Arduino Forum
Using Arduino => Storage => Topic started by: hambba on Jan 11, 2017, 06:54 pm
Title: write to csv file?
Post by: hambba on Jan 11, 2017, 06:54 pm
how to write the value of RTC and DHT into a CSV file.?
csv files I named "logger.csv"
//SD
#include <SD.h>
const int chipSelect = 10;
File file;
//RTC
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 rtc;
//LCD
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,6,5,4,3,2);
//DHT11
#include <dht.h>
#define sendht A1
dht dht;
{ lcd.begin(20,4);
  //SD
  Serial.print("Initializing SD card...");
  lcd.print("Initializing SD card...");
  lcd.clear();
  pinMode(10, OUTPUT); // required for SD lib
  digitalWrite(10,HIGH);
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    lcd.print("Card Failed or");
    lcd.setCursor(0,1);
    lcd.print("Not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  lcd.print("Card Initialized.");
  lcd.clear();
  //RTC
 Wire.begin();
 rtc.begin();
 if (! rtc.isrunning()) {
    lcd.clear();
    lcd.print("RTC NOT Running");
    //Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    // rtc.adjust(DateTime(__DATE__, __TIME__));  //useed when only to set date and time in firt setting of RTC
  // rtc.adjust(DateTime(__DATE__, __TIME__)); use it when you need to correct the time
    //DHT
    dht.read11(sendht);
    Serial.print("Current humidity = ");
    Serial.print(dht.humidity);
    Serial.print("%  ");
    Serial.print("temperature = ");
    Serial.print(dht.temperature);
    Serial.println("C  ");
    //RTC
    DateTime now = rtc.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(' ');
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.println();
Title: Re: write to csv file?
Post by: PaulS on Jan 11, 2017, 06:59 pm
dht dht;
You should NEVER create an instance of a class with the same name as the class.
The RTC is hardware. The library that you use to read it can return several values. Which ones do you want to write to the file? In what order? With what between them?
The same applies to the DHT.
Post by: hambba on Jan 11, 2017, 07:08 pm
dht dht;
thank you for your attention,
I want to create a data logger that will be I made a means of learning.
if you can give me a few examples to write two values ​​into csv file and how to separate the different values ​​in the column
"dht dht; Is naming From My library"
Post by: PaulS on Jan 11, 2017, 07:37 pm
It's still wrong.
   File csvFile = SD.open("theData.csv");
   if(csvFile)
      csvFile.print("thisIsInColumnOneRowOne");
      csvFIle.print(",");
      csvFile.println("thisIsInColumnTwoRowOne");
      csvFile.print("thisIsInColumnOneRowTwo");
      csvFIle.print(",");
      csvFile.println("thisIsInColumnTwoRowTwo");
      csvFile.close();
Post by: SukkoPera on Jan 13, 2017, 03:02 pm
I attempted to write a library for CSV file creation for my MyTrack project (https://github.com/SukkoPera/MyTrackr).
The library works, but I'm not really satisfied with its interface, this is why it is embedded in the project and not packaged separately. The interface is so ugly that the more you're going to use it, the more you will be thinking that you don't really need a library for writing CSV files ;).
Anyway it might still be of some use to you, so maybe you can check it out. You only need to copy the CSVWriter.cpp and .h files into your project. Then have a look here (https://github.com/SukkoPera/MyTrackr/blob/89fde847608e89726413bedef56bb6b4610de5ec/MyTracker.ino#L471-L487) for how to define the column names and here (https://github.com/SukkoPera/MyTrackr/blob/89fde847608e89726413bedef56bb6b4610de5ec/MyTracker.ino#L506-L580) for how to actually write a line of data.
