Arduino Forum
Products => MKR Boards => MKRZero => Topic started by: kobyfr on Jan 15, 2017, 04:06 pm
Title: mkrzero not programmable
Post by: kobyfr on Jan 15, 2017, 04:06 pm
Hello.
I've followed some online advice in order to make the MKRZERO enter sleep, and wake on interrupt.
That code worked for me, and indeed the MKRZERO responded to a change (rise/fall) in the selected GPIO.
Now, I'm hardly able to re-program it.
I'm afraid I caused some kind of mini-brick, due to the MKRZERO being busy with the different delay() and _WFI commands
I'm getting failure messages of this kind
java.net.SocketException: error setting options
at java.net.TwoStacksPlainDatagramSocketImpl.join(Native Method)
at java.net.AbstractPlainDatagramSocketImpl.join(AbstractPlainDatagramSocketImpl.java:178)
at java.net.MulticastSocket.joinGroup(MulticastSocket.java:323)
at javax.jmdns.impl.JmDNSImpl.openMulticastSocket(JmDNSImpl.java:463)
at javax.jmdns.impl.JmDNSImpl.<init>(JmDNSImpl.java:420)
at javax.jmdns.JmDNS.create(JmDNS.java:81)
at cc.arduino.packages.discoverers.NetworkDiscovery.inetAddressAdded(NetworkDiscovery.java:211)
at cc.arduino.packages.discoverers.network.NetworkChecker.run(NetworkChecker.java:67)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
Sketch uses 9544 bytes (3%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM10
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:160)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:709)
at processing.app.SketchController.exportApplet(SketchController.java:682)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2190)
at java.lang.Thread.run(Thread.java:745)
Caused by: processing.app.SerialException: Error touching serial port 'COM10'.
at processing.app.Serial.touchForCDCReset(Serial.java:87)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:144)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM10; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:81)
... 6 more
An error occurred while uploading the sketch
In what way is the code I entered the cause of this failure?
I'm able sometimes to free it from this programming failure, by pressing the reset while it tries to upload the hex, but I can't any more (I did another code change, which is probably even less agreeable with the upload process).
This is my code
// This sketch shows how to activate an interrupt handler in response to a falling edge on GPIO 0.
// After each interrupt (falling-edge), the on-board LED lights for 1 second, and then turns off.
#define CPU_ARM
#ifdef CPU_ARM
#else
# include <avr/sleep.h>
#endif
int wakePin = 1;                 // pin used for waking up
int led=LED_BUILTIN;
int event_counter = 0;
void wakeUpNow() {
  // execute code here after wake-up before returning to the loop() function
  // timers and code using timers (serial.print and more...) will not work here.
  // we don't really need to execute any special functions here, since we
  // just want the thing to wake up
  pinMode(wakePin, INPUT_PULLUP);
  pinMode(led, OUTPUT);
#ifdef CPU_ARM
  void sleepNow_start_armM0()
      SCB->SCR |= 1<<2; // Enable deep-sleep mode
      __WFI();          // ARM processor wait for interrupt
  void afterWakeup_armM0()
      // Do nothing?
#else
  void sleepNow_start_AVR()
      set_sleep_mode(SLEEP_MODE_PWR_DOWN);   // sleep mode is set here
      sleep_enable();          // enables the sleep bit in the mcucr register
      sleep_mode();            // here the device is actually put to sleep!!
  void afterWakeup_AVR()
      sleep_disable();         // first thing after waking from sleep: disable sleep...
#endif
void sleepNow() {
    attachInterrupt(digitalPinToInterrupt(wakePin),wakeUpNow, RISING); // use interrupt X (pin Y) and run function
#   ifdef CPU_ARM
        sleepNow_start_armM0();
        // THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
        afterWakeup_armM0();
#   else
        sleepNow_start_AVR();
        afterWakeup_AVR();
#   endif
    detachInterrupt(digitalPinToInterrupt(wakePin));      // disables interrupt X on pin Y so the wakeUpNow code will not be executed during normal running time.
  //Serial.println("loop start");
  int i = 5;
  while (i--)
    digitalWrite(led, HIGH);
    //Serial.println("led HIGH");
    delay(100);
    digitalWrite(led, LOW);
    //Serial.println("led LOW");
    delay(100);
  sleepNow();     // sleep function called here
Title: Re: mkrzero not programmable
Post by: kobyfr on Jan 15, 2017, 04:27 pm
I was able to reprogram it, but attaching the RESET pin to GND while the uploading was starting, and detaching it from GND when the IDE started connected to the serial port.
Modifying the code by setting a limit on the number of interrupts, preventing any further delay()or _WFI(), allows me to easily reprogram it.
I guess I should avoid leaving the processor in _WFI() coupled with deep_sleep.
Post by: kobyfr on Jan 19, 2017, 02:31 pm
Real answer : had to press reset twice, while the IDE was trying to connect and program the device.
Post by: monikah123 on Feb 04, 2017, 07:28 am
Thanks for posting. I've got an MKRZero too. Lots to learn.
Post by: robbideloose on Oct 05, 2018, 05:51 pm
Old post, I know, but you saved my day! Got my RocketScream Mini Ultra Pro and screwed it up within 30 minutes after unpacking. Set up alarm timer and sleep without including the delay in the setup.
Double tab did the trick!
