Arduino Forum
Using Arduino => Programming Questions => Topic started by: damith14 on Nov 16, 2015, 08:32 am
Title: Compare 4 int values and find the lowest value ?
Post by: damith14 on Nov 16, 2015, 08:32 am
i have 4 int  values and they can be different to each other or they can be equal,i want to write a programme to find what are the lowest values and how much of them...
Eg:(val1=5,val2=3,val3=10,val4=3)
lowest value=3,
lowest variables are val2 and val4
any help ..
thanks in advance
Title: Re: Compare 4 int values and find the lowest value ?
Post by: HazardsMind on Nov 16, 2015, 08:58 am
Do you know how for loops work? Are you familiar with the function min().
If yes to both, then you should be able to solve your problem.
I would make two functions, one to find the minimum value and the other to look for how many of that value.
I'll give you a Karma point if you can combine both into one function that returns both values.
Post by: Robin2 on Nov 16, 2015, 08:59 am
The simplest thing would be to put the values into an array and use a FOR loop to iterate over the array. Something like
lowVal = myArray[0];  // just to start it off
for (byte n = 0; n < 4; n++) {
   if (myArray[n] < lowVal) {
        lowVal = myArray[n];
...R
Post by: Whandall on Nov 16, 2015, 09:21 am
Why not use the min function?
  int val1 = 5, val2 = 3, val3 = 10, val4 = 3;
  int minimum = min(min(val1, val2), min(val3, val4));
  Serial.print("Minimum is ");
  Serial.println(minimum);
void loop() {}
Post by: PaulMurrayCbr on Nov 16, 2015, 02:29 pm
Sweep through the list once to find the lowest value, sweep though a second time to find which values equal it. O(n).
Post by: damith14 on Nov 16, 2015, 02:56 pm
THANK YOU GUYS
problem solved :D
