Arduino Forum
Forum 2005-2010 (read only) => Software => Development => Topic started by: BKNio on Jan 22, 2011, 07:08 pm
Title: add new function to wiring_digital.c
Post by: BKNio on Jan 22, 2011, 07:08 pm
Hello!
I am trying to add new function "MydigitalWrite" to wiring_digital.c () (\arduino-0017\hardware\cores\arduino)
When I try to compile:
In function 'void loop()':
error: 'MydigitalWrite' was not declared in this scope
How to win this problem?
Title: Re: add new function to wiring_digital.c
Post by: retrolefty on Jan 22, 2011, 08:03 pm
Hello!
There should be no reason to modify the core function in the wiring library.
Just write your new function directly following the loop() function in your sketch:
void MydigitalWrite( int argument1, int argument2, etc.)
  //your new code
  // more code
Then you can use your new function anywhere in the setup or loop function of your sketch.
Lefty
Post by: BKNio on Jan 22, 2011, 08:22 pm
there is one reason
standart digitalwrite spends a lot of time to switch on or switch of massive of pins
i think i can do it, if i modify standart digitalWrite
Post by: Coding Badly on Jan 22, 2011, 08:37 pm
Why do you want to modify digitalWrite?  To make it faster?
Post by: BKNio on Jan 22, 2011, 08:48 pm
No. i want create new to switch on or off massive of pins
i cant use like this
for(int i=0;i<10;i++)
digitalWrite(i,HIGH);
because it spend a lot of time
Post by: BKNio on Jan 22, 2011, 08:50 pm
i only need add new function to \arduino-0017\hardware\cores\arduinowiring_digital.c
Post by: Coding Badly on Jan 22, 2011, 08:52 pm
Have you considered direct port access?
Post by: BKNio on Jan 22, 2011, 09:04 pm
Yes but i found nothing
How i can do it? there is special function?
Post by: BKNio on Jan 22, 2011, 09:08 pm
i want to do it like this
out = portOutputRegister(port);
if (val == LOW) *out &= ~bit;
     else *out |= bit;
that is why i need to add new function
Post by: Coding Badly on Jan 22, 2011, 09:18 pm
http://www.google.com/search?q=arduino+port
http://www.arduino.cc/en/Reference/PortManipulation
Post by: BKNio on Jan 22, 2011, 09:22 pm
thank you
