Arduino Forum
Community => Exhibition / Gallery => Topic started by: FoxyLab on Mar 21, 2017, 04:51 pm
Title: CP/M computer on Arduino Nano 3.0
Post by: FoxyLab on Mar 21, 2017, 04:51 pm
Greetings to all lovers of Arduino and old school computing! Nostalgia for the eight-bit computers of my youth led me to this project :-) - CP/M 2.2 computer from ... what would you think? ... Arduino Nano 3.0!
For weeks two or three I made the i8080 processor emulator for Arduino Nano (it passes the test from MICROCOSM) and adapted the CP / M.
The main problem - Arduino has only 2 (!) KB of RAM. But we also have an SD card - I made a 4-line cache (32 bytes) to this card, and the card itself emulated all 64 KB of RAM. Although I applied the most primitive cache management algorithm, the speed of work is not so bad.
At the same time, this card also emulates four floppy disks.
Here's the quick-and-dirty prototype of my work:
Yes, I did not use the adapter for the card, I inserted it into the connector of the cable from the five-inch drive. :-)
To communicate with a computer, I use a terminal program (in the future I plan a PS/2 keyboard and an LCD screen or connect to a TV).
Here is a screenshot of the memory check:
CP/M Download:
CPU Test:
DIR command:
My first program in BASIC for the past twenty (!)))) years:
(I launched TinyBASIC).
Are you interested in such a project?
Title: Re: CP/M computer on Arduino Nano 3.0
Post by: GrooveFlotilla on Mar 21, 2017, 08:57 pm
{Claps}. Bravo!
Post by: FoxyLab on Mar 22, 2017, 02:32 am
{Claps}. Bravo!
Thanks a lot!
Post by: Isaac96 on Mar 22, 2017, 02:48 am
That is great!
Another person (i think it was on here) used a Mega1284, which was probably easier relatively speaking. One thing-there is a VGAout library somewhere. You might be able to output to a vga screen and have a command line!
Post by: FoxyLab on Mar 22, 2017, 03:41 am
That is great!
Many thanks! I plan to add PS/2 keyboard and LCD screen (or TV-out - but this required additional microcontroller as VGA-controller).
Post by: Isaac96 on Mar 22, 2017, 04:34 am
Awesome. That sounds amazing. Please post when that is complete.
Post by: FoxyLab on Mar 23, 2017, 03:01 pm
I uploaded on YouTube realtime video of my project in action:
https://youtu.be/LHFmt3qWAuY (https://youtu.be/LHFmt3qWAuY)
Post by: thomai on Mar 23, 2017, 07:22 pm
Simply awesome!!!
But why didn't you use a SPI RAM extension?
Post by: petersieg on Mar 23, 2017, 08:33 pm
Where is the source? ;-)
Would like to give it a try..
Very interesting to use a 64kb area on sd card to mimick ram memory.
I assume the 4 floppy images are dd-ed on 4 partitions of the sd card?
Please keep this code as a separate (version 1) project, before you introduce ps/2 kb und display.
thx,
Peter
Post by: FoxyLab on Mar 23, 2017, 10:04 pm
Simply awesome!!!
Thanks!
In future probably as an option (Ferroelectric RAM).
Post by: FoxyLab on Mar 23, 2017, 10:15 pm
thx,
Peter
1. I will uploaded source in my GitHub repository - I believe, by the beginning of next week.
2. I use 4 GB SDHC Card, so i trade free space for simplifying - i write one line cache at the beginning of each sector (64 bytes of 512 bytes)   (cache has 8 lines of 64 bytes)  ->  65536/64 sectors to all RAM.
3. No, i dont use partitions on SD Card - raw read/write only.
Post by: petersieg on Mar 24, 2017, 09:11 am
Thx. Would be glad if you upload also your sd card image so that one can write it directly with dd on a card.
Peter
Post by: FoxyLab on Mar 24, 2017, 09:53 am
Peter
O.K.
Post by: pito on Mar 24, 2017, 05:05 pm
I've got stm32duino (stm32F103zet6 board) with 64kB internal and 512kB of external sram (wired via FSMC). The 512kB of sram could be used for the heap. I can allocate the 64kB of CP/M's RAM with malloc() in that 512kB space easily.
So I may try to run your code on it, when available..
FYI:
External sram on stm32duino (http://stm32duino.com/viewtopic.php?f=28&t=1651&p=25394#p22576)
Post by: FoxyLab on Mar 24, 2017, 05:52 pm
FYI:
Thanks!
But my target was Nano. For fun i plan in future connect Nano to 32+32 KBytes Ferroelectric RAM (FRAM) (~1.2$ on eBay) as option.
Post by: FoxyLab on Mar 25, 2017, 08:55 pm
I uploaded very draft source code of my project to Github:
https://github.com/Dreamy16101976/cpm4nano (https://github.com/Dreamy16101976/cpm4nano)
I did the emulation of ports 0 and 1 in Altair-style and run Altair TinyBASIC without (!) CP/M. He works quick!
Post by: spcrngr on Mar 28, 2017, 04:59 am
This is very impressive, nice work!
Post by: FoxyLab on Mar 28, 2017, 09:31 am
Thank you very much!
Post by: FoxyLab on Mar 31, 2017, 03:32 pm
To simplify the configuration of the CP/M for the current RAM size, I extracted the CCP and BDOS images from MOVCPM.COM and analyzed (using the program, of course) the differences between this template image and the real image of the system with 62 KByte. The result is the project getcpm - https://github.com/Dreamy16101976/getcpm (https://github.com/Dreamy16101976/getcpm)
When you run getcpm.exe, you need to specify the memory size in kilobytes (XX) and the desired serial number of the CP/M system (6 bytes in hexadecimal, YYYYYYYYYYYY), after the configuration is done, the CPMXXK.SYS file is created and its eight-bit checksum is specified:
The program, using the CPMDIFF.SYS file, corrects the addresses in the CPM00K.SYS file by configuring CCP and BDOS for the specified amount of RAM:
The program itself is written on Go and compiled by the command go build getcpm.go
Post by: FoxyLab on Apr 01, 2017, 10:44 am
I found and fixed an error in INR M/DCR M emulation.
Now the TYPE command works correctly!!!
The emulator is almost ready to use widely.
I will write instructions on how to prepare a SD-card for use in the emulator.
Post by: FoxyLab on Apr 02, 2017, 08:43 am
I added an LRC-checksum for the memory data when writing/reading to the SD-card. While failures were not.
Post by: FoxyLab on Apr 05, 2017, 12:09 am
I made the input from the console more versatile - through interrupts - to connecting the PS/2 keyboard in the future + added a command R monitor to reset the Arduino.
Also i did 200 runs of the memory test (added a command to the monitor) - failures not detected:
Post by: FoxyLab on Apr 09, 2017, 08:05 pm
Using emulation of address and data buses, as well as internal registers (W, Z, ACT, TMP), made emulation of microoperations as close as possible to the "iron" processor + with #define made the emulation code much more visible. The new code is already laid out on GitHub.
Post by: FoxyLab on Apr 12, 2017, 01:06 am
According to the test results, the random access time to the emulated memory card was about 7 milliseconds.
Post by: FoxyLab on Apr 15, 2017, 07:59 pm
Because of the use of caching, the average access time with sequential access to memory is about 80 microseconds.
I used the BASIC test (in the TINYBASIC interpreter) to evaluate the effect of the cache on performance in the real task:
(The size of the cache line is 64 bytes)
Number of cache lines runtime (seconds)
2 .................................... 345
4 ................................... 155
6 .................................... 80
8 .................................... 60
Post by: FoxyLab on Apr 19, 2017, 09:40 pm
I ran the Ada language compiler on my Arduino !!!
Compilation of the program TOWERS.ADA for solving the problem of the "Hanoi Tower":
Running the compiled program TOWERS.COM:
Post by: FoxyLab on Apr 22, 2017, 05:59 pm
Changed the approach to emulating the floppy disks - allocated on the SD card the area for storing the contents of 100 floppy disks and with the monitor command Z i "insert" a floppy disk into one of the drives A, B, C or D
(for example, the ZB02 command mounts a floppy disk with the number 02 in drive B)
The numbers of "inserted" floppies are stored in the Arduino EEPROM and are restored when the emulator is restarted.
Post by: FoxyLab on Apr 27, 2017, 08:05 pm
I made an emulation of the memory management device (MMU) with switching banks, which allowed access to 512 KByte of memory.
I divided the address space 0x0000 ... 0xFFFF into 16 blocks (with numbers from 0x0 to 0xF) of 4 KByte in size. Each block can be mapped to one of 8 banks (the size of the bank is 64 KByte). The correspondence of banks to blocks is determined by the values ​​(bank numbers from 0 to 7) in a set of 16 registers (only bank 0 is active when the emulator is started).
To specify the bank number for a specific block, two output commands are used in the port:
OUT D0, block number
OUT D1, banknumber
Also, you can use the YXY monitor command to switch the X memory unit to the Y memory bank.
Post by: FoxyLab on Apr 30, 2017, 07:36 am
Testing for 8 banks of memory:
Post by: FoxyLab on May 17, 2017, 08:17 pm
cpm4nano Mk II
(used an adapter to connect a microSD-card)
Post by: Budvar10 on May 18, 2017, 07:49 am
Post by: petersieg on May 18, 2017, 09:57 am
Hmm. Just gave it a try with Arduino 1.0.6 (I know that it is very old).
1. Gives conflict with standard arduino SD library - better to rename your spinoff to something that does not give a conflict with the standard libs.
2. Resulting sketch ist to big for Nano/Mini Pro with atmega328:
Binäre Sketchgröße: 33.386 Bytes (von einem Maximum von 30.720 Bytes)
processing.app.debug.RunnerException: Sketch zu groß;
BTW: I assume the ps2 files are just there for future use and not yet used in the project?
Also some wiring information would be making it probably easier.
And where can I locate the ADA compiler for CP/M?
Also it would be a good idea, the let any somewhat stable version there as a release when you start working on a new/anhanced version.. so just have one bucket of code that is a work in progress ist not good.
Peter
Post by: FoxyLab on May 26, 2017, 08:20 am
Peter
I compiled the project succesfully on Arduino 1.6.6 (on Arduino 1.8.x - fail with PROGMEM).  Required library files (some are slightly changed!) placed in project folder (Sd2Card.h, SD.h etc).
I upload on GitHub today last project version.
For this code:
"Sketch uses 30,436 bytes (99%) of program storage space. Maximum is 30,720 bytes.
Global variables use 1,465 bytes (71%) of dynamic memory, leaving 583 bytes for local variables. Maximum is 2,048 bytes."
Yes, PS/2 related files - for future use.
I'm working on a wiring drawing.
ADA compiler - i will upload later.
Best regards, Alexey
Post by: FoxyLab on May 26, 2017, 08:26 am
Thanks!
Post by: FoxyLab on May 27, 2017, 06:57 am
P.S. Ada compiler for CP/M - https://acdc.foxylab.com/ada.zip (https://acdc.foxylab.com/ada.zip)
Post by: FoxyLab on Aug 10, 2018, 09:45 pm
Project news:
- connected two FRAM chips (32 KBytes each), and made auto-configuration of chips (they can be up to 8) on banks, so that these two chips filled zero bank RAM
- untied the hardware I2C from interrupts (by rejecting the use of Wire.h)
- untied work with UART from interrupts
- from interruptions I got off for good reason - timer 1 after these tweaks allowed to generate the horizontal line frequency for output on TV; I was able to select a set of assembler commands that would allow one pixel to be output in 7 cycles of the processor (where the characters are taken from the character generator - an array in flash memory, but not the screen buffer in RAM), and this at 56 μs of the active part of the line will give 128 pixels, e. Arduino Nano (one !!!) can both emulate and output to the screen through the composite TV input 24 chars in row with 5 x 8 font, although losing a few in performance (but still not to that the ZX80 of Sir Clive :-))
- rewrote emulation code, saving a few kilobytes of flash
To be continued (and a new version of the code on the GitHub, as well as a edited description (in russian) at https://acdc.foxylab.com/node/76)
Post by: FoxyLab on Aug 23, 2018, 09:15 pm
I will boast :-)
I taught my "nanocomputer" to display on TV screen without jitter (!) 20 lines of text on 40 columns in each.
The "screenshot" of the TV screen shows the results of the DIR command and the CPU tests:
Currently one (!) Arduino Nano (!) in my "cpm4nano" project:
- emulates the i8080 processor;
- loads the OS CP M and runs its programs;
- exchanges information on the serial port;
- displays the image on the TV screen.
P.S. Font, of course, i will correct, Spectrum compressed font looked better.
Post by: FoxyLab on Aug 26, 2018, 09:48 pm
Current project circuit:
The minimum configuration requires:
Arduino Nano 3.0;
SD card with adapter;
USB-UART converter.
Post by: FoxyLab on Aug 30, 2018, 08:33 am
With the addition of the PS/2 interface for connecting the keyboard, my "nanocomputer" has become self-sufficient:
Post by: FoxyLab on Aug 30, 2018, 09:23 am
Project on Arduino Project Hub:
https://create.arduino.cc/projecthub/FoxyLab/arduino-nano-as-cp-m-compatible-computer-c09d4e (https://create.arduino.cc/projecthub/FoxyLab/arduino-nano-as-cp-m-compatible-computer-c09d4e)
Post by: CyberCube37 on Sep 02, 2018, 08:57 pm
thank you for this post. I am 16yrs old and im just in love with assembly language and old simple microprocessors and IC. when I get a little bit more experience i will definetly give it a try I dont like newer higher level languages and it would be awesome to learn things on something I already have like an arduino. If you have any suggestions where I could learn more and how to get started I would appreciate your suggestions
Post by: FoxyLab on Sep 06, 2018, 07:01 pm
Thanks! I started programming on such a Soviet programmable micro calculator - https://en.wikipedia.org/wiki/Elektronika_MK-61
Then there was ZX Spectrum... This project brings me back to my youth :-)
But enthusiasts do much more incredible things - a processor on TTL logic or even electromagnetic relays ("homebrew relay computers").
Post by: FoxyLab on Sep 06, 2018, 07:14 pm
Displaying the font on the TV screen after the redesign and adding symbols of the pseudographics and Russian letters in the KOI-8 encoding:
Post by: FoxyLab on Sep 09, 2018, 04:52 pm
"Hardware" underline cursor added:
Post by: FoxyLab on Sep 13, 2018, 11:06 pm
I tested the BASIC compiler on my "nanocomputer":
compilation
link
run :)
Post by: FoxyLab on Sep 22, 2018, 03:39 pm
Huzza!
My simulator passed the test DIAGNOSTICS II V1.2 - CPU TEST by SUPERSOFT ASSOCIATES:
Post by: FoxyLab on Sep 24, 2018, 07:51 pm
Epic game "Star Trek" running in my "nanocomputer":
Post by: brandonpcguy on Dec 14, 2018, 08:14 pm
I'm going to try this on:
https://www.adafruit.com/product/2795
I would like to make a compact portable CP/M computer.
Thank you for your work.
It is a really cool project.
