Arduino Forum
Using Arduino => Programming Questions => Topic started by: nmunoz on Aug 15, 2016, 12:33 am
Title: compile when I get the message ' setLocked ' was not Declared In This scope
Post by: nmunoz on Aug 15, 2016, 12:33 am
hello, I need to work with the keyboard 3 * 4, but when I compile I get this mesaje ,
 ' This was not Declared In scope
and and I tried everything but it does not work . I could help please .
I leave copy of the program .
#include <Keypad.h>
char  codigosecreto = '12345';
int   position = 0;
const byte ROWS = 4; // cuatro filas
const byte COLS = 3; // tres columnas
char keys[ROWS][COLS] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'},
byte rowPins[ROWS] = { 1, 2, 3, 4 };      // Conectar teclado ROW0, ROW1, ROW2 y Row3 a estos pines de Arduino
byte colPins[COLS] = { 5, 6, 7 };         // Conectar teclado Col"0" , col"1" y col"2" a estos pines de Arduino .
Keypad keypad1 = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int Rojo = 9;
int Verde = 10;
void setup () {
  pinMode (Rojo, OUTPUT);
  pinMode (Verde, OUTPUT);
  setLocked(true)
    void loop () {
      char key = keypad.getKey();
      if (key == '*' || key == '#')
        position = 0;
        setLocked(true);
      if (key == codigo secreto [position])
        position ++;
      if (position == 4)
        setLocked(false);
      delay(100);
      void setLocked(int Locked) {
        if (locked)
          digitalWrite(redPin, HIGH);
          digitalWrite(greenPin, LOW);
          digitalWrite(redPin, LOW);
          digitalWrite(greenPin, HIGH);
Title: Re: compile when I get the message ' setLocked ' was not Declared In This scope
Post by: larryd on Aug 15, 2016, 12:56 am
Try pressing 'CTRL T' in the IDE
Post by: Gabriel_swe on Aug 15, 2016, 01:19 am
Compiler is right. setLocked is not declared in your code, but you have codigosecreto and other variables declared.
Post by: ChrisTenone on Aug 15, 2016, 02:03 am
Add this at the top:
boolean setLocked;
Post by: 6v6gt on Aug 15, 2016, 02:04 am
... and setLocked(true) should be terminated with a semi-colon ';'
and the '{' following setLocked(true) should be replaced with a '}'
