Arduino Forum
Forum 2005-2010 (read only) => Software => Interfacing => Topic started by: zodiak on Feb 05, 2010, 06:01 pm
Title: manipulating serial data
Post by: zodiak on Feb 05, 2010, 06:01 pm
Hello All,
I've been struggling for a while with the following:
I wrote code that fills in the contents of an array with bytes coming in the serial port:
while (finish != '#'  && i <= 13){ //if we have more than 13 we have more info than we should...
   command[i] = Serial.read();
   delay(5); // must be included to ensure board receives good data
   finish = command[i];
   Serial.print(command[i], BYTE); //DEBUG
   i++;
   // read the bytes comming in until end of comms (i.e. #); command[i] holds the position information
   // now the program is waiting for another * to come in.
I'm sending serial data from a PC and the output of the Serial.print(command, BYTE); is fine, this means I can see tat what I send from the PC is well received.
The problem comes when I need to manipulate the values on the array because of what seems to be some kind of variable type mismatch but I can't really tell. The following line does not output what is expected:
   g_pos = (command[1] * 100 + command[2] * 10 + command[3]) - 100;
   Serial.print(g_pos);
Because I think above I'm actually doing calculations on ASCII code rather then an integer so I tried the following:
g_pos = (char(command[1]) * 100 + char(command[2]) * 10 + char(command[3])) - 100;
but it also doesn't output an integer. I read somewhere about the atoi() function which seems to be what I need but writing:
g_pos = (atoi(command[1]) * 100 + command[2] * 10 + command[3]) - 100;
gives me an error: error: invalid conversion from 'int' to 'const char*'
Am I going the right way with this?
TIA
Title: Re: manipulating serial data
Post by: PaulS on Feb 05, 2010, 06:08 pm
The atoi function takes a string as an argument, not a character.
g_pos = atoi(command);
Post by: GrooveFlotilla on Feb 05, 2010, 06:11 pm
You're very close, and bonus points for perseverence!
"atoi" works on strings, not "char"s, so either terminate your buffer with a zero and call "atoi", or
g_pos = ((command[1] - '0') * 100 + (command[2] - '0') * 10 + (command[3]) - '0') - 100;
Post by: zodiak on Feb 05, 2010, 06:40 pm
Thank you for the replies, guys!
Groove the following code works like a charm, many thanks:
May I just ask what the code above does? I'm confused, subtracting char '0' to the ascii code on each array element??
Post by: PaulS on Feb 05, 2010, 07:42 pm
If you look at the ascii table, there is a code assigned to each letter and number. The value isn't really important, but by subtracting the ascii value of '0' from each character, you get the relative position of the character.
If, for instance, the character is '3', then '3' -  '0' means that the '3' is 3 positions to the left of '0'. That offset is the numerical value of the character.
Post by: zodiak on Feb 06, 2010, 12:20 pm
Brilliant and clever! Took me a while to see that but I got it. Thanks!
