Re: On/Off Button and Volume changing Potientometer
Post by: DVDdoug on Sep 08, 2015, 05:51 pm
how about an iPod?    ;)
That's the "hard part."   You'll need an "audio shield" or "MP3 shield".   The shield will have the memory to store the song and the digital-to-analog converter.   So, the Arduino is just a "controller".
...every time a button is pushed.
That's just an if-statement in software.  Look at the button example (https://www.arduino.cc/en/Tutorial/Button).
A pot at the analog output is the easiest way to go.   Make sure to get an "audio taper" pot.    Your ears are not linear and a regular linear pot will sound too loud at the half-way point.   But...    You'll need an amplifier to drive a speaker and the amp should have a volume control already.
Or, if the audio shield you choose has digital volume control, you can use either a pot on an Arduino analog input, or volume-up and volume-down buttons on digital inputs (again with if-statements).
