Arduino Forum
Using Arduino => Displays => Topic started by: c0rsa1r on Oct 22, 2015, 03:21 pm
Title: Solved please delete
Post by: c0rsa1r on Oct 22, 2015, 03:21 pm
PLEASE DELETE
Title: Re: Small yet big problem with touch lcd
Post by: david_prentice on Oct 22, 2015, 04:42 pm
A membrane switch is nothing more than a regular switch.   (with a "moderate" ON resistance)
So you can read it like any other pushbutton.    i.e. connect common to GND,  the switch to a pin.   use pinMode(button, INPUT_PULLUP);
If you have a matrix keypad,   you would use exactly the same code as a 4x4 keypad.
You do not need any external electronics.
If you are very tight for pins,   you can use an Analog input pin to read 3 or 4 pins on a resistance ladder.    But it is a bit unreliable with dirty membrane.
David.
Title: Re: Solved please delete
Post by: MAS3 on Oct 22, 2015, 09:39 pm
Note to self:
NEVER reply to user c0rsa1r.
He/she doesn't appreciate help if offered, and doesn't want others to learn from their mistakes.
