Is there a feature that you are terribly missing on the Arduino Create Platform? Or do you have an idea you would like to share with us?
Please let us know by posting you feedback in this thread!
COMING UP:
* Reference tab
* Private sketches
* Adjust the compiler flags before compiling and uploading the program
Wish List:
* Add roadmap + ways to up-vote/down-vote a feature
* Autoformat as in the Desktop IDE (auto indent)
* Support for 3rd party boards (specifically ATTiny and ESP, Sparkfun Digital Sandbox, Adafruit Feather, Microduino)
* Installation of Plugin for multiple users
* Sketch version control, and a way to retrive deleted sketches and files
* Github/Dropbox integration
* Keep local and online Sketchbook in sync as an option
* Support Yun Shield
* Blind-friendly, fix compatibility with screen readers
* Multi-language support
* Serial Plotter
* Arduino as ISP, burn bootloader
* Debugger
* Language support
* Move the "Serial Monitor" view (pop out window)
* Drag and Drop on Sketchbook panel
* Download Libraries together with the sketch
* Split screen friendly
* Multiple errors management: show on the red error bar AND highlighted in the code.
* "installation free" version using an USB-Mass-Storage device
* Schematics editor
* Add bootloader
* Turn off metadata (set default board as in the Java IDE)
* Autocomplete
* Include Library when exporting/saving a sketch
* Live collaboration feature (as Gdocs)
* Student & teacher collaboration: accounts linked, the teacher could setup a class assignment, and students could have a "Submit to Teacher" button built into the editor page. Teachers would be able to see an "assignment" page with a listing of all of the names of the students with the appropriate links to the code from that project, multiple install of the agent on classroom PCs
* Scratch or blockly-like coding environment
* Integrate Processing
* Edit Libraries on the Web Editor
* Share custom library
* Phone app
* Tablet plugin
* Arduino online simulation to check working process, before reducing upload cycles of the hardware.
* More editor themes (other than just light and dark)
* Import PDF in a sketch
* Export the .hex file
* Simulate the Serial Monitor for such functions as Serial.print() without needing a board or USB connection as in http://cpp.sh/
* Plugin for Linux 32bit
Done
* Version number
* Protected "credentials" tab in your Arduino sketch for sensibile info
* Chromebook plugin
* New SSO
* Clickable URLs in the code
* Copy/paste in right click
* Import whole Sketchbook
* Readme auto-population
* Select multiple files at once to perform bulk actions
* Show the memory usage (flash) when compiling
* Library Manager (Probably changed to: include all the trusted library by default)
* Import multiple libraries at once
* Support on Edge
* Support on Safari
* Support for screens smaller than 1024
* Tab scaling
* Public/Private Share feature
* Custom Library Deletion
* Support for MKR100, Arduino/Genuino 101
* Upload the whole Sketchbook to Arduino Cloud
* Serial Monitor refactor
I'd love the ability to share entire groups of programs+other tabs with other users or via a publicly accessible link. I'm sure you're thinking of this, but the richer environment (adding pictures, instructions, explanations) begs to be used for teaching.
I would love to see board manager make it's way in. Especially the ability to use this with the esp8266.
is it really necesaary to have a board connected to verify my code what if i am metro and i had this astaunishing solution for a problem and i wanted to check it do i need to have always my boards with me i dont know i am just saying
It is not necessary to have a board to Verify your code, if you have already Uploaded your code onto a board a metadata will be saved. Just pressed the Verify button (the one with the checkmark).
If you are starting from scratch you can still Verify your code w/o a board by going into Select Other Board and select the board you will like the sketch to run onto.
ESP8266 module could be sellected alone. i could not find any board option about esp8266 :smiley-confuse:
The library manager is still under development so esp8266 cannot be used right now. But we are working on it.
@MetalBird we are indeed already experimenting a bit with sharing features. It is in progress but takes a while. That is one of the reason why Arduino Create is born, share knowledge with others.
@mastrolinux that's great to hear! I think the more types of media you can share along with the program, the better the experience will be. Addition of pictures in the tabs is already great.
Are you trying to create a 'public share' where anyone can find/ link to the sketch or are you considering a 'private share' where the sketch is sent to a specific username?
@MetalBird we are considering both private and public shares :)
I would like to see the ability to upload your whole sketchbook easily into the cloud added and selecting code made easier
Hi @bonalybob, what do you mean with "select code made easier"?
We have a dev api to import a sketch so using it recursively to import the whole sketchbook should not be a big deal.
"select code made easier" means when editing code it is sometimes hard to select code to copy or delete as the selector will also select random other bits of code
Ideas that were asked for so far and their status of implementations is:
1)Sharing features (Arduino cloud) - in progress
2)...
Hi
00alis,
I suggest you to edit your first post every time you consider a feature or idea is worth taking into consideration or even if not and also to write the status of implementation like I edited in your quoted post above.
Horia
I would love being able to drag files in the left bar in order to move them in folder. Now you must right click then move to. Otherwise this webapp is awesome thanks for the development ! Using it every day for my projects and it rocks.
It would be great to have an "installation free" version using an USB-Mass-Storage device like with "mbed" over the bootloader Adafruit uses on the "Adafruit Playground".
I would like to grab all the code of Arduino Create (is it open source??) to run a local server in my classroom without the need of Internet
@Osqui we do not know yet if we are going to open Arduino Create or not. More news in few months.
@jadonmiller this is actually something we can implement relatively quickly.
@chatelao I am not even sure if an installation free version is possible, the application is very complex and involves a lot of components:
Node.js (will be moved to Golang)
RetrhinkDB
Arduino Builder Bots (a scalable way to compile Arduino Code)
The frontend in js with Angular.js
The Arduino Create Agent which runs on the client PC
An object storage (now running on Amazon S3)
I think it would be nice to also simulate the Arduino electronic, online.
For example, 123d.circuits.io :-)
Would it be possible (or is it already and I missed it) to upload multiple tabs for a project at once. I seem to only be able to upload one tab at a time.
Single tabs are working fine, but most of my larger sketches are multiple (6+) tabs for clarity.
I would also recommend to add a keyboard functions: SHIFT and CTRL. In this way I can select multiple files at once (to move, to delete ecc.). :-)
Integration with subversion server would be nice.
@Terciops when you open a sketch all the files included in the folders are opened as tabs, let us know it this does not happen!
Hello, I would like to suggest in "Preferences" option. Can you put the "Default Board" option? That way, when I create a sketch, the board is automatically set to "Arduino Uno" in the IDE. This really helps the lazy. :D :D
I would like to use the MKR1000 library (and also +1 on the ESP8266 board).
However to try out Arduino Create I can simply make sketches and use the local IDE with correct board manager. No problems.
I wish a "Local IDE" option in the Create board manager that I could select as "user defined board".
- The Create Agent would only have to start the local IDE with a command-line option.
-- Starting IDE with user command that could be set in web board manager, or in the Create Agent.
-- Default to latest used board manager if no options set and load graphical IDE to select board.
- Sync or store current sketch in local temporary sketch folder for the IDE to use.
I think this would make it easier for more users with specialized boards to get started with Create.
I agree with:
Alternatively can store in a cookie the last board selected.
Thank You
Mauro
Hi!
First, I wanna say that I love this idea, a web-based IDE is an amazing development and I really love the design, it is so clean, congrats!
However, I have a few things to say about it:
1. Language support (I know it's a beta version yet).
2. You probably know the 123d.circuit.io page and I know that it's a huge project, but It will be nice to see the posibility to simulate the code or something similar.
3. The posibility to move the "Serial Monitor" view. For example, in another window (there are many people with two or more monitors) or in the same place that the "Verbose output" (in two tabs).
4. A button to copy the output of "Serial Monitor".
5. The posibility to make our own layout and schematic image in the IDE (or maybe import from Fritzing)
6. The posibility to install the Arduino bootloader in another atmega328p or another chip
I'm done... for now :P
Hope you found this things really usable.
Bye!
I recommend making the initial import of sketches and libraries easier into Create easier and more intuitive. Have a way to bulk import sketches and libraries as they exist in a classic Arduino IDE environment. What's are the zip files all about?
I find the library system challenging. I was wondering if anyone else would agree with me that it would be easier to have the libraries that you create yourself in the same directory as the file is in and have the includes check there first.
If this were the case, then when there is a duplicate name for a library, it would use yours by default and all the libraries that are written special for the program are packaged with it in the same directory. When you upload it to a website, or store it as a backup, it will still work, because the libraries will not have been updated and changed or have been removed. You won't also have to go collect them to be able to share your code with others.
Maybe add another save option that includes the used libraries in the saved file folder! Or maybe even just save the parts of the libraries that are referenced in the code in a single library reference file.
I am wanting to use the Encoder examples with my MKR1000 board. The file Encoder\pins.h does not have interrupt listings for my board (I know, it's not released yet!) and I do not know what the processor description information is that the pins.h uses to identify which board it is running on. Does anyone know where I can track this information down at?
"__SAMD25__" <- I tried this and it did not work?
Is pins.h looking for the processor pin numbers or the board bin numbers?
Another question: Am I doing this forum posting correctly by using this like a blog?
Are there defined rules to how this is supposed to be used?
If so, how do I find those rules?
I would love a team collaboration feature, kind of like the way the google docs system works! Also a version control and password protection feature, maybe with GitHub integration. I would love integrated Processing within the Create IDE.
Much Thanks,
spyguy518
Hi all!
I have been updating the first post in this thread with our schedule, so you can have a better sense on when things are going to happen.
@spyguy518 what do you mean with password protected? everything is in HTTPS and you have to log in your Arduino account to access the Editor
@MRMAINT62 I agree with you on the Library behavior, we have been discussing similar solutions internally. It is a big structural change so it won't happen in the next few months, but we have it in mind.
@00alis I mean like a way to password protect a project, so that only people with the password can edit, and those without may only view!
Oh I get it, yes we are implementing a public/private project feature, currently all your projects are private but it won't be so in the future, thanks!
MKR1000 tested ok.
Board identified and verified upload basic blink test and modified blink sketch.
Good work!
I wish ability to use local values that will not be saved, only used i local compilation of code. Specifically when setting password such as in Wi-Fi sketches where User, Password, IP, DNS and MAC should never be stored publicly.
One way could be to have a protected "credentials" page in your Arduino profile where values can be changed and stored and never by mistake be uploaded or stored in public code. Another suggestion is ability to add a tab "locked.h" for temporary storage of sensitive values and have that tab server-side encrypted salted with user Arduino Create credentials.
Values from a "credentials" entry or "locked.h" file could be linked in sketch with a reference like "//securevalue:p14" when stored and replaced with secure value reference p14 (Password number 14) during compile.
I'd like to debug with the Arduino Zero board. Basic debugging, as breakpoints and variable monitoring, would be great.
The debugging feature on the Zero board is a real step forward compared to previous generation of Arduino boards.
Once the online backend is stabilised, do you plan to release a version to run on an Arduino board with Linux, e.g. Yún or Edison? Intenet ins't available everywhere...
Thank you!
My things I really want:
-Support for screens smaller than 1024px (e.g. 1280x720)
-A phone app or support for a mobile site. (App is preferrable.)
-Assuming said app, USB OTG support so the Arduino can be programmed via being hooked up to the phone.
-A chromebook plugin. Unless that already exists.
Just realized chromebook plugin is already on the radar. Oh well. Another thing I'd suggest is allowing for the hidden functions like setup and loop to stay hidden permanently, rather than re-expanding each time I open the program.
@cdmoro did you know you can expand the Serial Monitor panel a lot, see screenshot :)
:) Move the "Serial Monitor" view (pop out window)
I want to upload sketch through internet from outside. it's very difficult to carry hardware outside . few some time its very complicated. so I can connect my hardware with internet connection through lab dextop , open arduino create with my ID. then i can configure - update from outside ,through internet & my laptop. still now i don't have live experiment but i belie that i can do this with arduino create.
And one another think we can
i want to make a different type graph with serial monitor value. with a single click . type of option must be there.
It'd be great if it had Fritzing integration, though
A circuit simulator would be nice as well, although I don't know how easy it would be to make.
I don't want to be rude, but I wish Arduino Create's projects weren't so polluted of Azure/Windows 10 (and 1sheeld) stuff. It seems (is it??) a sponsorized site.
@Osqui this is because of popular the contest https://www.hackster.io/challenges/arduino-microsoft-maker (https://www.hackster.io/challenges/arduino-microsoft-maker). I hope the more users will add content the more the website will be open to other platform.
Totally agree !
For
education, that would be great tools !
I'm a french STEM teacher and instructor for teacher, for kids from 9 to 19, my software (Blockly@rduino (http://technologiescollege.github.io/Blockly-at-rduino/)) is very popular in France & Quebec too (they are just discovering Arduino for Education ! That's great : http://recitmst.qc.ca/arduino/ (http://recitmst.qc.ca/arduino/)).
And what we need :
- integrate your plugin in web browser : when PC are totally 'frozen', with a portable browser and a plugin in it we can work without installing anything....
- use plugin to upload to IDE Arduino installed on computer if someone prefer use it
- integrate your editor like a plugin in a web page, that's what I did with Codebender
And as said : Fritzing + simulator !!!
Thanks a lot for your work !
Everything is working, although there are a few things that I'd recommend. As a lot of people have mentioned, I need a board manager to make Arduino Create truly useful, as I spend more time developing for 3rd party boards like the Adafruit ones and barebones Atmel boards like the Attiny than I do developing for Arduino/Genuino boards.
2nd point - it would be literally awesome if you could include some kind of 123d circuits integration. 123d circuits has an "electronics lab" where you can actually simulate a variety of boards like the Uno, Nano, and ESP8266 with a virtual breadboard, and virtually upload code to these virtual boards. 123d circuits also allows you to develop schematics. So, I think that it'd be awesome if there was some kind of import function that could take the code already in 123d circuits, convert it to a sketch, and take the schematic and put that in there too.
Anyways, those are just some ideas.
Totally agree !
For education, that would be great tools !
And what we need :
Whilst it isn't EXACTLY what you asked for, I'd reccomend looking at 123D circuits. It lets people build circuits using a virtual breadboard in their web browser and has support for the ATTiny85, Arduino Micro, and Arduino Uno.
Oh, I see.
Sorry.
Hi all!
I have some project where I need to use a protoboard to minimize the space I need, and I'd like to burn the bootloader on an atmega328p. I know the ArduinoISP sketch is in the example tab but, i wish i had a online tool to burn it.
It'll be nice to completely remove the use of the desktop app.
By the way, I use the minimal hardware configuration for my microcontroler (No clock) So being able to upload a sketch with the editor would be awesome! Like adding a new board.
This is what the compiler say when I try to follow the step on this thread:
http://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
"avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf3"
OS : Win10, Browser : Chrome, Board used in editor : Arduino Uno
Continue your great job all of you!
just got the invite... thanks for that
but first show stopper for me is that i cant cant add boards via an url.... i have 2 boards that i need to add this way
but otherwise i like the concept.... one less bit of software to install :-D
Hi @boelle, what kind of boards are you trying to use? For now we only support official Arduino and Genuino boards, we will support 3rd party HW in the future. Thanks for your feedback!
Why do you not support iPads (or tablet from other brands) with the editor.
Currently it stops while loading with the hint of not supporting resolutions less than 1024px!
Strange when using an iPad Air 2.
Would be nice using editor while mobile and using a lightning2usb jack for connecting to board when at home.
Hi @mamu, we are working on that right now, you'll have a version that you can use with screens less than 1024px hopefully in the next few days, but please note that the app is not optimized for touchscreens.
Sounds promising! But what does it mean "you can use with screens less than 1024px". An iPad has a resolution of way more than 1024px.
And will you support or add a plug-in (app) for the iPad so that I can connect my board to it by using an usb converter jack?
Hi @mamu, an iPad plugin is not yet in our road map but I am adding it in the wish-list, thank you for your feedback!
Thx
How about directly supporting Dropbox or Git for importing existing sketches or for versioning the code?
I could think of a scenario where one locates the whole project as a zip-file on Dropbox or Git and could import it to the create web editor environment.
That would ease the jump start.
Yep! it is in our long-term plan, thanks for your input!
First thing I noticed was the default addition of the ReadMe.adoc tab on new sketches. I like the idea of standard documentation.
This is probably low on the list of things to work on, but the AsciiDoc markup was not working yet.
I don't know if everyone would like this, but I might be more likely to use it if there were a script for autopopulating the ReadMe file with my info and maybe some of the info it could grab like the files included, board used etc.
Yep, we have a plan for some auto-population of the Readme, it is in our long long list of features :)
What do you mean by this?
I would love to see an Arduino 'server' that would allow you to upload over the network. Support for this could be added to the board manager allowing full use on tablets that don't support a plug-in agent. Lots of other uses for a standard TCP protocol. Maybe this already exists and is just not integrated into the board manager?
I wish that the editor will allow/recognize urls in source comments so that can directly click on them to navigate to that url.
I use this for additional documentation or links to other sources like lib github sites.
BTW: the Arduino IDE does that already.
@Mamu good point! Opening a bug about the URL. Thanks!
Hello,
IMHO the feedback of the editor after it finishes verifying code or uploading to the board is rather less visible.
In the client app, people have the progress bar and the output panel that clearly display the result of the process.
Verbose (and not) output panel doesn't clearly show the finish of the process.
In case of error people have a red bar displaying the error message. All fine. Well done.
But, what about doing the same in green (green bar) in case of success?
I wish it could be displayed some green check or some green evident text that clearly shows the success ending of the process.
Thanks a lot and keep up with the great work.
Matteo
@interpeo
The output console is collapsed by default, but you can have it as in the Desktop IDE by selecting the option 'Always show output panel'. We can try adding the Success message on a green background and see how it feels like. Thank you so much for your feedback!
@00alis
Great, thanks!
Hello,
another wish here! Do you plan to integrate in the WE the actual version, fixed bugs and roadmap list?
I would like to see, directly in one linked page of the editor, the infos you post in the first entry of this forum: coming up, wish list and done/solved issues.
Thanks again.
Matteo
Makes a lot of sense, adding a feature request for this on our repo. Thanks Matteo!
Fine! Good to know that!
Can we bring in an option to extract C/C++ code behind ?
:) live breakpoint debugging capability is something i am looking forward to
As for the built in libs, I would like to know / get displayed which version they are.
And will you update to the most recent versions?
And how, if they are no longer compatible?
The libs are always the most updated version, compatibile with the most updated core installed. We are working on the Library Manager similar to the Desktop IDE and you will be able to select a version from there.
@interpeo we just added a better feedback on successful uploads as you suggested, let us know how you like it!
Hello,
just what I expected for!
Thanks
what about things for 3d printers and quadcopters
An "EXIT" option on the client side pc software would be nice so I don't have to start task manager if I want to shut down the client for anything.
Also maybe a slight colour change for the client side toolbar icon as here its like a faint blob on the toolbar.
And no its not a custom toolbar colour either. its windows stock.
(https://drive.google.com/open?id=0B0ESkwqJ8U-TZHpHWEpya1Jud0U)
You may have to look closely LOL Arduino in camo (https://drive.google.com/open?id=0B0ESkwqJ8U-TRzlCcEktNmZOaUU)
K tried post image here but sorta fails so link instead
It will be great with themes in web app and desktop app, because white background is very ugly and eyes can get pain.. White stinks. Dark colours are great and neccesary for me.
@Ballscrewbob, opened issue https://github.com/arduino/arduino-create-agent/issues/107
the plugin repo (agent) is public, if you find other issues with it can open issues there if you are familiar with github
Could you elaborate on the "EXIT" option?
thanks!!
@MariuszPL5400 you can switch to dark theme from the preferences panel
What I lack, is an Arduino online sumulation. That would allow to check working process, before reducing upload cycles of the hardware.
thanks!!
The agent only has 4 options
Go to Arduino Create
Open Debug Console
Agent version (greyed out)
Pause plugin.
There should be a fifth one to EXIT the agent.
And maybe one to adjust settings eg. "Start with windows (tick box)"
@Ballscrewbob oh now I get it! Yes instead of Pause we had kill but then people told us they had a hard time finding the plugin again on their machines. So Pause turns it grey but actually EXIT it.
When the icon is grey the options are:
- Open
- Kill
Kill just remove the icon from the bar :)
Thanks hadn't noticed the two stage kill duhh
Odd way but it works LOL
UPDATE... I see what you mean about not being able to find a start option after you kill the agent.
Its not a long process to create a shortcut, see below which worked for me.
Create shortcut to IDE agent.
Most taskbar programs make a shortcut in the programs list however here on Win7 X64 it didn't
I wanted to be able to shut it down and open it as I wanted.
Here is what I did.
1. Locate IDE Agent. usually in C:\Users\yourname\AppData\Roaming\ArduinoCreateAgent (unless you have split install of windows)
2. Right click and select Copy.
3. Return to dektop.
4. Right click and select Paste Shortcut.
Now change the ICON
1. Right click your new Arduino Agent shortcut and select Properties
2. Make sure you are on the Shortcut tab and select Change Icon.
3. If you get a pop up box click OK
4. You can either choose a default icon from the selection or click the Browse
If you want the proper Icon click Browse.
5. Browse to the path at the top (it may already select the correct path)
6. Select the tray_iconWin then click OK
7. Click OK again
8. You should be back on the properties page for the shortcut again and now just click Apply then OK.
Whilst this is for Win 7 the process should be similar for some other versions of windows.
GitHub integration!
Cut and paste anyone ?
Would be great for slicing code chunks, passwords, long keys, etc.
@Ballscrewbob are you encountering issues cutting and pasting?
@ 00alis
Yep sort of
I can COPY from the web IDE CTRL C and paste CTRL V into things CTRL X mostly works but I don't seem able to always CUT.
The cut is sometimes hit and miss but mostly it works.
I miss the mouse only CUT, COPY, PASTE commands per se on the right click drop down menu. So its more a "wish list" item.
Offline Modus !!!
Online is rubish. Installation and configuraiton for unexperienced users is also rubish,
I don't see any benefits from using cloud service to compile simple stuff for
micro controllers.
So repeat: Offline is the the better cloud.
BTW: I didn't work for non-admin users on my Win 8.1!
And what's about Linux?
@ f41_ardu
I think its still too early in development to actually call it rubbish.
It has an awful lot of potential especially for educational users.
I use both on and offline.
Support issues tend to get looked at pretty quickly from what I have seen so far.
They seem to have managed to get it running on raspberry pis (with small workaround)
So linux would seem to be supported in a limited fashion.
Give it time is my advice the girls and boys in the backroom are doing thier best.
Some clarifications.
Both Linux and Windows are completely supported in the last stable version (Ubuntu 14.04 or 16.04 and Windows 10).
To avoid using the Admin installer there is a workaround (the admin is needed to install certificate at the system level).
You can go here:
https://github.com/arduino/arduino-create-agent#development compile your version and in that case you will not need the Admin installer. You can just run the script. The fact is you will not have the certificate installed so you have to manually import it going to https://localhost:8991/ (https://localhost:8991/) in your preferred browser. After you correctly added an exceptio or you imported the certificate manually, then you can access to the editor with no need of Admin role.
Thanks,
Luca
@f41_ardu we will always support an offline version, no worries about that. Let us know if you have specific issues/feedback on the first setup we can work on and improve.
Thank you @Ballscrewbob for the support!
Hello,
as an idea, in the link below you'll find a simple script to automate writing main code blocks (if, for, while).
It would be a feature I espect, also in the client IDE, considering it an alternative to code intellisense or code hint.
Please, feel free to check the script at GitHub and implement or enhance it:
https://github.com/matteopasqualin/webeditor-2016
Thanks
I would like to have the functionality of graphs (like graph of values in Serial monitor vs time) and logging of data, so it could for exams log light intensity values reported by arduino vs time, so we could graphically see how it varied over time.
Also it'll great if you guys could include the functionality of tabs in offline Arduino editor also, so that we can switch to different sketches rapidly (and not open each one in a separate window).
Thanks
Hi @abhishek_nigam,
thanks for your feedback! The Serial Plotter is in our road map!
+1 Chromebook plugin. Cheap Chrome laptop + cheap Arduino board = (almost) universal access
Please add cut/copy & paste in the right click menu.
I think, it's already mentioned.
But support for third party boards would be nice.
Especially ESP8266 boards... (Wemos D1 Mini)
Thanks.
mfg
Chris
Hello,
I would like 3rd party support via an API. This way the Web Editor could be integrated with other systems, but the sketches could end up in Arduino Create regardless. I am specifically thinking about block-based systems and other systems that are made especially for teaching purposes.
Very Best Regards,
Joachim Haagen Skeie
hello everyone, i just installed web editor and will be using it for now to try out
Is it slower the the arduino IDE?
Can i update libs on it?
it is actually very quick and you can import libs etc
I'd like to vote up Chromebook integration.
Hello everyone,
Is there a way of editing the Custom Libraries? I think it would be helpful if we could edit the libraries just like any other sketch.
For instance, I uploaded an OneWire library that is not working OK in the web editor:
(/tmp/webide_tmp536567/libraries/OneWire/OneWire.cpp:83:21: fatal error: arduino.h: No such file or directory
#include <arduino.h>)
Since there's no way of editing it I have to re-upload it as a zip file after I modify it on the computer.
Thank you.
Hi @bogdan90211,
we are going to implement library editing in the next weeks! Keep following the forum for updates
Thank you!
Any chance of implementing mouse cut/copy/paste in the web-based editor?
I second dbkaynor's idea rather than CRTL V & C etc.
Change the color of the comments in the editor. Light gray on white is too soft.
@ Franck1048
There are two theme options under Preferences.
Dark and Light.
I do agree that a couple more options might be nice to have though.
@Franck1048 we have already in our roadmap the implementation of the most common editor schemes, thanks for your patience!
It would be great if this tool worked on Jetson TX1 and TK1.
An item for the wishlist:
Show the memory usage (flash) when compiling for the Arduino 101.
@Mike44449 Yes, good catch. The memory usage is not shown in the desktop IDE either, there will be a new 101 SW release soon and both the web and desktop IDE will print that info in the output. Thanks!
It would be really useful to have Google Docs esque collaboration features, especially when you have team projects.
Thanks !!!!! Love it !
Iv use putty as a serial monitor, just to have some basic vt100 escape sequences.
To have just the basic commands would make the serial output much more useful, like this ones.
And a check box, to enable o disable the VT100 function..
// #################### setColor #######################
void VT100_SetColor(int xpaint)
30 Black
31 Red
32 Green
33 Yellow
34 Blue
35 Magenta
36 Cyan
37 White
Serial.write(27);
Serial.print("[3");
Serial.print(xpaint);
Serial.print("m");
// #################### Locate #########################
void VT100_Locate(int xrow, int xcol)
// Row, Col
Serial.write(27);
Serial.print("[");
Serial.print(xrow);
Serial.print(";");
Serial.print(xcol);
Serial.print("f");
// ##################### CLS ##########################
void VT100_Cls()
// VT100 CLS
Serial.write(27);
Serial.print("[2J");
Serial.write(27);
Serial.print("[;H");
// ##################### Cursor_Off ####################
void VT100_Cursor_Off()
Serial.write(27);
Serial.print("[?25l");
// ##################### Cursor_On ####################
void VT100_Cursor_On()
Serial.write(27);
Serial.print("[?25h");
Any nfo on why this was overlooked?
Hi @NonaSuomy,
we opened an issue about that and we'll try to implement it as soon as possible
I hope the Chromebook plug-in has a high priority on the wish list.
Upload Project documentation as PDF files.
I have tried uploading PNG images of an A4 portrait page containing my circuit diagram, it works but the resulting image is too small to use.
I have 10 pages in my design and it looks like I can only save 3. Is this a size or quantity restriction?
A simpler solution would be to be attach a PDF file (or files) to a project - this would be easier than providing a link to an external location.
(It does not need to be displayed, just downloadable).
Have you tried JPG ? IGNORE its not letting me use JPG's anymore
It seems a little better than PNG. (it did)
By 10 pages do you mean tabs ?
For files there is a limit size per individual file of 10 mb I think and you can also use the 4 way expansion icon to get more screen room.
Landscape seems better too.
@notdodgy I added the ability to add PDF files to the wishlist, thanks for letting us know.
Please not that you can also write a tutorial on create.arduino.cc/projecthub and add all the documentation you want. If you paste your sketch URL in the software section of your tutorial a button that points to it will be displayed in the Code preview page, for details look at this tutorial (https://create.arduino.cc/projecthub/Arduino_Genuino/how-to-submit-content-on-arduino-project-hub-cf2177?ref=user&ref_id=65561&offset=10)
@Ballscrewbob I can add JPG no problem, there is instead a problem when adding images bigger than 2 MB, we are investigating it. Thanks!
I really like using the Web IDE. I've started using BitBucket for a project I'm working on. The problem I have encountered is that the Web IDE will only download the sketch as a zip file which also includes the ReadMe file and a .json.
Once I've downloaded it to my computer I need to open it and move the file to my .git folder. I've gone back to using the regular IDE as this method adds too many steps.
Is there a way to an option to export only the .ino file?
Thanks.
I'd love to find
- Auto Format command
- ESP8266 board support
thanx guys! :)
Global variable size and usage is now displayed in the output area for every compilation :)
Thank you for adding new boards since I last looked.
I have a request that would allow me to be more inclusive in my education practice on a shoestring with low income urban youth of color.
I would love to add ATTiny 85 as a board because while we use full size Arduinos teaching skills and for group projects, I would love to do teaching activities for my low income youth of color that they can take home --- I found a source for ATTinys that makes it affordable enough that I can let individuals take them home!
Why on Arduino Create online?
Codebender made the whole teaching of microcontrollers possible. We deal with so many different kinds of computers and old computers and different community organizations that mess with computers all the time. So keeping on the latest version of Arduino IDE + libraries + plug ins + code was a huge obstacle. If the coding environment is online and if youth can build a library of "starter programs" as they learn and not have to worry about where the latest version of their program is, it makes a huge difference.
Thank you for considering.
Dear
@zackboston thank you so much for your email. You made a great point about supporting ATTinys, unfortunately we are only supporting only Arduino boards and their cores for now, with ATTiny we will need to implement an external bootloader, so we need to schedule that feature first. I am totally going to bring your case to the management and hopefully we can find a way to schedule this implementation in the near future. Please keep your requests coming as this way we understand where the platform needs to go in the future.
Best!
copy/past with right click
Codebender user here. We use(d) it for lessons in class.
In class, students view and run read-only sketches from the teacher's account, and then the students clone those sketches into their own accounts to make modifications.
The students have a bookmark to the teacher account's folder of example sketches.
Is there a way to create a shareable link to a folder?
Thanks,
Ken
@ kaspesla
Its already there.
See the SHARE button right next to the board selection box.
It gives you two options both of which you could use as you describe.
Hi
@kaspesla we currently don't have a sharable link to a folder, adding it to our education-related wishlist.
Thanks so much for letting us know!
Okay, from the first message I can see that ESP support is not available.
All my boards are ESP so I do need that to go forward.
Thanks for all your work.
Walt
I'd like to use my arduino with my chromebook. I'll ansiously wait for the plugging
Hi @maurober, @NonaSuomy, @dbkaynor,
we just deployed an implementation of copy/cut/paste buttons with right click on the editor, let us know what you think about it!
it would be awesome if you made the arduino ide on the PC and mac to have this new format. The create.arduino is very great
Ditto on ESP8266 and add to that ATTiny support!
Please support the Sparkfun Digital Sandbox. This is an excellent starter board for learners, and it would be great to be able to use it with the web editor.
need to print from editor would be nice
Hi!
I am missing these features:
- AutoComplete
- Search and replace
- Github/bitbucket integration
- Print
If you could add these features, it would be lovely!
@ cog3981
You might want to play with it a little more...
(http://forum.arduino.cc/index.php?action=dlattach;topic=361376.0;attach=198803)
For PRINT I just C/P out to notepad or the regular IDE..Couple of clicks and done.
Additionally there is some "limited" git already in there.
(http://forum.arduino.cc/index.php?action=dlattach;topic=361376.0;attach=198811)
Too bad the Arduino Web Editor does not support:
1.) Chromebooks (as used in our school district)
2.) BlocklyDuino / BlocklyDuino Enhanced / TUNIOT and/or related Scratch-like
block oriented programming languages.
3.) LiquidCrystal_I2C library. There should be a way to import the 3rd party
Libraries already set up on your PC. The supported 3rd party libraries are
a very limited subset of what's out there. My choice of libraries used is
usually affected by the tutorials (text & video). If they use an "odd-ball"
library to get the job done, then I will likely use it. I don't like being forced
to re-learn how to adapt other "supported" libraries, some of which don't
offer all the functionality I'm looking for.
That's all from my first look at Arduino Web Editor. Seems I'll have to wait
awhile before adopting it. If I'm wrong on anything, let me know how to do it.
@ randmor.
Android is in the pipeline so yours and a lot of other peoples voices have been heard.
Importing 3rd party libs is already there too and has been for a while.
(http://forum.arduino.cc/index.php?action=dlattach;topic=361376.0;attach=198813)
As for third party languages I think you are going to be waiting for that as its not really something I can see them doing at this point in time. However stranger things have happened.
BTW you lib is already available in CREATE...just had a quick look to be sure.
Try playing with the Library manager a little...It always surprises me
@Ballscrewbob:
Very nice! Thanks!!!!
The missing import library would have been the next but it is not relevant!
@ cog3981
I only just realised another nice feature today...You can select lib versions too !
A much needed bonus feature for me at least
(http://forum.arduino.cc/index.php?action=dlattach;topic=361376.0;attach=199320)
An online simulator would be hugely helpful. Even just a way to "upload" to a simulation board and read the serial monitor.
@ raschke
Think that would be a project all of its own and a very large one at that.
There are a few threads in some other parts of the forum with regards to the specific topic of simulators / emulators.
They might be worth your time following up to see where people are on that aspect.
Why don't you see if you can use the work already done by codebender for their web programmer's plugin that makes it support chromebooks?
@ Drago_Nightwing
I think since they went "COMMERCIAL" the code will more than likely be proprietary and they would probably not want to share it unless they were getting a good chunk of profit out of it.
That would be my personal take on it.
Plus 100 for the Chromebook plugin!
Not just for my own personal interest either. There are a ton of schools moving to Chromebooks and it's essential that they are able to use the Arduino Web IDE as the Arduino is still the best gateway to an interesting and exciting STEM education.
With the death of codebender.cc this need is greater than ever as there are schools that were already using the great Chromebook Arduino combination via codebender's web based IDE.
We need a replacement ASAP before these schools abandon either the Chromebooks, or the Arduino, or both.
Thanks.
Chromebook plugin would be very nice, now codebender is shutting down and interferes with old libraries.
As others have suggested, I would like to see the capability of using the Serial Monitor for such functions as Serial.print() without needing a board or USB connection. I have discussed this topic elsewhere (http://forum.arduino.cc/index.php?topic=465008.new#new) on the Forum.
@DonpK, isn't that a Create forum discussion specifically, and not so much the IDE in general?
Indeed it is and a crosspost too.
Was hopefully discussed HERE (http://forum.arduino.cc/index.php?topic=465008.msg3190896#msg3190896) to about the fullest extent possible.
Yes, my link was to a Create discussion about using the Serial Monitor. Isn't this wishlist for Create? Perhaps I'm misunderstanding your point, CrossRoads.
I included that link to provide those interested for more information "to the fullest extent possible". Since that discussion concluded that my suggestion wasn't possible with the current Create configuration, I'm presenting it here as an idea for a future Create feature. Is there a problem with doing this?
Oh, I didn't look at the topic link close enough:
Arduino Forum (http://forum.arduino.cc/index.php) > Products (http://forum.arduino.cc/index.php#c14) > Create (http://"http://forum.arduino.cc/index.php?board=105.0") > Editor (http://"http://forum.arduino.cc/index.php?board=101.0") (Moderator: smellai (http://"http://forum.arduino.cc/index.php?action=profile;u=303395")) > Wish-list and ideas (http://"http://forum.arduino.cc/index.php?topic=361376.0")
I saw Editor and thought it was just for the IDE. You're good, my error.
@ DonpK
Its just repeating an issue that has been discussed in another attempt to get a second opinion IMHO.
The wish list AFAIK is quite vast and many of them I personally doubt will ever see the light of day or will not take precedence over more important matters.
Your idea has already been noted via the thread itself.
Thanks
@DonpK for your suggestion, I have added to the summary in the first post of this thread.
I would also really love the web editor to support esp8266 boards. Any idea if and when this will happen?
@MortenCopenhagen
If I had my way it would be top of the list.
It stops me making full use of CREATE not having them.
Seems it has been requested a few times but I think it is out of the hands of those who can make it happen.
How cool would it be to have a digital graphical bread boarding simulation similar to multisim. I'm not sure if there is already software like this for the Arduino but man it would be so nice for planning out projects before pulling out all the boxes of parts. I imagine it would be a great platform to save and share circuit designs as well if you only have one board and multiple projects running at once.
Actually if someone reads this and knows of a piece of software to Sim the Arduino Uno... Let me know!
@riggy
This wish list is more dedicated to the CREATE platform so I doubt it would be added and if it were it would be way down the list.
However it is mentioned in a few other sections more appropriate to your wish and even a few sources for such things. Just type simulator into the search box provided for you at the top of this page.
Dont be put off that it takes you to google as the results are from the forum.
I truly hate that it jumps to google as that puts a lot of people off using it but it is all we have around here for now.
Happy hunting for your simulator but be aware that they do seem to be a little limited in functionality for the most part IMHO.
I would like to have the boards manager to download some boards, such as ATmega or ATtiny.
+1
i would like to see the option to upload sketches to boards via ISP.
+ 1 for roboter32
+ 1 for bconfort
There could be more room for the code editor. Currently the edit area is too small, takes only a quarter of the screen. Maybe other UI elements (i.e. buttons, side panel) could be more compact?
Otherwise it's really enjoyable to use!
lingkaidong
You can size the panels.
Thats been a feature for quite a while now.
You can even temporarily disable sections too !
Just made a quick video for you here (https://youtu.be/uIOHFWi73q8)
You have the fullscreen mode too, check the attached screenshot
It would be nice if users could vote for wishes from a wishlist. Of course IDE developers should remain free to set the priorities, but I think it would be helpful. As for my own wish - sketch upload from Android devices to Arduino - I think I read about this wish somewhere, but I don't know if other users want it as bad as me. A (working) alternative for me is ArduinoDroid but it needs more care for program/library updates and the latest version is running only in Android 5 and higher. Being able to change code on the fly only with an Android phone or tablet is really a nice feature, especially if the Arduino is built into a mowing robot, a rain sensor, a wearable device ..
Hello,
about the "Scratch or blockly-like coding environment", I'm the creator of Blockly@duino (https://github.com/technologiescollege/Blockly-at-rduino (https://github.com/technologiescollege/Blockly-at-rduino)). There are also another projects based on BlocklyDuino & Blockly new version :
- arduBlockly (https://ardublockly.embeddedlog.com/ (https://ardublockly.embeddedlog.com/))
- BlocklyDuino Enhanced (http://easycoding.tn/index.php/arduino/ (http://easycoding.tn/index.php/arduino/))
- MixlyArduino (https://github.com/xbed/Mixly_Arduino (https://github.com/xbed/Mixly_Arduino))
- etc
I think the real pb is to communicate with Arduino IDE easily, without adding Python server (most common choice). Arduino has tools like Arduino Create but how to interact with???
I added the Codebender plugin many months ago...but it's not a valid solution.
So a part of job is finished, miss just few code to interact with.
Regards,
Sebastien Canet
It would be really useful if a zip file could be uploaded with all the project with things like PCB layout files, schematics, images of the hardware, notes, etc. Integration with dropbox and github is not the same thing as having it in one location. Dropbox and github may be popular today but who knows about tomorrow.
AC9NM
You can incorporate those items with the tabs in create.
There are a couple of caveats though as picture sizes can crash a sketch if they are too big.
They can also slow down CREATE a lot too at your end.
Notes are also easy in CREATE.
I haven't tried a fully tabbed upload with a zip.
I tried a simple test of downloading a sketch from CREATE in which I included both pictures and text of different types.
Then "uploaded it back to create and it did bring everything back in. I had changed the file names of the folder and sketch to prevent a conflict of file names with the existing one
Changed the following. Zip name, sub folder name, sketch name eg "Example1.zip" became "Example1B.zip", Folder and sketch also became "Example1B.zip"
Please send me a dht11 code
@LakinduChamathka
It is up to you to provide code.
There are also lots of examples around the internet if you search.
Hi!
Still, I am missing these features:
- auto indent such as Ctrl+T in Arduino IDE (sometimes I copy-paste codes and it takes time to indent the code)
- code completion
- a bit bigger editor area, for me the TAB area eats more space
Besides my wishes, I really like the Web Editor!
Hi @cog3981,
about a bigger editor area, you can use the fullscreen button in the top right of the editor or you can close the sidabar
Yes, I can. Thank you for your suggestion.
I realized that I can also hide the output window but still I feel the TABS area occupies more than necessary. But I admit that I have 14 inch screen on my laptop with high resolution so I scaled up the fonts in my browser. That might causes a bit bigger area occupation.
Is there any way to change the color of error text from red to something legible like yellow?
+ Vote for adding schematics and simulating the firmware and common circuits
+ Integration with Upverter would also be nice if adding support for schematics
Maybe more of a known issue than a wish-list, but the installer deployment method is too complex, has a couple of bugs, and/or potentially insecure to deploy for all users of a system, particularly for users without administrator rights. I outline the problems with it here: http://forum.arduino.cc/index.php?topic=415177.0
I would love to be able to store my sketches on Github and edit them with the online editor. Is there any chance of an integration with github?
The Github integration is on the wishlist, it is definitely a super interesting feature but it is not in our immediate roadmap. Thanks for your suggestion!
i wish i wish,.... for Microduino boards to be added. This would make it an ideal setup for STEM workshops.
im triggered
Hello,
I've only just become aware of the web-based development environment. It feels a bit clunky but that's partly me not being familiar with it. I like the colour coding for the text.
Id like to see some form of Auto-complete added to the editor. Something along the lines of what I see when adding/editing formulas in Excel. A great addition would be something like the 'variables' etc being auto detected by the environment then automatically added to the Auto-complete list.
Just a thought anyway.
I don't know about plans for the web editor but this has already been done for the standard Arduino IDE. You can try it out by downloading the beta version here:
http://www.arduino.cc/en/Main/Software#beta (http://www.arduino.cc/en/Main/Software#beta)
you activate auto-complete by pressing Ctrl+Space.
Note that this is still in the testing phase so it's not guaranteed to be 100% ready for use. If you do try it out and encounter any problems please report them so the developers can make a fix.
It would be REALLY handy to be able to use 'Arduino as ISP' for programming pro-micros, etc.
Also the ability to burn a bootloader.
I will whole heartedly support Ardii's wish.
Consider this a +1
I needed to replace my Leonardo bord for connection issues that sometimes plague them, I got a seeeduino from adafruit because that is what they recomended.
I wish to add the support drivers. As I cannot do it my self.
https://github.com/Seeed-Studio/Signed_USB_Serial_Driver
Post from @RussellandSusan (and @pert) merged.
Please add the boards manager! Allow for custom boards!
ESP32 and ESP8266 would be awesome!!! Also, add a plugin version that can be used on raspberry pi. Allow for custom coloring over the editor would be nice... (Be able to set your own bg colors...) Edit 2 files at once? Mostly just the boards manager though... I would love to be able to use ESP board with the editor!
Can there be an option to adjust the compiler flags before compiling and uploading the program. I'd like to be able to set debug macros before compiling my applications
Would like to see support for the plug-in to run on an OS that can run on a Raspberry Pi 2 or later.
I see it already on the wish list, but as a STEM educator in a school moving to Chromebooks, having the serial plotter available on the web editor would be HUGE! Graphical analysis of the data we collect with various sensors is a hugely important skill for my students at all grade levels. Thanks for your continued support.
Add my vote for either a Board Manager option, or add more of the Adafruit and other partner boards. I'm a fan of the desktop IDE, and the MS IDE App, but I'm exploring the web editor again. My current project is teaching a grade-9 class (13-14 yrs old) using Adafruit Adalloger M0 (for speed and memory and SD Card and battery reasons). It's been hard trying to get 30 machines set up consistently with the IDE and USB drivers needed because students don't have Admin credentials on the machines. I was hoping that the Web IDE could make this issue easier.
As I write this, I'm thinking that the web editor might not be able to help the USB Driver issues, but adding boards for other vendors might still invoke the need to add USB drivers for some non-Italy boards. It's probably a bigger problem than I see from my chair tonight.
Thanks for the efforts you put in, and for considering adding at least more boards...
Hi! I am a teacher, and I have been wanting to work with Arduino boards with my students for a little while, usually in the context of having my beginner-level computer science girls create a wearable to get them hooked into coding. It seems that creating most wearables involves some complexity that is a bit above the knowledge and skills level that a young beginner would have during their very first-experience with coding. It's been a bit of a pardox, because creating and coding wearables is a great hook as a first experience to get girls interested in learning about CS, but you have to know a little bit about CS or have someone mentoring you who does to be able to create your first wearable. A couple of weeks ago, I I discovered Jewelbots, a ready-to-go wearable that uses the Arduino IDE and masks any complexity that is normally involved in creating and coding a wearable! After working with Jewelbots for the past week and a half and experiencing success with the with the Arduino IDE, I now am feeling confident enough to try more Arduino boards in the future! I imagine that every Jewelbot user is probably gaining that same self-confidence and positive self-expectancy with Arduinos. I would consider Jewelbots board as an Arduino "gateway board." I would like to use Jewelbots with my beginner-level students to introduce them to coding and making with Arduino. However, right now, the Jewelbots board is not yet available on the Web Editor IDE, and I would like to request that it be added. Adding the Jewelbots board on the Web Editor IDE would be most ideal for beginners because using the Web Editor IDE yet again masks the complexity that a beginner might experience downloading and configuring Arduino software. Also, students can easily then access the Arduino Web Editor IDE from both personal and school devices. Being able to get started right away on the Web Based Arduino IDE means that the young users (and their parents and teachers like me) will immediately have a positive first experience with this Arduino "gateway" board, which builds confidence trying a more complex Arduino board in the future. How may I go about requesting that the Jewelbots board be added to the Arduino Web Editor IDE so that I can use this with my students? Thank you so much for any help that can be offered!
@Deanna
I looked at this jewelbot.
A little disappointing it doesn't seem to be based on an existing MCU or mention the MCU type.
You might be better off looking at the GEMMA as they are much more versatile sew-able and expandable.
They are also much better supported throughout the Arduino world and would let those girls with a little more imagination go a little further.
Given the scenario you laid out the GEMMA would be a much better fit and also fall within many curriculum in other terms of reference.
That last bit would allow you to see the more gifted girls easier. That makes a teachers job a lot easier too.
I find it hard to see it as a gateway board and much more of a toy, but thats just my opinion.
Thank you for the kind words, Deanna!
Hi All,
Creator of Jewelbots here, thanks for all your comments! Jewelbots has been a labor of love for years and has been open source since day 1. Jewelbots was created after speaking with over 200 girls in our demographic and asking them "what can we build for you that would inspire you to code"? What we heard from them across the board is that the most important thing in their lives at this age are their friends and friendships. So, we built them smart friendship bracelets that react to their friends, allow them to send secret messages, and allow them to code whatever they can come up with given their imagination.
We used the Nordic nRF51822 chip as the size was most compatible with making something for tiny wrists (the chip and the antenna are 4mm x 4mm). We made sure that it was compatible with the Arduino IDE as we're huge fans of Arduino and open source in general.
@ballscrewbob thanks for your feedback! GEMMA are awesome tools for learning. Jewelbots has significantly more functionality and capabilities including Bluetooth, 4 RGB LEDs, and a vibration motor. With it users have created metronomes, games, and all kinds of custom friend interactions. GEMMA is awesome for beginners, but Jewelbots are much more flexible and allow you to build many things the GEMMA is incapable of.
Though, we would agree, we definitely are a toy, and that's the best part. Of the users that pick up Jewelbots, 100% of them use them as toys, and 44% of them sit down and code them. Our underserved demographics are finally being exposed to things that are both feminine and technical, many for the very first time.
We would love the ability to upload custom boards to the Web IDE for use on Chromebooks as well!
Jewelbots have been a fun and awesome way to engage young women in coding through our non-profit, Kansas City Women in Technology, and being able to use the web IDE will help us with families with group books or with work/school computers with no administrative privileges for downloads.
If there's anything the software developers on our teams can do to help make this happen, we'd love to know how we can contribute!
I agree with Deanna, SaraJo, and JenniferWadella: I would love to be able to use Jewelbots with Arduino Create so that we can use our classroom's Chromebooks and not put the burden of purchasing a laptop on the students.
Another voice chiming in who wants to include Jewelbots with the Web IDE in our curriculum to teach teens to code. The library provides us with Chromebooks for use in our programs. They do have some Windows machines available, but they do not have permission to install anything. Also when students are provided laptops in school, they do not have administrative privileges, so our curriculum options are limited to what we can do on the web. We use the Cloud9 IDE for other development projects, so we know that this kind of environment works well for our students.
Clearly something quite odd here about the jewelbot posts.
Having been a quite close member of this section of the forums for some time I have NEVER seen such a concerted effort to gain traction for a single board.
But in fairness to sarajo.
Nice that you should mention the Chip used and maybe you should also mention much clearer on your web sites what you use.
It is still not a "mainstream" MCU in the Arduino world And as you yourself say it is a "toy".
It does have some decent capability but doesnt fit as well with the STEM programs often used in education.
I also find the demographic exceptionally small and seeing as it only seems to have quite recently come out of the KS system then myself I dont see it becoming a part of "additional boards" until that demographic is very much larger.
However I must stress those are only my personal opinions and NOT that of Arduino.
Our company sponsors robot clubs in local middle schools in conjunction with City Year.
The robots have been a hit; however, the Jewelbots have been very popular with the young women and have increased retention. Unfortunately, the Ardruino setup requires non-school laptops to be used which is limiting our ability to bring the technology to more locations.
The schools we are working with are Title 1 locations and neither the school nor student can afford laptops. There are a very limited number of Chromebooks that we use during club time. The robots are utilizing micro:bit and makecode. Having a web-based option for Jewelbots would allow us to roll-out their use to more locations and retain more young women.
If there is something we can do to help make the board set available in the Web IDE, let me know!
Hi ballscrewbob -
I don't think there is anything odd. Jewelbots have made a good impression with a number of professional programmers.
Working in constrained environments like a school can result in some trade-offs. Hearing that there might be an opportunity to remove one of the largest road-blocks we hit encouraged me to post my vote.
I'm unsure about your assessment of demographic. Middle-school-girls is a hugely important demographic to the success of STEM and diversity in technology. All women programmers have passed through or will pass through that demographic at some point.
Just the tiny sample size of 200 would be my biggest concern.
Totally agree with more women in the IT field and I think you would be happily surprised by diversity of the team involved behind the scenes of CREATE.
I just find the "concerted" effort a little too convenient to be just accidental.
That may be my background as a detail orientated person and longevity on the internet / pre internet kicking in.
Please be less suspicious, I think it is not that odd.
I do not know jewelbot, but this is exactly how new things get momentum. And apparently jewelbot has allready a group of active users. Maybe that demograpic is or looks small but I recall in 2009 when I started reading this forum there were less than 100 visiters a day (now it are thousands). And Arduino started with a group less than 10. Partly with the goal to educate people and have fun. I see something similar with jewelbot.
Best thing you can do if you want jewelbot embedded into the IDE is to raise an issue and explain your goals in github.com/arduino,
or better make a pull request so it can be integrated without effort. After all it is open source. Be aware that it can (will ?) take plenty of time before reactions come.
Second thing to do is to get onto the developers mailing list of Arduino and make your point.
Finally I would advise to show what you can do with jewelbots in the exhibition section, to get more fans.
Note that this merge into Arduino will only really work if jewelbot is open source/hardware and I just don't know if that is the case.
Another interesting route could be to contact Lady Ada from Adafruit.com - she is very interested in new tech trends.
This is also my personal opinion
(lines ommited)
There have been "concerted" spam attacks in the past so I understand your reaction.
What you are seeing is the reaction after this Tweet:
https://twitter.com/SaraJChipps/status/966019190254694400
(https://twitter.com/SaraJChipps/status/966019190254694400)
Thanks for all the kind words, all! Hopefully we can surface some more community folks who would also appreciate our boards being added.
Thanks for adding the reason I was suspicious.
Had I seen that earlier I might not have been so.
But as Rob pointed out...To get the traction you need you need to go to such as Github etc and raise the issues over there.
Flooding a forum might not get the reaction you desire.
There are ways and means and Rob's is the best way.
Get the developers for Jewelbot to talk to people in the proper places.
Send you a PM
Actually this is about adding Jewelbots (https://jewelbots.com/) support to the Arduino Web Editor. AFAIK Jewelbots have already created a boards support package that makes it easy to add Jewelbots boards to the standard Arduino IDE:
https://github.com/Jewelbots/arduino-library (https://github.com/Jewelbots/arduino-library)
In fact the Arduino Web Editor developers have specifically stated that the Create > Editor forum section is the place where they want to track bugs and feature requests generally related to the Arduino Web Editor:
https://github.com/arduino/arduino-create/issues/1 (https://github.com/arduino/arduino-create/issues/1)
Although some parts of the Arduino Web Editor are open source, unfortunately that part that would need to be changed is not.
I looked at Jewelbots a while back and it looks pretty cool! You have the option of using them at a very basic "toy" level level to get started but it doesn't stop there because you can progress to writing firmware with the Arduino IDE or even go beyond that as far as you like.
Just a couple days ago I listened to an interview with someone who worked on the project:
https://www.embedded.fm/episodes/173 (https://www.embedded.fm/episodes/173)
It's probably not the best overview of Jewelbots since that's not really what the interview was about but I thought it was really interesting hearing about the an experienced programmer's first encounter with embedded systems. Even though that's not how you would ordinarily expect an electronic product to be developed, by the end I found myself thinking this was the perfect person for the job because, in addition to having the skills to do quality work, he also had the learning experiences which I would hope would provide a better understanding of the user experience. I think that often the people with the most knowledge have forgotten what it's like to be a beginner and thus have a hard time making things beginner friendly.
Thanks for a more independant POV Pert.
@ballscrewbob this an appropriate place to discuss Jewelbots boards, as the issue many of us are facing is due to the inability to upload custom boards to the web based Arduino IDE. Our Jewelbots sessions are currently selling out with tons of people interested, and we're trying to do our best to ensure those on all types of laptops can participate.
Right now I see at least THREE voices from Jewelbot themselves including yours.
There is a saying that "Too many cooks spoil the broth".
Not sure why most of the jewelbot team need to try speak as a crowd.
And BTW I was NOT the first to suggest an alternative source for discussion.
May I respectfully suggest you pick ONE member to speak on behalf of your team and stick with it.
Just to satisfy my curiosity what Country is this jewelbot primarily based in and targeted towards.
^ Just to clarify I do NOT work for Jewelbots. I run a non-profit organization that helps get more women into tech careers, and we run a program called "Coding & Cupcakes" where we teach girls to code with web development workshops and Jewelbot programming workshops.
Hey Bob,
Thanks for your question, right now there have been almost 11,000 Jewelbots shipped to 38 countries! We're all over the world. As far as team members in this thread, the only official Jewelbots employee that has spoken is me! We're super honored to have amazing community members leading their own movements getting more girls coding, and super happy to be supporting them as one of the tools they are using.
Thanks @robtillaart for your support. Much appreciated, glad you gave us the benefit of the doubt.
We do have our boards setup for the Arduino IDE, however, we don't have them on the web editor which is what is stopping students in schools from being able to code their Jewelbots with Chromebooks (though, we're also looking into other solutions). We're petitioning here as that's what we were advised to do, though, if there is a better way to get included in the web create interface we're super down to try that.
Thanks again for your help.
I posted on this forum wish-list to request that the Jewelbots board to be added to the Web editor because I have already evaluated the tool according to the CS curriculum and the existing research on girls in CS and found the Jewelbots to be an appropriate tool for achieving specific curriculum standards and goals.
Nothing nefarious, @ballscrewbob. Just a teacher trying to teach and use a tool that I have determined to be appropriate for specific CS curriculum standards. I teach several different levels of computer science classes on the software development pathway, from true beginners in middle school with no computer science experience to students with at least 3 years of coding experience who are earning advanced placement credit for college. From my 15 years of experience teaching STEM at the middle school and high school level, and my 12 years of curriculum writing experience, I am deeply familiar with the national, state, and local curriculum standards for science and CS. I am also very familiar with the research in engaging students in STEM, with a focus on the research findings in the last decade on engaging girls in computer science. Based on the curriculum standards, the research findings, and experience, educators such as myself select the appropriate tools for specific curriculum standards, program goals, and student needs.
The Jewelbot and the GEMMA are appropriate for use at different points in the CS curriculum, but they are not interchangeable in their use within the STEM curriculum.
The GEMMA is an outstanding tool for creating the wearables and other projects, and it requires that the students master skills in addition to coding including wiring and soldering sensors and actuators, and, possibly, as mentioned by @ballscrewbob, sewing, if the product is to be wearable. The GEMMA allows for great creativity to make whatever the students wants for creative projects, which is outstanding, and makes it a good tool for achieving specific curriculum standards. One appropriate potential use for the GEMMA in the CS Principles class curriculum is the "create" project.
Serving a different purpose, the Jewelbot is "ready-to-code-and-wear" wearable that masks that complexity of wiring and soldering sensors and actuators, as a button, Bluetooth, 4 LEDs, and buzzer are already built in. Also, the student does not have to learn to sew or craft to wear the product of their code, it is already connected to a wrist band. Therefore, I can use the Jewelbot on Day 1 in a Intro to CS class or club with true novices to dive immediately into the introductory coding principles covered in the curriculum, with no soldering, sewing, or other technical crafting skills required. On day 1, my students can wear out their coded product after only a 45 minute class, can work on it at home more if they wish, and then will return to class the next day to master the next introductory-level coding principles. The Jewelbot is a tool that I plan to use in my curriculum, among other tools that I am already using, for novice students who are mastering of introductory coding principles in the curriculum.
Again, the key for true novices is high engagement with masked complexity. Jewelbots are appropriate for engaging novice students in mastering curriculum standards in an engaging way which leads to their engaging in more CS projects, including creating projects using Ardino boards that do not mask complexity, including, but not limited to, the GEMMA. In my previous post, when I discussed the use of the Jewelbots as a "gateway" board, I was thinking of the GEMMA as one of the possible boards.
I posted the request for the Jewelbots board to be added to the Arduino Web Editor because I have determined that Jewelbots is appropriate tool for teaching specific CS principles, achieving specific curriculum standards and program goals in my introductory coding classes and clubs for young novices. I posted this request in this forum because using the the Web Editor would allow educators like me and our students to overcome the normal hurdles we encounter installing software on school-district PCs to which we do not have administrative access. My school district is 1:1 with Chromebooks as well.
I very much appreciate the responsiveness of @sarajo as well as the other educators, Jewelbots users, and members of this forum who have constructively advised ways to work towards getting the Jewelbots board added to the Arduino Web editor so I can use this tool with my students.
Thank you!
May I suggest to add a confirmation message to the select board command in the Editor?
For now, the box vanishes just after after hitting OK, so I never know whether the Create picks my selection.
Another suggestion is to include an option to de-activate self detection of the board, thus allowing a full manual selection or to link the selection to the profile of the user and not to the sketch.
Thanks for the web-software! I know is a difficult and long way effort.
for some interested in graphic arduino code generator, I've published a plugin to put in 'tools' directory based on my Blockly@rduino project : https://github.com/technologiescollege/BlocklyArduinoIDEPlugin
Hope this could help.
It would be great to be able to have more persistence in the editor. It is rather clunky to try to switch between multiple projects at the same time. IMO it needs a concept of project tabs. Try scrolling down in a long sketch, then open an example from a library, then try going back to your original sketch. The sketchbook by default goes to the top sketch, not the one you had open previously. That makes copying from examples and libraries inconvenient.
@joebutler10 you are totally right and we already have a task in our list for that, hope it will be solved soon, thanks for your feedback!
This is the list of stuff I find missing and would really like to see (in the order of importance)
1) Github integration!
2) autocomplete
3) maybe also something like intellisense that shows the function signatures, types of variables.
I know I am not the first one to ask for it: Version control.
The web editor is probably only used by single developers, so that features required for teams can be left out. For example, simplified integration with Github, and commands like creating commits and branches, go ing back to older commits, switching the branch.
Is there a way to have the Sketchbook tab and the serial monitor tab open at the same time? If not, it would be nice.
Not sure what you mean exactly ?
The serial monitor takes the place of the sketch view when in use.
Do you mean a totally seperate tab ?
It would be nice but serial output to the web page with everything else involved could be a pain to implement in a seperate tab.
Bump for version tracking!
Work with teammates togather (coding togather with a sync)
Search-Replace can do jobs in all tabs(in the same sketch) so I can change the name quickly(e.g. Change all the a[10] into b[12] from all tabs)
File history to recover the file saved in 10min from leave(to avoid suddenly close)
I REALLY NEED A LARGER MONO SPACED BOLD FONT TO SEE IT
I AM USING WINDOWS 10 64 BIT
I DOWNLOADED THE NEW ZIP FILE TO REINSTALL AND LOST MY LARGER MONO SPACED FONT.
IF I REMEMBER IT RIGHT IT TOOK ME MORE THEN A WEEK TO GET IT READABLE.
MONOSPACED IS NOT REALLY A FONT ON MY PC.
Are you talking about the Arduino Web Editor or about the standard Arduino IDE?
I would love the ability to prove off my code via the simulator before I upload it to the actual board. Maybe to set up output registers and input registers that the simulator can then access that would be triggered on or off based on the simulated code. this would all but guarantee that the code itself is sound before even trying to run it live on the actual board.
i think that they should add a feature that allows the user on ide to create groups on what the user puts into the groups
Hi tarbear123
Can you expand on that a little as there is already a SHARE LINK option to a single sketch.
Do you mean a whole sketchbook ?
no i mean like whenever you go to include a library to a sketch (below arduino libraries)
Despite a copious amount of caffeine I seem to be missing something here ;)
Is there a feature that you are terribly missing on the Arduino Create Platform? Or do you have an idea you would like to share with us?
Please let us know by posting you feedback in this thread!
COMING UP:
* Reference tab
* Private sketches
* Adjust the compiler flags before compiling and uploading the program
Wish List:
* Add roadmap + ways to up-vote/down-vote a feature
* Autoformat as in the Desktop IDE (auto indent)
* Support for 3rd party boards (specifically ATTiny and ESP, Sparkfun Digital Sandbox, Adafruit Feather, Microduino)
* Installation of Plugin for multiple users
* Sketch version control, and a way to retrive deleted sketches and files
* Github/Dropbox integration
* Keep local and online Sketchbook in sync as an option
* Support Yun Shield
* Blind-friendly, fix compatibility with screen readers
* Multi-language support
* Serial Plotter
* Arduino as ISP, burn bootloader
* Debugger
* Language support
* Move the "Serial Monitor" view (pop out window)
* Drag and Drop on Sketchbook panel
* Download Libraries together with the sketch
* Split screen friendly
* Multiple errors management: show on the red error bar AND highlighted in the code.
* "installation free" version using an USB-Mass-Storage device
* Schematics editor
* Add bootloader
* Turn off metadata (set default board as in the Java IDE)
* Autocomplete
* Include Library when exporting/saving a sketch
* Live collaboration feature (as Gdocs)
* Student & teacher collaboration: accounts linked, the teacher could setup a class assignment, and students could have a "Submit to Teacher" button built into the editor page. Teachers would be able to see an "assignment" page with a listing of all of the names of the students with the appropriate links to the code from that project, multiple install of the agent on classroom PCs
* Scratch or blockly-like coding environment
* Integrate Processing
* Edit Libraries on the Web Editor
* Share custom library
* Phone app
* Tablet plugin
* Arduino online simulation to check working process, before reducing upload cycles of the hardware.
* More editor themes (other than just light and dark)
* Import PDF in a sketch
* Export the .hex file
* Simulate the Serial Monitor for such functions as Serial.print() without needing a board or USB connection as in http://cpp.sh/
* Plugin for Linux 32bit
Done
* Version number
* Protected "credentials" tab in your Arduino sketch for sensibile info
* Chromebook plugin
* New SSO
* Clickable URLs in the code
* Copy/paste in right click
* Import whole Sketchbook
* Readme auto-population
* Select multiple files at once to perform bulk actions
* Show the memory usage (flash) when compiling
* Library Manager (Probably changed to: include all the trusted library by default)
* Import multiple libraries at once
* Support on Edge
* Support on Safari
* Support for screens smaller than 1024
* Tab scaling
* Public/Private Share feature
* Custom Library Deletion
* Support for MKR100, Arduino/Genuino 101
* Upload the whole Sketchbook to Arduino Cloud
* Serial Monitor refactor
it would be really helpful to have a roadmap to vote for features
I think the easiest way to accomplish that would be if they switched to using the GitHub issue tracker for feature requests and bug reports. GitHub allows you to give a "thumbs up" to feature requests, which could be seen as votes. Using a proper issue tracker has a lot of other advantages. An argument against is that probably the average Arduino Web Editor user is more likely to have an Arduino Forum account than a GitHub account and might not want to create a (free) GitHub account just to request a feature or report a bug.
i would really like to upload all my sketches online but 100 is not enough when you have multiple iterations.
Hi everybody,
autoindent is now available in web editor and we keep session info for each file, as requested by @joebutler10 (scroll position, selection and undo/redo history)
I would really like to see possibility to "Export the .hex file". As long that's not available I can't use the Web Editor.
Thanks
Hello,
A) i was looking for a way to print the sketch (as shown on the screen, so in color and with linenumbers)...
B) i liked to have a way to reset the arduino in the menu without having to go over to the PCB..
Thanks, Ton
Edit custom libraries from within the online IDEHi,
The main thing I would love to see, is the ability the edit custom ".h" and ".cpp" files, from within the online IDE. It surprised me to see that this is hardly mentioned, as it would be an incredibly useful tool.
At the moment, when I want to edit a custom library, I have to:
-Remove the library from the IDE
-Edit the library in a text editor
-Upload the edited version to the IDE
Whereas if it were editable in IDE, everything would be much easier / way more portable.
It was mentioned as being on the "to-do list" in the following post:
Currently Library edits are not available in CREATE.
Your only option is to modify the source you used and upload and over write the on in the library manager.
Sorry about that but I know that library functions were mentioned as being on the "to-do" list.
Although it seems this post is a bit outdated, are you still planning on implementing this feature?
Thank you,
~Jonathan
It is on a "road-map" but unfortunately I cannot say when it may be implemented.
Sooner than later would be my preference but so much work for such a small team.
Bob.
I would like to be able to choose 'rebuild all'.
At present I need to choose a non-valid board, start compile till it fails and then go back and select the correct board.
I need to rebuild all due to the form of conditional compilation controlled by external files that the IDE doesn't notice.
Thanks.
@kamala
Is this with the ONLINE IDE ?
Bob.
Would love to see support for the Adafruit Feather M4 Express board (https://www.adafruit.com/product/3857). Support for this board is available in the 'on-disk' version of the Arduino IDE. Would be great if Arduino Create also supported it.
Hi everybody,
we are happy to announce that support for ESP8266 and library editing are now available on Create Web Editor (https://create.arduino.cc/editor) with the Maker Plan (https://store.arduino.cc/digital/create#plans). Thanks for your patience!
Hi everybody,
The online IDE has been incredible so far and I absolutely love the portability it provides. Being able to edit libraries on the go is a great addition to the IDE.
However, to finally get this much desired feature after so long, only to have it locked behind some paid subscription, just feels like a big insult to me. Especially when you consider the amount of free and effective alternatives out there.
I'm sorry. There is just no way I'm going to pay for the ability to edit my libraries.
~Jonathan
Ability to verify/compile a sketch without the plugin or board connected. For times when you are away from home and simply want to draft some ideas and verify the syntax by compiling the sketch.
It doesn't appear that the current editor allows this. Just gives the "Error compiling, check if you have selected a board and if it's currently available".
@Sistom
For that there is the regular IDE (https://www.arduino.cc/en/Main/Software) ( see below the CREATE option) that you can install and even run as a portable version (https://www.arduino.cc/en/Guide/PortableIDE) should you wish to move between computers
An "ONLINE" ide as CREATE is is just that. It is for ONLINE / WEB based use.
Most "use" cases are handled for almost every user.
Bob.
@Sistom, @ballscrewbob,
actually that's totally possible, just select the desired target from the boards dropdown -> Select Other Board & Port, and the sketch will compile even if no board is connected and plugin not installed
@ballscrewbob
In libraries, computer labs, and work environments that do not allow installs or removable storage devices, the Online IDE would be the only option. It seems like it would be a simple option to allow compiling a sketch without a connected arduino device.
@smellai
I'm unable to even select a board in the editor. The board-select area in the editor is blocked by the following error: "No Plugin Connection. Uploading is disabled until you reconnect. Check you Firewall or Antivirus configuration."
@Sistom,
can I see a screenshot of your situation? Please have a look at mine attached
(https://forum.arduino.cc/index.php?action=dlattach;topic=361376.0;attach=331448)
@smellai
Your screenshot helped a lot. My browser was not displaying the X to close the yellow warning message covering the board select dropdown. I was able to click on the location where the X should have been displayed and closed the warning message and everything is now working as you've stated. Thanks for your help!
Hi, I think the web editor is great! I was just curious if anyone knows if the serial plotter will ever be implemented into it, as I find this very useful for doing and teaching many projects.
Thanks for any info.
Jesse
Not sure how far along in the "to-do" list this is.
Do agree it would be a nice feature and bring it more into line with the mainstream IDE.
Bob.
I would love to be able to upload my sketch from my Android tablet using the web editor. I don't want to use one of the apps from the play store.
@sean2k5
There are / were no plans to deploy CREATE to android although it is available for multiple other platforms including CHROMEBOOK devices.
Currently your options are those devices which are already supported or a third party app.
Hi 00alis,
Programming an attiny with arduino uno on the online web editor would be very nice.
I am a Low Vision User. I use MS High Contrast and MS Magnifier when using Create.
When I use "Font size" (in Preferences) to increase the size of the Sketch text and it works but the size of the Font in the Serial Monitor does not change. It becomes unreadable to me. If both font sizes stayed in sync the text would make the monitor usable for Low Vision Users.
Thanks for your consideration.
share link
would be nice if it whas possible to see in the link what
the sketchname.ino is
for example
https://create.arduino.cc/editor/luberth/dd50a0f5-cc88-4d88-8e04-77018410898d/preview
is not human readable
you can not see what is the sketch about
ammazed about what you have created!
thanks
luberth the netherlands
Hello
How can i make a html url link to a TAB page in the shared code
if i copy the link from a TAB in browser
i get https://create.arduino.cc/ wich is not the right url adres to the TAB code
luberth
Please add support for ESP32 boards. If they are supported, I'm willing to pay for it.
@luberthWith any luck and a good headwind you may see your request take shape in the near future.
;D
Bob.
Hi
@luberth,
now when you press "share", a link is provided with the current file selection, for examples too, check it out:
layout.png (https://create.arduino.cc/example/builtin/03.Analog%5CAnalogInOutSerial/AnalogInOutSerial/preview?F=layout.png)
Does that mean it already has NON-live collaboration?
Is there a way to make Create Editor to generate assembly source files also so I could check exactly how much time does it take from entering a function to execute one specific PIN manipulation?
If not, it would be good to have a feature to enable edit the CLI of the compiler and get/view the generated files.
For anyone interested in this subject, there is some discussion in the dedicated thread @sanyi created:
https://forum.arduino.cc/index.php?topic=723809
Please sort the files in sketchbook alphabetically.
So it is the order, how the sketch is compiled.
(https://forum.arduino.cc/index.php?action=dlattach;topic=361376.0;attach=401697)
@Andreas1313
That does nothing for the OP as a sort is only re-ordering a list and does not fix the problem.
Sorting libs is more useful just before importing large amounts of libraries or sketches and only useful if done PRIOR to the uploads.
That PRIOR sorting also needs to take into account removal of unwanted sketches and library components (https://forum.arduino.cc/index.php?action=dlattach;topic=459306.0;attach=204237) that will not be used.
@ballscrewbob. Thank you for your quick answer.
Your link was not helpful for me. But I found a solution: Simple switch from "Sort by Last Modified" to "Sort by Name".
Sorry, I did not recognized that before. I will add now the date in format yyyymmdd at the beginning of the name of my sketches, than I have it in the order, I want to have it. (Sketches itself and files in the sketches)
Andreas1313
Karma for getting back with your solution.
