Hi
Firstly thanks for the great forums have learned so much already. I am working with the HP03 pressure sensor and not having much luck with reading anything off it. Here is the data sheet for it.
http://www.oceancontrols.com.au/Sensors/pressure/HP03.pdf
I have read threw the i2c playground and several other example and they seem to have only confused me more. I would like to know if anyone has an example for reading from this actual device or might be able to point me in the right direction.
Any help you can give me would be greatly appreciated.
Here is a library I use for the HP03 pressure sensor. This code works for me but has only been run with a modified wire library on Arduino version 0011. It should be ok with the standard 0012 wire library, but not yet tested.
test sketch:
// HP03 test sketch
// Created 11 July 2008
#include <HP03.h>
#include <FrequencyTimer2.h>
#include <Wire.h>
// note that the HP03 code uses digital pin 11 for the clock and analog pins 4 and 5 for I2C
unsigned long start;
Serial.begin(19200); // start serial for output
if(HP03.begin() == false)
Serial.println("Error getting HP03 calibration, check sensor connection");
for(long p = 1100; p >=310; p-= 50){
Serial.print("pressure ");
Serial.println(p,DEC);
HP03.distanceUnits = METERS;
Serial.print(" Altitude, Meters = ");
printFloat( HP03.getAltitude(p * 100L) /10.0, 1);
Serial.println();
HP03.distanceUnits = FEET;
Serial.print(" Altitude, Feet = ");
printFloat( HP03.getAltitude(p * 100L), 2);
Serial.println();
start = millis();
if(HP03.update() == false)
Serial.println("Error getting HP03 data, check sensor connection");
else {
int dur = millis() - start; // calculate conversion time
output('T', HP03.Temperature/10.0, 1);
output('P', HP03.Pressure/100.0, 2);
output('A', HP03.getAltitude(HP03.Pressure)/10.0, 1);
output('C',dur,0); // conversion time in ms
start = millis();
void output( char tag, float value, int decimalPlaces){
//send the value to the serial port with the given tag, format using given number of decimal places
Serial.print('>'); // this is our message start indicater
Serial.print(tag);
Serial.print('=');
printFloat(value,decimalPlaces);
Serial.println();
void printFloat( float val, byte decimalPlaces){
// prints val with the given number of decimal places
unsigned int precision;
Serial.print( (long)val ); //prints the integer part
if(decimalPlaces != 0){
Serial.print("."); // print the decimal point
for(precision=1; decimalPlaces--; precision *= 10)
unsigned int frac;
if(val >= 0)
frac = (val - int(val)) * precision;
frac = (int(val)- val ) * precision;
Serial.print(frac,DEC) ;
HP03.h header file to go into the library directory
HP03.h - Arduino library support for HP03 Pressure sensor
Copyright (c)2008 Michael Margolis All right reserved
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Version: 1.0 - July14 2008
#ifndef HP03_H
#define HP03_H
typedef unsigned char boolean;
define some constants for errors based on the return values
of the functions in utility/twi.c
#define WIRE_OK 0
#define WIRE_ERR_NO_BUFFER_SPACE 1
#define WIRE_ERR_BAD_ADDRESS 2
#define WIRE_ERR_NOT_IN_TRNSMISSION_MODE 2
#define WIRE_ERR_DATA_NO_ACK 3
#define WIRE_ERR_BUS 4
typedef enum distanceUnits_t {METERS, FEET};
class HP03class // shell class for HP03 glcd code
private:
// methods to send and receive data via I2C
int i2cTransfer(unsigned char Address, const unsigned char *TxBuf, int TxBytes, unsigned char *RxBuf, int RxBytes);
int i2cSendCommand(unsigned char Address, unsigned char Command);
int i2cMeasure(unsigned char SubType);
int i2cResult(unsigned int *Result);
public:
HP03class();
float Temperature;
float Pressure;
long Altitude;
unsigned int rawPressure; // D1 - raw values are only for test purposes
unsigned int rawTemperature; // D2
distanceUnits_t distanceUnits; // METERS or FEET
boolean begin( void );
boolean getCalibrationData();
#ifdef PRINT_CALIBRATION_DATA
void HPO3class::printCalibrationData();
#endif
boolean update();
boolean readRawData();
void calculatePressureAndTemperature();
long getAltitude(long pressure); //pressure is 100 times what it should be
extern HP03class HP03;
#endif
The cpp file is in the next post
HP03.cpp - Arduino library support for HP03 Pressure sensor
// Note that this code uses the return values in Arduino version 0012 wire.c library
extern "C" {
#include <avr/pgmspace.h>
#include <wiring.h>
#include <Wire.h>
#include "HP03.h"
#if !defined(NULL)
#define NULL 0
#endif
// #define PRINT_CALIBRATION_DATA //undefine these to print low level data for debug purposes
// I2C defines
#define MCLK_pin 16 // Arduino uses analog pins 4 and 5 for I2C
#define XCLR_pin 17
#define HP03_I2C_SENSOR_ADDRESS 0x77
#define HP03_I2C_CALIBRATION_ADDRESS 0x50
#define HP03_MEASURE_COMMAND 0xff
#define HP03_RESULT_COMMAND 0xfd
#define HP03_PRESSURE_SUBTYPE 0xf0
#define HP03_TEMPERATURE_SUBTYPE 0xe8
#define HP03_RESULT_SUBTYPE 0xef
// macro to convert two bytes in an arrya to an int
#define GET_BIGENDIAN_WORD(x, y) ((((unsigned int)x[y]) << 8) | x[y+1])
// Pressure to altitude conversion defines
#define MAX_PRESSURE 1100L // in Hpa
#define PRESSURE_ARRAY_ELEMS 80 // number of elements in pressure array
#define PRESSURE_INC 10L // 10Hpa between array values in altitude table
#define HP03_NUM_COEFF 7
#define HP03_NUM_PARAMS 4
enum coefficients { C1,C2,C3,C4,C5,C6,C7};
enum params { AA,BB,CC,DD};
unsigned int coeff[HP03_NUM_COEFF]; // these are marked C1 through C7 in the datasheet
byte sensorParams[HP03_NUM_PARAMS]; // these are marked a,b,c,d in the datasheet
long int pow2(byte value){ // return value raised to the power of 2
long uiData = 2;
while(--value){
uiData <<= 1;
return uiData;
//********* I2C functions ******************
int HP03class::i2cTransfer(unsigned char Address, const unsigned char *TxBuf, int TxBytes, unsigned char *RxBuf, int RxBytes){
// send bytes to the given address and receive bytes from that address
int ret = WIRE_OK;
if(TxBytes > 0){ // send data if TxBytes greater than 0
if(TxBytes > BUFFER_LENGTH)
ret = WIRE_ERR_NO_BUFFER_SPACE ;
else{
Wire.beginTransmission(Address); // transmit to device
while(TxBytes--){
Wire.send(*TxBuf++);
ret = Wire.endTransmission(); // stop transmitting
if (RxBytes > 0 && ret == WIRE_OK){ // receive given number of byts if send ok
Wire.requestFrom(Address, (uint8_t)RxBytes);
while(Wire.available() && RxBytes--)
char c = Wire.receive();
*RxBuf++ = c;
return ret;
int HP03class::i2cSendCommand(unsigned char Address, unsigned char Command){
Wire.send(Command);
return Wire.endTransmission(); // stop transmitting
int HP03class::i2cMeasure(unsigned char SubType){
// Start a measurement on the HP03, returns WIRE_OK on success else WIRE error code
unsigned char TxBuf[2];
TxBuf[0] = HP03_MEASURE_COMMAND;
TxBuf[1] = SubType;
return i2cTransfer(HP03_I2C_SENSOR_ADDRESS, TxBuf, sizeof(TxBuf), NULL, 0);
int HP03class::i2cResult(unsigned int *Result){
// Get a measurement result from the HP03, returns WIRE_OK on success else WIRE error code
unsigned char RxBuf[2];
int Status;
TxBuf[0] = HP03_RESULT_COMMAND;
TxBuf[1] = HP03_RESULT_SUBTYPE;
Status = i2cTransfer(HP03_I2C_SENSOR_ADDRESS, TxBuf, sizeof(TxBuf), RxBuf, sizeof(RxBuf));
*Result = (RxBuf[0] << 8) | RxBuf[1];
return Status;
HP03class::HP03class(){
boolean HP03class::begin( void ){
// set control pins for output
pinMode(MCLK_pin, OUTPUT);
pinMode(XCLR_pin, OUTPUT);
digitalWrite(XCLR_pin,LOW) ;
/* set up TIMER2 to 32768Hz with 50/50 mark/space ration with output on */
pinMode(11,OUTPUT); // frequencyTimer2 is hard coded to output on this pin
FrequencyTimer2::setPeriod(31); // 31us = 32258hz
FrequencyTimer2::enable();
Wire.begin();
return getCalibrationData(); // returns true if ok, if false then probably sensor not detected
boolean HP03class::getCalibrationData(){
// read the calibration values from the sensor, return true if ok, false if error
unsigned char CalData[18];
boolean ret;
ret = (i2cSendCommand(HP03_I2C_CALIBRATION_ADDRESS, 16) == WIRE_OK);
if (ret == true){
if(i2cTransfer(HP03_I2C_CALIBRATION_ADDRESS, NULL, 0, CalData, sizeof(CalData)) == WIRE_OK) {
for (int i = 0; i < HP03_NUM_COEFF; i++)
coeff[i] = GET_BIGENDIAN_WORD(CalData, i*2);
for (int i = 0; i < HP03_NUM_PARAMS; i++)
sensorParams[i] = CalData[( HP03_NUM_COEFF * sizeof(int)) + i];
ret = true;
#endif
return ret;
void HP03class::printCalibrationData(){
int Count;
for (Count = 0; Count < HP03_NUM_COEFF; Count++) {
Serial.print("Coeff C");
Serial.print((char)('1' + Count));
Serial.print(" = ");
Serial.println((unsigned long)coeff[Count],DEC);
for (Count = 0; Count < HP03_NUM_PARAMS; Count++) {
Serial.print("Param");
Serial.print((char)('A' + Count));
Serial.println( (unsigned)sensorParams[Count],DEC);
Serial.println();
#endif
boolean HP03class::update(){
if(readRawData()){
return true;
return false;
boolean HP03class::readRawData(){
digitalWrite(XCLR_pin,HIGH);
// send temperature measurement command
if ( i2cMeasure(HP03_TEMPERATURE_SUBTYPE) != WIRE_OK) {
digitalWrite(XCLR_pin,LOW);
return false;
delay(40);
if( i2cResult(&rawTemperature) != WIRE_OK){
return false;
if (i2cMeasure(HP03_PRESSURE_SUBTYPE) != WIRE_OK) {
return false;
delay(40);
if( i2cResult(&rawPressure) != WIRE_OK){
return false;
return true;
void HP03class::calculatePressureAndTemperature(){
double MiddleData1;
double MiddleData2;
double MiddleData3;
double MiddleData4;
double dUT;
double SENS;
double OFF;
double X;
MiddleData1 = (long)rawTemperature - coeff[C5];
MiddleData2 = MiddleData1 * MiddleData1/16384;
if(rawTemperature < coeff[C5])
MiddleData3 = MiddleData2 * sensorParams[BB];
MiddleData3 = MiddleData2 * sensorParams[AA];
MiddleData4 = pow2(sensorParams[CC]);
MiddleData4 = MiddleData3 / MiddleData4;
dUT = MiddleData1 - MiddleData4;
//OFF = (C2+(C4-1024)*DUT/Get2_x(14))*4;
MiddleData1 = (long)coeff[C4] - 1024L;
MiddleData2 = pow2(14);
MiddleData3 = dUT * MiddleData1;
MiddleData4 = MiddleData3 / MiddleData2;
MiddleData4 = (long)coeff[C2] + MiddleData4;
OFF = MiddleData4 * 4;
//SENS = C1+C3*DUT/Get2
MiddleData1 = (long)coeff[C3] * dUT;
MiddleData2 = pow2(10);
MiddleData3 = MiddleData1 / MiddleData2;
SENS = coeff[C1] + MiddleData3;
//X = SENS*(D1-7168)/ Get2_x(14)-OFF;
MiddleData1 = pow2(14);
MiddleData2 = (long)rawPressure - 7168;
MiddleData3 = MiddleData2 * SENS;
MiddleData4 = MiddleData3 / MiddleData1;
X = MiddleData4 - OFF;
//Pressure = X*100/Get2_x(5)+C7*10;
MiddleData1 = X * 100;
MiddleData2 = pow2(5);
MiddleData4 = coeff[C7] * 10;
Pressure = MiddleData3 + MiddleData4;
Temperature = 250 + dUT * coeff[C6] / pow2(16) - dUT / pow2(sensorParams[DD]);
static prog_int32_t BasicAltitude[PRESSURE_ARRAY_ELEMS] PROGMEM = {
-6983,-6201,-5413,-4620,-3820,-3015,-2203,-1385,-560, 270, //0.1m
1108, 1953, 2805, 3664, 4224, 5403, 6284, 7172, 8068, 8972,
9885, 10805,11734,12671,13617,14572,15537,16510,17494,18486,
19489,20502,21526,22560,23605,24662,25730,26809,27901,29005,
30121,31251,32394,33551,34721,35906,37106,38322,39553,40800,
42060,43345,44644,45961,47296,48652,50027,51423,52841,54281,
55744,57231,58742,60280,61844,63436,65056,66707,68390,70105,
71854,73639,75461,77323,79226,81172,83164,85204,87294,89438};
long altitudeValue_P(int address){
// return the value of the altitude table
return pgm_read_dword(&BasicAltitude[address] );
long HP03class::getAltitude(long pressure){ //pressure is 100 times what it should be
int index;
long AltitudeDifference,PressureDifference;
long fraction;
long alt;
index = (MAX_PRESSURE - pressure/100) / PRESSURE_INC + 1;
if (index >= PRESSURE_ARRAY_ELEMS)
index = PRESSURE_ARRAY_ELEMS-1;
AltitudeDifference = altitudeValue_P(index) - altitudeValue_P(index-1);
PressureDifference = pressure - ((MAX_PRESSURE - (index* PRESSURE_INC))*100);
fraction = (AltitudeDifference *1000) - (PressureDifference * AltitudeDifference) ;
alt = ((altitudeValue_P(index-1) * 10) + (fraction/100))/10;
if(distanceUnits == METERS)
return alt;
return (long)(alt * 0.328084);
HP03class HP03 = HP03class();
Thanks so much for the info. I have put all the libraries etc in but am getting some errors when trying to compile.
In file included from C:\arduino-0012\hardware\cores\arduino/WProgram.h:4,
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:80: error: expected unqualified-id before 'int'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:80: error: expected `)' before 'int'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:111: error: expected unqualified-id before 'int'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:111: error: expected `)' before 'int'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:144: error: expected identifier before '(' token
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:144: error: expected `)' before '(' token
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:144: error: expected ',' or '...' before '(' token
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:144: error: expected initializer before ')' token
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:176: error: '__compar_fn_t' has not been declared
In file included from C:\arduino-0012\hardware\cores\arduino/WProgram.h:6,
I have confirmed that other programs are compiling ok so could this be something to do with the mod wire library you where talking about ?. It is prb just something I have done wrong when copying it over but it is strange as it does not seem to be referring to any of the new includes.
P.s Im still very new at all this ;)
hmm, to test I copied the files posted back onto my computer and they compile ok for me. Are you using the test sketch I posted? Are HP03.h and HP03.cpp copied to a directory called HP03 in the hardware/libraries directory? (Note there are three files named HP03.pde, HP03.H and the third needs to be called HP03.cpp)
Mem, I *haven't* tried this code, but these are exactly the types of errors (stdlib.h:80) that people get when compiling old libraries with 0012. My guess is that it works for you because you disabled or undefined those pesky "function-style" cast macros in wiring.h"? If so, perhaps you'd care to share your method?
Mikal
Thanks Mikal, I had forgotten that I had removed those pesky macros in my working copy of wiring,h.
#ifdef USE_PESKY_MACROS
#define int(x) ((int)(x))
#define char(x) ((char)(x))
#define long(x) ((long)(x))
#define byte(x) ((uint8_t)(x))
#define float(x) ((float)(x))
#endif
Right-o! maca, if you follow mem's example and add the #ifdef/#endif to your copy of wiring.h (effectively removing the five #defines in between), you will probably get happiness.
Mikal
Strange thing is that I just tried re-compiling the code I posted and even with the macros enabled it compiled ok. hmm?
Thanks for all your help so far guys, I have entered the info listed below and it has def reduced the amount of errors but still will not compile. Now it says
Any ideas on this one ?
Thanks
Yeah, also remove the #define of abs() in wiring.h.
Mikal
Well spotted Mikal, I do have that commented out as well !
Did you mean to remove this
#define abs(x) ((x)>0?(x):-(x))
When I remove that I get
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected unqualified-id before 'double'
c:/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected `)' before 'double'
down to 3 errors :P
remove this:
#define round(x) ((x)>=0?(long)((x)+0.5) (long)((x)-0.5))
(although it compiles ok on my system as is)
duh forgot to bring xclear high, Working perfectly now got lost of lovely data coming threw and looks like rain is on the way :P.
Thanks so much for your help both of you have been a wealth of information. Also do you have any idea how accurate these things are in the real world the temp and pressure are spot on but the altitude is out by about 450m or so, but I guess pressure i Probly not the best way to measure altitude.
Because the pressure is varying with atmospheric conditions, you need to set an offset in the pressure value to correct it to a known altitude (or exact pressure). I may add that function to the library, but for now you will need to do it in your sketch.
I think my sensor was accurate to around 5 or 10 meters, but its been a while since I designed and tested the library so have forgotten that exact figure.
If you do some tests please do report on your results. I hope you enjoy using the library as much as I enjoyed writing that code.
First, thanks so much for all the great information!
I'm using the HP01D and I had the exact same experience as maca_404 getting the code to compile.
I'm a bit new to the arduino though, and I'm not what it means to bring xclear high:
Here is what I'm getting now, which I'm guessing is similar to what maca_404 got at first:
Error getting HP01D calibration, check sensor connection
pressure 1100
Altitude, Meters = -698.2
Altitude, Feet = -2291.0
pressure 1050
Altitude, Meters = -301.5
Altitude, Feet = -989.0
pressure 1000
Altitude, Meters = 110.8
Altitude, Feet = 363.0
pressure 950
Altitude, Meters = 540.2
Altitude, Feet = 1772.0
pressure 900
Altitude, Meters = 988.5
Altitude, Feet = 3243.0
pressure 850
Altitude, Meters = 1457.1
Altitude, Feet = 4780.0
pressure 800
Altitude, Meters = 1948.9
Altitude, Feet = 6394.0
pressure 750
Altitude, Meters = 2466.1
Altitude, Feet = 8091.0
pressure 700
Altitude, Meters = 3012.1
Altitude, Feet = 9882.0
pressure 650
Altitude, Meters = 3590.6
Altitude, Feet = 11780.0
pressure 600
Altitude, Meters = 4206.0
Altitude, Feet = 13799.0
pressure 550
Altitude, Meters = 4865.2
Altitude, Feet = 15961.0
pressure 500
Altitude, Meters = 5574.3
Altitude, Feet = 18288.0
pressure 450
Altitude, Meters = 6343.6
Altitude, Feet = 20812.0
pressure 400
Altitude, Meters = 7185.3
Altitude, Feet = 23574.0
pressure 350
Altitude, Meters = 8117.2
Altitude, Feet = 26631.0
Error getting HP01D data, check sensor connection
If anyone can explain this to me, I'd greatly appreciate it!
mem, thank you for posting this library. I was able to compile the sketch under IDE 15 after fuddling with frequencytimer2 library. I have two questions though. I am using Arduino Pro Mini, which is 16MHz instead of 8MHz, and I was wondering if something needs to be changed to account for this. For example, will line 141 in HP03.cpp be still accurate?
Also, I actually have HP02D sensor, which is very similar, but it works with 5V. When comparing the spreadsheets I can see some differences in how the pressure is calculated. Do you happen to have a library for the HP02 sensor as well?
Thanks,
Nick
Hi Nick, you should not need to change anything to use the code on 16MHz or 8MHz boards, although I have only tested on 16MHz boards. FrequencyTimer2 adjusts to a board specific clock value when it is compiled should produce the correct frequencies for your board.
I have not looked at the HP02D sensor but the HP03 code could be modified to use the calculations needed for that sensor. Unfortunately, its not an easy task and I don't have the time to do this, sorry. The HP03 costs less than $10 from Futurlec so the easiest thing may be to use that module instead of the HP02.
mem, thanks for the reply. I was trying to avoid using HP03, because it is 3V device. I am prototyping an altitude monitoring system for RC helicopter. I only have 5V rail available there and I am trying to keep the number of components to a minimum (I will need additional 3V regulator and logic level converter if HP03 is used).
Anyway, your library is very well commented, so I will try to make HP02 version. The differences I see so far are in the wait time between readings: 32ms vs 40ms, and in HP02 there are only 5 calibration constants to be read. I will post here if I run into trouble.
Do you know any other low-cost pressure sensor which is easy to integrate with Arduino?
Thanks,
Nick
Modifying the library to support the hp02 is certainly possible if you are comfortable coding the math needed for the calculations.
But integrating the hp03 is not difficult if your controller board has a 3.3 volt supply (or you can use a couple of diodes to drop the 5 volts line). You can do the logic level conversion with a couple of FETs and a six resistors.
Which is easier depends on whether you are more comfortable working in software or hardware.
Have fun!
Well, I went ahead yesterday and updated the library. so far no cigar. Arduino shoots back to the serial port some garbled symbols. Even the normal text sent from the sketch is not recognizable. I wen back to the original library and I see the same thing. Some how the serial communication is not working properly even with the sensor disconnected. I wonder it this has something to do with the fact I am using IDE 15 and Atmega 328. Your thoughts?
The example sketch posted earlier in this thread uses 19200 baud, have you set that rate in the serial monitor?
Hm, no, I did not. But I can execute other sketches using this bit rate without any problem.
I am not sure what you are saying. My question was about ensuring the baud rate on the serial monitor viewing the serial data matches the 19200 baud being sent. If the anwswer is no then that is why you are seeing gibberish characters.
OK, I'll check again when I get home. In the mean time I was looking at the sensor spreadsheet and I could not figure out where the following values are coming from:
Why 0x77 and 0x50?
Also, I assume the following code refers to PB4(MISO) and PB5(SCK) atmega pins:
#define XCLR_pin 17
PB5 (17) on Atmega 328 in Arduino Pro Mini is connected to the green LED via 330 om resistor. I am not getting a good square signal there, so I am using PB3 (pin 15) instead.
In this regards, it would be nice if you could provide the pin connections, as you have them in your setup (Atmega -> HP03)?
Thanks again for your help.
Nick
The Arduino I2C wire library requires that you divide the datasheet address by 2. The HP03 sensor address is 0xEE, which is 0x77 after dividing by 2. See the wire library reference page here: http://www.arduino.cc/en/Reference/Wire
I have not used a Pro Mini, but according to the reference page: "The Pro Mini has 6 analog inputs, each of which provide 10 bits of resolution (i.e. 1024 different values). Four of them are on the headers on the edge of the board; two (inputs 4 and 5) on holes in the interior of the board. "
MCLK_pin is analog pin 4
XCLR_pin is analog pin 5
So the sensor connects to analog pins 4 and 5. Although you don't need the following information, you may be interested in knowing that analog pin 4 is also digital pin 16, this is physical port PC4 on the controllers chips physical pin numbered 27.
Wow, this is getting confusing. The analog input 4 and 5 are also marked as SDA and SCL. I thought I need to connect there SDA and SCLK pins from the sensor. If you are saying I need to connect MCLK to analog 4 and XCLR to analog 5, then where the SDA and SCLK go to?
BTW, the serial communication is working now. I found I need to press the reset button, after I start the monitor. Sure enough, the message is 'Error getting HP03 data'. Not surprising, considering the mess with the pins assigment.
The comment in that code is confusing ( I even forgot what I meant by it)
I2C uses analog pins 4 and 5:
SDA (data line) is on analog input pin 4
SCL (clock line) is on analog input pin 5.
MCLK is on analog pin 2 (the code uses it as digital pin 16)
XCLR is on analog pin 3 (used as digital pin 17)
I hope that helps with the connections.
BTW, I think the wire library may have been modified slightly since I last ran this code so you if you still get errors, you may need to fiddle with the wire error return codes.
Thanks, mem.
In the sketch, there is a comment:
I understand that means MCLK should be connected to digital pin 11 (PB3, MOSI), but your last comment puts it to analog pin 2 (PC2, ADC2). Which one is the correct assigment?
The HP03 was so many projects ago I can't remember the pin assignments but suspect that I may have changed from generating the clock within the library using that analog pin to using FrequencyTimer2 which has a hard coded output pin.
Unfortunately, I am travelling for the next week or so and won't be able to check my notes until I get back. There may also be some clues in the posts earlier in the thread.
No problem. The following line pretty much describes it:
Just to be sure, I've checked the board with oscilloscope and I confirmed the signal is on pin 11. Resoldered MCLK wire and now I am getting some data back from the sensor.
I wanted to verify the coefficient values, so I uncommented #define PRINT_CALIBRATION_DATA and tried to compile the HP03 library. I've got a bunch of errors about missing references to printCalibrationData().
After some head scratching I moved the definition line before #include "HP03.h" line. This removed some of the errors.
I also replaced
with
void printCalibrationData();
in the HP03.h file.
That helped and the errors are now reduced to the following:
HP03.cpp: In member function 'void HP03class::printCalibrationData()':
HP03.cpp:174: error: 'Serial' was not declared in this scope
HP03.cpp:177: error: 'DEC' was not declared in this scope
Any idea how to add a reference to Serial here?
Thanks,
Nick
if you include HardwareSerial.h you will get the definitions for Serial and DEC.
Included the reference and the library compiles OK. However, no calibration information is sent to the serial port. Not a big deal, since I am getting some good data back from the sensor - 992 hPa, and 175m altitude, which seems about right . I can move forward with my project now. Thank you again for your help.
You must remove the initial comment from the following line in HP03.cpp to print the calibration data:
// #define PRINT_CALIBRATION_DATA //uncomment this to print low level data for debug purposes
Anyway, good to hear you have it working. Why not post the changes needed for the HP02 version for others that want to use this module
Uncommenting that line is the first thing I did, as posted already. Still, no data is sent to the port.
Regarding my HP02 sensor, it turned out it is closer to this spec: http://www.picbasic.org/forum/attachment.php?attachmentid=2040&d=1188053824
which is different from the spreadsheet I was initially working with: http://www.futurlec.com/HP02D.shtml
This is very confusing, since both documents claim to be version 1.0, yet they contain different data.
Reverting back to the original code published here gives me good results with my HP02.
mem, do you know if it is possible to speed up the readings from the sensor? Right now it takes 95mS to complete a sensor reading. This gives me approximately 10 readings per second, which might not be enough in my application. Any thoughts?
hi, i need help.
i'm using the HP03D , compile and works ok. But the readings are not correct, i dont know the correct altitude o pressure on my city, but when start the reading, temperature stars on 29.xx and few minutes later is 36.xx, however the real temperature is about 22 degrees. How calibrate the sensor or what i need to do. Thanks. Greetings from puebla, Mexico.
The I2C works at 100kHz, I believe it is possible to hack the library and get it to run at 400kHz. There was a post on this a few months back.
Nikivan, the spec sheet says the conversion time is 35ms and you need some time for all those floating point calculations. Its just a guess, but I would be surprised if you could more than double the conversion rate, no matter how fast the i2c clock rate.
What is your application and how fast do you need it?
ricarDOGS, not sure what to suggest, can you post a picture of your wiring.
mem, my application is an altitude hold function for RC helicopter. So far I have the Arduino generate audio signal which indicates when the helicopter ascends, descends, or it hovers at fixed altitude. My next step is to have the board read a receiver channel (or several channels) and generate a servo impulse. This presents some challenges since the Timer 2 is already taken and I am working at the hardware limits here. Now that you mention the 35mS conversion time, I think 50mS is probably the best time I would ever achieve (after some optimization of the calculations code). This might be OK for my needs.
@ricarDOGS. I also noticed my temperature readings are a little bit high, but not as extreme as yours. Your problem could be as simple as defective sensor.
nikivan, looks like a fun project, I would like to see more. Why not start a thread in the exhibition area with more info and updates from time to time. I am sure others would also be interested in following progress.
I doubt the HP03 sensor has an output that can be relied on to indicate the distance a heli would move vertically in less than a tenth of a second. Bear in mind that the sensor output is not absolutely stable, mine fluctuated by at least a few feet when sitting on a desk (I can't remember the exact figure, it could have been higher) . If you are primarily looking for tight control of altitude you may want to consider adding an accelerometer through a Kalman filter to drive your altitude control ( I presume you are using a variable pitch head, I would think fixed pitch would not be responsive enough)
If timer2 is used for the 32khz signal, perhaps replace that with an external signal source (a 555 timer may be good enough - plenty of circuits can be found using google)
i use the files HP03.pde, HP03.h and HP03.ccp. I removed the lines indicates in Post #6,#10,#13. On arduino Duemilanove conected :
Vss-GND
Vdd-3.3V
MCLK-Pin 11
XCLR-Analog 3
SDA.Analog 4
SCL-Analog 5
4,7 uF between 3.3V and GND
10Kohm between 3.3V and SDA
it´s Right??
I
The HP03 is not rated for 5 volt operation. I use FET level translators on the I2C pins and simple resistor voltage dividers on the sensor inputs (2.2k and 3.6k resistors).
I posted a diagram the FET level translator here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1225292345/6#6
I never got around to documenting the wiring but FWIW, here is a picture of the mini shield I made to test the sensor
(http://farm3.static.flickr.com/2483/3700855735_01c81d5517.jpg?v=0
Ok, thanks. It´s possible that i get damaged the sensor?
Driving the inputs .7 volts higher than the Vcc voltage will damage some chips, I don't know how sensitive this particular device is.
PM me if you want to send your HP03 to me so I can try it on my test rig.
Hi, mem. I want to use your hp03.pde to make my project. But my board is nano . I think something must be changed in hp03.pde or more. But I am a newbie in C/C++. Can you help me for that?
Best regard.
wlwl
Hi wlwl, I don't use the Nano but would think it should work just like the full size Arduino boards I do use. Why do you think something needs changing?
Oh,thanks your notice. Let me test it in nano! ;) ;)
Thanks, Mem.
I´m using IRF3205 and 10K resistors, but i dont get data. Just this:
pressure 1100
pressure 1050
pressure 350
pin 11 is a resitor voltage?? i used R1=1.8K and R2=3.3K and this conected to MCLK. It´s Ok???
Analog 3 is conected to XCLR with a 10K resitor??
what´s wrong? i bought a new sensor.
thanks.
the reisitor between 5V and Drain aren´t conected. I corrected this, but now when starts the serial comunication (19200 or other) nothing happens. only black screen all the time.
again, whats wrong????
thanks.
ricarDOGS, its very difficult to debug something like this remotely. Because there is not much explanation on how to connect things up, it's likely that the problem lies somewhere there. Perhaps if you can take a clear picture of your wiring it may be possible to see if something is amiss.
Do you have any previous experience with interfacing 3.3v to 5v logic levels? Did any of the HP03 pins get connected directly to an arduino pin or 5 volts when you first connected things up?
is that clear?
Tahnks.
(http://hosting.udlap.mx/estudiantes/ricardoj.gonzalezmz/HP03.bmp)
That looks very much like the circuit on the board I made. I will see if I can find the actual circuit diagram I used and will double check and let you know.
By any chance, did you apply +5 volts to any of the HP03 pins, I hope the module is not damaged.
I conected like circuit, but when you confirme if its right, i´ll buy another sensor, just to be sure.Again, thanks.
That looks similar to what I did. Here is my schematic so you can double check :
(http://farm4.static.flickr.com/3498/3722488341_093c2ffebe.jpg?v=0)
Its difficult for me to tell from your diagram but note that the drains are connected to the Arduino, the sources to the sensor.
For the voltage divider resistors (R5-R8) I used 2.2k on both sides but your values are good.
The other resistors were 8.2k but 10k just as good.
Note I have a 0.1 decoupling capacitor across the 3.3v line - may not be necessary but its best to use one.
Here is a board layout suitable for building on stripboard that I used to make the shield I posted earlier.
(http://farm3.static.flickr.com/2460/3723367416_bb05b7283c.jpg?v=0
see: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1223819446/43#43
Ok, it´s the same circuit. Surely the sensor was damaged.
i´m using IRF3205 or SUP85N06 instead of 2n7000, it doesn't matter ??
R1=R2=R3=R4=8.2K??
R5=R6=R7=R8=2.2K??
Anyway, i´ll buy another sensor and tell you what happens.Thanks.
I would think most any N channel FET would work.
Yes, those are my resistor values but yours are just as good.
I changed BS170 instead of IRF3205 and now serial communication starts correctly, however the pressure and altitude change constantly, i don´t know the real values in my city. But the temperature is 30.5 degrees and a LM35 says 28.1 degrees. These 2 degrees of difenrence are normal?? or the sensor was damaged?? thanks.
By how much do the altitude readings vary? If the readings are within 10 meters or so of your actual altitude then the sensor is probably working.
I found in the intertet these altitudes for my city: 2160, 2135,2220.
but, the values of HP03d changes every reading, here is the txt for the readings:
http://hosting.udlap.mx/estudiantes/ricardoj.gonzalezmz/HP03D.txt
pressure is in hPA, right??
thanks.
yess, pressure is in hPa
The altitude variations are higher then they should be but still close enough to the expected readings to indicate that the sensor is probably working.
Do you have a decoupling capacitor on the 3.3v line? How long are the wires connecting the sensor?
Perhaps post a photo of you layout.
These are the pictures of my circuit:
(http://hosting.udlap.mx/estudiantes/ricardoj.gonzalezmz/HP1.bmp)
(http://hosting.udlap.mx/estudiantes/ricardoj.gonzalezmz/hp2.bmp)
(http://hosting.udlap.mx/estudiantes/ricardoj.gonzalezmz/HP3.bmp)
these are readings (today):
http://hosting.udlap.mx/estudiantes/ricardoj.gonzalezmz/Valores2.txt
Altitud must be the same almost always?? because today changes a lot from yesterday.
altitud must be the same almost always?? because today changes a lot from yesterday.
I think your wiring is sort enough not to be causing a problem. It may be worth experimenting to see if its any more stable if you keep the circuit as far from your computer as possible
If you are saying that the readings are more stable then yesterday, I agree.
I wonder if you should try smoothing the output. You should be able to find code in the playground the will provide an moving average.
It would also be interesting to note the atmospheric pressure in your location and see if the readings track the changes in pressure.
ok, it´s possible change pin 11 to another that not interfere with SPI communication??
I`ll use the ethernet shield, but this communicates with pins (10,11,12,13), right?
Thanks.
The HP03 needs a 32kHz signal and this is provided by the FrequencyTimer2 library. FrequencyTimer2 uses hardware PWM to create the signal and this is hard wired in the controller chip to pin 11. If you want to free up pin 11 then you need to provide another source for the 32kHz signal.
One way of doing that is to use a timer chip like the 555. There are lots of resources on the web for this part (google 555), here is one: http://www.doctronics.co.uk/555.htm the circuit you want is called an astable (multivibrator)
To free up pin 11 you need to turn off FrequencyTimer2. In the HP03 library source file you comment out these lines as follows in the begin method:
// pinMode(11,OUTPUT); // frequencyTimer2 is hard coded to output on this pin
// FrequencyTimer2::setPeriod(31); // 31us = 32258hz
// FrequencyTimer2::enable();
For anyone looking to use the HP03 code posted earlier in this thread, here is a new test sketch that displays the various values from the sensor. It includes a function to smooth the altitude readings. I found that individual readings could vary by plus/minus four or five meters. Smoothing the data drops the deviation down to plus/minus a meter or so.
// HP03 example sketch
// prints the temperature, presssure and altitude to the serial port
// also shows the maximum deviation in feet from the average altitude
// Created 17 July 2009
#include <HP03.h>
#include <Wire.h>
const int numReadings = 12; // the number of readings to smooth
// with HP03 conversion rate of 85ms, 12 readings takes one second
long count = 0; // the number of readings taken
long minA = 9999999; // used to show how much the altitude deviates
long maxA = 0;
long deviation;
Serial.begin(9600); // start serial for output
Serial.flush();
count++;
showReadings();
void showReadings()
Serial.print("Temp ");
Serial.print(HP03.Temperature/10.0);
Serial.print(" Pressure ");
Serial.print(HP03.Pressure/100.0);
Serial.print(" Altitude: Meters = ");
Serial.print(HP03.getAltitude(HP03.Pressure)/ 10);
Serial.print(", Feet = ");
long feet = HP03.getAltitude(HP03.Pressure);
Serial.print(feet);
feet = smooth(feet);
if(count >= numReadings)
Serial.print(" smoothed = ");
Serial.print(feet);
if(feet < minA) minA = feet;
if(feet > maxA) maxA = feet;
Serial.print(", deviation = ");
Serial.print( (maxA-minA) /2 );
Serial.println();
long smooth(long value)
static int index = 0;
static long readings[numReadings] ;
static boolean isPrimed = false; // set to true when at least numReadings have been received
static long total = 0;
total = total - readings[index]; // remove the oldest value
readings[index] = value; // store the new value
total= total + readings[index]; // add the reading to the total:
index = index + 1; // advance to the next position in the array:
// if we're at the end of the array...
if (index >= numReadings) // check if this is the end of the array
index = 0; // and wrap to the beginning if so
isPrimed = true; // enough readings received for average
if(isPrimed)
return total / numReadings;
return value; // return the raw value if not enough samples received;
With 555, whats the minimum/highest duty cycle, or it doesn´t matter?
I compiled your new sketch, but i have these errrors. Thanks.
In function 'void showReadings()':
error: call of overloaded 'print(double)' is ambiguousC:\Documents and Settings\12ic412d06\Escritorio\arduino-0012\hardware\cores\arduino/Print.h:37: note: candidates are: void Print::print(char)
C:\Documents and Settings\12ic412d06\Escritorio\arduino-0012\hardware\cores\arduino/Print.h:39: note: void Print::print(uint8_t)
C:\Documents and Settings\12ic412d06\Escritorio\arduino-0012\hardware\cores\arduino/Print.h:40: note: void Print::print(int)
C:\Documents and Settings\12ic412d06\Escritorio\arduino-0012\hardware\cores\arduino/Print.h:41: note: void Print::print(unsigned int)
C:\Documents and Settings\12ic412d06\Escritorio\arduino-0012\hardware\cores\arduino/Print.h:42: note: void Print::print(long int)
C:\Documents and Settings\12ic412d06\Escritorio\arduino-0012\hardware\cores\arduino/Print.h:43: note: void Print::print(long unsigned int)
It uses floating point support in the serial code. As I recall this was introduced in version 0013. Looks like you are using version 0012.
If you change 10.0 to 10 and 100.0 to 100 it should compile in 0012 but you will lose the values after the decimal point.
Why not upgrade to a later version?
I don't know if the duty cycle matters. See how close you can get to 50% and see if it works.
Hi, i compare my readings whith DAVIS weather station, and i'm 8-11 hpa under the DAVIS, and that´s much. Datasheet HP03d says that pressure accuracy is about plus/minus 1hpa.
Some idea about what´s happening?
Temperature Readings are OK comparated with DAVIS and SHT15.
thanks.
Are you at exactly the same altitude as that station, 8-11 hpa lower would be perhaps a hundred meters higher.
Also, the spec may be for the relative accuracy (after calibration). You can calibrate the values by adding (subtracting) a constant to the readings.
yes, DAVIS and HP03d(with metoerological shelter ) are togheter. the problem if i add a constant, it isn´t lineal. sometimes the difference is 8.XX and sometimes is 11.XX mb. thanks.
Have you tried measuring at significantly different altitudes? Is the variation still +-1.5 hpa or does the error increase or decrease at different altitudes.
I've had mixed results so far with the HP03. I develop using a netbook running Ubuntu Linux, and was not able to fix compiling errors using version 0018. I tried installing 0011 and 0012 but they would not run (I guess this is a limitation of the OS--I'm a Mac guy without a lot of experience with Linux).
Next I switched to Mac OSX Leopard and loaded 0012. With the adjustments to wiring.h as described earlier in this thread, I was able to get the data stream in the serial monitor. According to Google Earth I'm located at 77m but the HP03 says I'm -44m, and although Environment Canada gives the pressure at 1031, the HP03 says it's 1018.
I'm interested in the barometric pressure delta so absolutes are not necessary, but it is troubling that I can't get accuracy as close as is claimed by the datasheet.
Later on in this thread mem offers another sketch, which I loaded and tried to run with 0012 but had similar compile errors to ricarDOGS. mem suggests upgrading to 0013. Has anyone had success using this library with the most recent distribution 0018?
The code posted compiles without errors on 0018, although I have only tested this on a windows machine.
What errors did you get?
I get two errors with the newer sketch. I'm running Ubuntu Linux 9.04 and Arduino release 0018 (with the revisions to Wiring.h as prescribed earlier in this thread):
/home/mbl/Desktop/arduino-0018/hardware/arduino/cores/arduino/HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long int)':
/home/mbl/Desktop/arduino-0018/hardware/arduino/cores/arduino/HardwareSerial.cpp:144: error: 'abs' was not declared in this scope
Thanks for the quick response... I'm anxious to get the new sketch working since, as you say, it may give more reliable data than the original one through averaging.
The changes that I made to wiring.h broke other sketches in 0018, so I restored wiring.h back to its original state.
With the original wiring.h, I receive a different set of errors:
/usr/lib/gcc/avr/4.3.2/../../../avr/include/stdlib.h:111: error: expected unqualified-id before 'int'
/usr/lib/gcc/avr/4.3.2/../../../avr/include/stdlib.h:111: error: expected `)' before 'int'
These errors look familiar to me but I don't know my way around things well enough to make sense of this.
the errors are because there are some definitions in wiring.h that cause conflicts with the standard C libraries.
try replacing the includes in the HP03.cpp library so just the following are included:
#include <WProgram.h>
#include <Wire.h>
#include "HP03.h"
The top of the file should look like this:
#include <Wire.h>
#include "HP03.h"
#if !defined(NULL)
#define NULL 0
#endif
The rest of the file should be unchanged
Thanks! I'll take a look later today.
Is it easy to explain why the second include does not have a "#" in front of it?
its a cut and paste errror
I have modifed the post to show the correct includes
No joy. Precisely the same errors (as I last mentioned in reply 77) remain. One thing I did not notice earlier is that in the upper sketch code portion of the window, the FrequencyTimer2 include is highlighted, suggesting that the problem is there...?
[glow]#include <FrequencyTimer2.h>[/glow]
If the problem is in FrequencyTimer2 then try moving this include:
#include <wiring.h>
from FrequencyTimer2.h to FrequencyTimer2.cpp
When I moved the include as instructed, I encountered these errors:
/home/mbl/sketchbook/libraries/FrequencyTimer2/FrequencyTimer2.h:30: error: 'uint8_t' does not name a type
/home/mbl/sketchbook/libraries/FrequencyTimer2/FrequencyTimer2.cpp:27: error: 'uint8_t FrequencyTimer2::enabled' is not a static member of 'class FrequencyTimer2'
/home/mbl/sketchbook/libraries/FrequencyTimer2/FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::setPeriod(long unsigned int)':
/home/mbl/sketchbook/libraries/FrequencyTimer2/FrequencyTimer2.cpp:96: error: 'enabled' is not a member of 'FrequencyTimer2'
/home/mbl/sketchbook/libraries/FrequencyTimer2/FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::enable()':
/home/mbl/sketchbook/libraries/FrequencyTimer2/FrequencyTimer2.cpp:146: error: 'enabled' is not a member of 'FrequencyTimer2'
/home/mbl/sketchbook/libraries/FrequencyTimer2/FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::disable()':
/home/mbl/sketchbook/libraries/FrequencyTimer2/FrequencyTimer2.cpp:156: error: 'enabled' is not a member of 'FrequencyTimer2'
I thought that maybe I should have not removed the include from FrequencyTimer2.h, so I put it back in, but this did not change the situation from the three errors encountered before.
try including only <WProgram.h> in FrequencyTimer2.h
Thanks mem, it works, and it's a beautiful thing! If I'm ever in London I'll buy you a beer.
good to hear you have it going.
Have fun
I ran the sketch overnight but at some point it hung, giving an indeterminate number of error statements in red. I had hoped to be able to transcribe the error but Arduino 0018 has frozen and the window is now white. I remember that it mentioned that it was a JAVA out of memory error.
I realize that this could be caused by a wide variety of factors, but we did make some changes to some of the libraries and I thought I should mention it.
Sounds like its the Serial monitor, do you have another serial program you could use to view the serial output to ensure that is ok.
I don't think anything that was changed on the arduino side would cause the Serial Monitor to freeze.
I think you're right; I restarted 0018 and left the Serial Monitor open. When I returned about 6 hours later the program had hung again.
I just installed a program called "GtkTerm"--also known as "Serial Port Terminal"--and when I started it up and selected the USB port that connects to my Duemilanove, the data streamed right in.
I'll be jettisoning the Serial Monitor anyway in favour of an LCD display (for now anyway). Thanks again.
Another question relating to Arduino's Digital Pin 11, which is used to drive the MCLK on the HP03: I want to use the liquidcrystal library, which uses pin 11 for LCD Enable.
The frequencytimer2 page in the Playground says that (if it's running on an atmega168) this library uses pin 11 and pin 3. I've looked at the frequencytimer2.cpp code to see if there is any mention of pin allocations but if it's there, it's not in clear text. Simply changing the pin in HP03.cpp from 11 to 3 doesn't seem to work.
I'm wondering if this is a case of diminished returns--should I just rig up a 32kHz 555 timer and be done with it?
The LiquidCrystal library uses ANY 6 pins. No need to work around any special pins. Just plug the LCD into 6 pins, and tell the library WHICH 6 pins you used.
