Arduino Forum
Topics => Product Design => Topic started by: pekasus on Jan 18, 2016, 06:08 pm
Title: 5v or 12v submersible aerator with propeller
Post by: pekasus on Jan 18, 2016, 06:08 pm
I am working on an educational project that teaches about the process of water treatment using an arduino to automate the process.
I need an aerator that makes bubbles and mixes the water at the same time.
I've seen something similar done a long time ago. If I remember correctly, it was more or less a submersible hobby motor with a 'fan' soldered to the shaft and a tube running down to the 'fan' where the air was sucked in.
Does anyone know of a product that will do this? If not, can anyone explain how I could make one? I can't think of how to put together what I saw.
Here' s video of the aerator I am trying to emulate: Novair 200 YouTube video (https://www.youtube.com/watch?v=BC5T2hzRIZA)
Here is a photo: (https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcQaKgO_tPAEpbM8_5z35MAtqUkvNFSm0BmfJWYzcmTJ036q2ybiuw)
Thanks!
Title: Re: 5v or 12v submersible aerator with propeller
Post by: Chagrin on Jan 18, 2016, 07:23 pm
I'd try something like http://www.thingiverse.com/thing:76369 (http://www.thingiverse.com/thing:76369) except put an additional impeller on the end. And of course reverse the vacuum from "suck" to "blow".
Post by: Boardburner2 on Jan 20, 2016, 03:56 pm
One of these,
https://sub-driver.com/accessories/couplers-bearings-seals-and-rods/propeller-shaft-seal-3-16.html (https://sub-driver.com/accessories/couplers-bearings-seals-and-rods/propeller-shaft-seal-3-16.html)
With a motor in a housing and a propellor may work.
If the motor can be kept out of the water then just a propeller may do.
Post by: Chagrin on Jan 20, 2016, 05:37 pm
You might want to stop by a pet (aquarium) store and ask around. They should definitely have submersible "wave" pumps for water circulation since they're used for reef tanks and of course you can get small air pumps.
