Arduino Forum
Products => The Arduino Starter Kit and Basic Kit => Topic started by: happypete on Jun 02, 2016, 11:39 pm
Title: heart rate monitor example can't work
Post by: happypete on Jun 02, 2016, 11:39 pm
Hi I just received my starter kit. I am trying to build heart rate monitor and find this example CurieBLEHeartRateMonitor. https://www.arduino.cc/en/Tutorial/Genuino101CurieBLEHeartRateMonitor.
I can not find the example in the Arduino software package, then copied the source codes and uploaded them, But debugging shows wrong. I wonder the reason that the example is for Arduino 101 instead of Starter kit. Is that correct?
If yes, where can I find some examples to test heart rate monitor?
If no, how can I make it work?
Thanks!
Haotian
Title: Re: heart rate monitor example can't work
Post by: chummer1010 on Jun 04, 2016, 03:01 pm
Could you post the code and the error messages you received? That would be most helpful.
Post by: AndreaRichetta on Jun 23, 2016, 02:28 pm
included in the starterkit there is a UNO board, the tutorial you are linking is specific for the 101 board because of the use of BLE capabilities of the board, so it's impossible to use it.
if you plan to use a standard bluetooth heart rate monitor you have to use a 101.
thanks
Andrea
