Arduino Forum
Using Arduino => Project Guidance => Topic started by: isaralynn on May 20, 2017, 06:08 pm
Title: Arduino life span? Best on/off intervals for long installations?
Post by: isaralynn on May 20, 2017, 06:08 pm
Hello! I have a project that will be part of a 2 month long exhibition.  This means the project will be active 5 days a week, 7 hours a day for 2 months.   I am concerned with how long the arduino fio (and the other components) that run the piece will last.  The piece uses a 12v 5amp power supply that connects to a circuit that powers an actuator and arduino fio.  The actuator is triggered frequently.  The full duration of the piece is 5 minutes long.
I was wondering if using a Short Period Repeat Cycle Outlet Timer (https://www.amazon.com/gp/product/B0184CG9K0/ref=abs_brd_tag_dp?smid=AARY1ZSUT9VPR) would help sustain the life of the piece.  I could set it to be powered on for 5 minutes, then off for 3 minutes.  I was curious if powering the arduino off/on like that is actually good or bad?  Is it better to have the piece on for 30 straight minutes and then off for 10 minutes?  What are the best intervals, or do you have other solutions to prevent burn out?
I'm attaching a schematic of the circuit.  Sorry it's a little rough, and someone helped me build it, I'm kinda a newbie.
Title: Re: Arduino life span? Best on/off intervals for long installations?
Post by: Delta_G on May 20, 2017, 06:17 pm
Tell us about the project.  The Arduino would be perfectly fine running constantly for 20 years or more, so 2 months is nothing.  What other components are you worried about?  For many components, on-off cycles are worse than just leaving them run.
Post by: isaralynn on May 20, 2017, 06:28 pm
I guess aside from the arduino, I'm also worried about the regulator (Mosfet LD33CV) and the Converter 12V Step Down to 3.3V 3A (https://www.amazon.com/gp/product/B00A714QBQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The circuit also uses some diodes, resistors, LEDs.
I didn't know arduinos last that long.
This is the actuator I use: https://www.sciplus.com/p/power-door-lock_47851?ppc=shopping1&gclid=CjwKCAjw0v_IBRAEEiwA3--1Ns_CdPfrHjDO07MggrcYxsXgLbVF3r36c92kzk-WXWhfHaNFwLX1UBoCb1AQAvD_BwE (https://www.sciplus.com/p/power-door-lock_47851?ppc=shopping1&gclid=CjwKCAjw0v_IBRAEEiwA3--1Ns_CdPfrHjDO07MggrcYxsXgLbVF3r36c92kzk-WXWhfHaNFwLX1UBoCb1AQAvD_BwE)
Basically the piece uses an arduino fio with a blink sketch to trigger the actuator to make a kick drum pedal beat on a kick drum.  It's powered from a wall outlet.
Post by: Delta_G on May 20, 2017, 06:30 pm
That should run constantly for decades.  If the regulator gets hot then put a heat sink on it.  That's about the only thing you'd need to be concerned with.
Post by: isaralynn on May 20, 2017, 06:37 pm
Great! I do already have a heat sink on the regulator.  So I guess it doesn't matter either way if I turn it on/off vs. just leave it running?  If I want a delay between when the sketch loops should I just factor in a delay at the end of the code, or turn the piece off?
Post by: Delta_G on May 20, 2017, 06:39 pm
Just stick a delay in there.  Power cycles would be worse than just leaving it on.
Post by: isaralynn on May 20, 2017, 06:48 pm
Ok thank you very much for the advice!
Post by: isaralynn on Jun 04, 2017, 08:02 pm
After being on for 56 minutes (and being triggered almost every second) I noticed my door lock actuator feels pretty warm.  Is that anything to worry about?
Post by: Paul_KD7HB on Jun 04, 2017, 08:26 pm
Those are made to be used intermittently. How much time is used to actuate the lock and how much time is power removed. Most electronics is ok if you can keep you hand on it.
Paul
Post by: TomGeorge on Jun 05, 2017, 12:03 am
Can you please post a complete copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png?
Using component symbols and labelling pins etc.
You diag does not tell us where the actuator is connected, where your Arduino is connected, what model Arduino are you using.
Thanks.. Tom... :)
Post by: aarg on Jun 05, 2017, 02:09 am
It would be if it were a mass produced product, since wasted electricity has an environmental impact. Also some components age faster when they're warm, like electrolytic capacitors. Sometimes if the case is warm, it can mean that something inside is much hotter than you believe it is.
Post by: isaralynn on Dec 18, 2017, 04:24 am
Update:  Everything lasted the whole exhibition no problem except my door lock actuators (they lasted between 5-8 days).  The piece did run in 30 minute intervals, with a 5 minute break.  I'm on the hunt for a better motor solution, but haven't found anything yet :/  Some rack and pinion type have been recommended to me, but I haven't been able to find a viable one that will work with my project yet. Need something that will pull 1" multiple times a second for extended durations.
Post by: wvmarle on Dec 18, 2017, 05:16 am
Sounds like a job for a solenoid. Door openers are built around solenoids usually. Very likely those door openers are made with a somewhat underpowered solenoid, as they're designed to be on for a few seconds at a time, then off for long time. So a smaller solenoid makes them cheaper, but won't last when pushed like you do.
Post by: isaralynn on Dec 14, 2018, 09:03 pm
Update #2:  I've updated my motors to these solenoids: https://www.mcmaster.com/70155k611 (https://www.mcmaster.com/70155k611)
I haven't used them in an exhibition yet, but they are much quieter and seem a lot more reliable than the previous motors I was using since these don't use any plastic gears that can go bad.
Post by: Rx7man on Dec 14, 2018, 10:06 pm
Might want to look into dual-circuit solenoids.. They have a high power "pull-in" coil and a low power "hold" coil, this gives them both the strength to pull with significant force, as well as a low power draw so they can stay on for extended periods of time without overheating.. There are also microchips (LM1947) designed for fuel injectors that can be repurposed for this, the drop the amperage by a factor of 4 after a set time which drastically reduces heat buildup in the coil.
