Hello I am trying to use WS2812B LED's to make brake lights for my motorcycle.
I have written a program that lights up an 8x8 panel from the center to the outside when I press button3.
Button 1 and 2 are left and right blinkers so it is okay if they loop.
The problem is the program loops and keeps lighting from the inside out over and over. I want this to happen once and then stay lit until i release the button. What am I doing wrong?
Bonus:
*how do I control the brightness of the LED's using fastLED??
*how do I group LED's - like ROW1 = LED 0-7, ROW2= 8-15... and so on... ?
Use a state machine.
Add a variable oldButtonState = 0;.
if(buttonState1 == HIGH && oldButtonState == LOW) {
// "braking" code here
oldButtonState = HIGH; // so this block can only run once
if(buttonState1 == LOW && oldButtonState == HIGH) {
// "stop braking" code here
oldButtonState == LOW;
Leo..
Okay thanks Leo - I got it to work
but now - I set my stop braking code to be the LED at a lower brightness - which will be my running tail light - so now at the beginning of each code I set all the LED to black so the blinker or stop light can be seen easier.
This screwed up my brake light - it is looping again - if i remove the set LED to black coding from the beginning it works good again - why would the black coding do this?
Line 32 is wrong, mind you this crystal ball is sometimes not very reliable so you better post your code so we can check.
#include <bitswap.h>
#include <chipsets.h>
#include <color.h>
#include <colorpalettes.h>
#include <colorutils.h>
#include <controller.h>
#include <cpp_compat.h>
#include <dmx.h>
#include <FastLED.h>
#include <fastled_config.h>
#include <fastled_delay.h>
#include <fastled_progmem.h>
#include <fastpin.h>
#include <fastspi.h>
#include <fastspi_bitbang.h>
#include <fastspi_dma.h>
#include <fastspi_nop.h>
#include <fastspi_ref.h>
#include <fastspi_types.h>
#include <hsv2rgb.h>
#include <led_sysdefs.h>
#include <lib8tion.h>
#include <noise.h>
#include <pixelset.h>
#include <pixeltypes.h>
#include <platforms.h>
#include <power_mgt.h>
#include "FastLED.h"
// fast led constants
#define DATA_PIN 3 // change to your data pin
#define COLOR_ORDER GRB // if colors are mismatched; change this
#define NUM_LEDS 256 // change to the number of LEDs in your strip
#define FRAMES_PER_SECOND 120
// change WS2812B to match your type of LED, if different
// list of supported types is here:
// https://github.com/FastLED/FastLED/wiki/Overview
#define LED_TYPE WS2812B
#define BRIGHTNESS 200
#define DIM 10
#define ALL 0-255
const int buttonPin1 = 5; // the number of the pushbutton pin
const int buttonPin2 = 6;
const int buttonPin3 = 7;
const int buttonPin4 = 10;
// variables will change:
int buttonState1 = 0; // variable for reading the pushbutton status
int buttonState2 = 0;
int buttonState3 = 0;
int buttonState4 = 0;
int oldButtonState3 = 0;
// this creates an LED array to hold the values for each led in your strip
CRGB leds[NUM_LEDS];
delay(3000); // 3 second delay for recovery
// tell FastLED about the LED strip configuration
FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
//FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
// the wiki features a much more basic setup line:
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS);
// initialize the pushbutton pin as an input:
pinMode(buttonPin1, INPUT);
// set master brightness control
FastLED.setBrightness(BRIGHTNESS);
// List of patterns to cycle through. Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
{ // read the state of the pushbutton value:
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
buttonState3 = digitalRead(buttonPin3);
buttonState4 = digitalRead(buttonPin4);
if(buttonState3 == HIGH && oldButtonState3 == LOW){
// left tail light black
leds[0] = CRGB::Black;
leds[1] = CRGB::Black;
leds[2] = CRGB::Black;
leds[3] = CRGB::Black;
leds[4] = CRGB::Black;
leds[5] = CRGB::Black;
leds[6] = CRGB::Black;
leds[7] = CRGB::Black;
leds[8] = CRGB::Black;
leds[9] = CRGB::Black;
leds[10] = CRGB::Black;
leds[11] = CRGB::Black;
leds[12] = CRGB::Black;
leds[13] = CRGB::Black;
leds[14] = CRGB::Black;
leds[15] = CRGB::Black;
leds[16] = CRGB::Black;
leds[17] = CRGB::Black;
leds[18] = CRGB::Black;
leds[19] = CRGB::Black;
leds[20] = CRGB::Black;
leds[21] = CRGB::Black;
leds[22] = CRGB::Black;
leds[23] = CRGB::Black;
leds[24] = CRGB::Black;
leds[25] = CRGB::Black;
leds[26] = CRGB::Black;
leds[27] = CRGB::Black;
leds[28] = CRGB::Black;
leds[29] = CRGB::Black;
leds[30] = CRGB::Black;
leds[31] = CRGB::Black;
leds[32] = CRGB::Black;
leds[33] = CRGB::Black;
leds[34] = CRGB::Black;
leds[35] = CRGB::Black;
leds[36] = CRGB::Black;
leds[37] = CRGB::Black;
leds[38] = CRGB::Black;
leds[39] = CRGB::Black;
leds[40] = CRGB::Black;
leds[41] = CRGB::Black;
leds[42] = CRGB::Black;
leds[43] = CRGB::Black;
leds[44] = CRGB::Black;
leds[45] = CRGB::Black;
leds[46] = CRGB::Black;
leds[47] = CRGB::Black;
leds[48] = CRGB::Black;
leds[49] = CRGB::Black;
leds[50] = CRGB::Black;
leds[51] = CRGB::Black;
leds[52] = CRGB::Black;
leds[53] = CRGB::Black;
leds[54] = CRGB::Black;
leds[55] = CRGB::Black;
leds[56] = CRGB::Black;
leds[57] = CRGB::Black;
leds[58] = CRGB::Black;
leds[59] = CRGB::Black;
leds[60] = CRGB::Black;
leds[61] = CRGB::Black;
leds[62] = CRGB::Black;
leds[63] = CRGB::Black;
// right tail light black
leds[192] = CRGB::Black;
leds[193] = CRGB::Black;
leds[194] = CRGB::Black;
leds[195] = CRGB::Black;
leds[196] = CRGB::Black;
leds[197] = CRGB::Black;
leds[198] = CRGB::Black;
leds[199] = CRGB::Black;
leds[200] = CRGB::Black;
leds[201] = CRGB::Black;
leds[202] = CRGB::Black;
leds[203] = CRGB::Black;
leds[204] = CRGB::Black;
leds[205] = CRGB::Black;
leds[206] = CRGB::Black;
leds[207] = CRGB::Black;
leds[208] = CRGB::Black;
leds[209] = CRGB::Black;
leds[210] = CRGB::Black;
leds[211] = CRGB::Black;
leds[212] = CRGB::Black;
leds[213] = CRGB::Black;
leds[214] = CRGB::Black;
leds[215] = CRGB::Black;
leds[216] = CRGB::Black;
leds[217] = CRGB::Black;
leds[218] = CRGB::Black;
leds[219] = CRGB::Black;
leds[220] = CRGB::Black;
leds[221] = CRGB::Black;
leds[222] = CRGB::Black;
leds[223] = CRGB::Black;
leds[224] = CRGB::Black;
leds[225] = CRGB::Black;
leds[226] = CRGB::Black;
leds[227] = CRGB::Black;
leds[228] = CRGB::Black;
leds[229] = CRGB::Black;
leds[230] = CRGB::Black;
leds[231] = CRGB::Black;
leds[232] = CRGB::Black;
leds[233] = CRGB::Black;
leds[234] = CRGB::Black;
leds[235] = CRGB::Black;
leds[236] = CRGB::Black;
leds[237] = CRGB::Black;
leds[238] = CRGB::Black;
leds[239] = CRGB::Black;
leds[240] = CRGB::Black;
leds[241] = CRGB::Black;
leds[242] = CRGB::Black;
leds[243] = CRGB::Black;
leds[244] = CRGB::Black;
leds[245] = CRGB::Black;
leds[246] = CRGB::Black;
leds[247] = CRGB::Black;
leds[248] = CRGB::Black;
leds[249] = CRGB::Black;
leds[250] = CRGB::Black;
leds[251] = CRGB::Black;
leds[252] = CRGB::Black;
leds[253] = CRGB::Black;
leds[254] = CRGB::Black;
leds[255] = CRGB::Black;
[/code :) ]
// Turn the first led red for 1 second leds[i] %= 192;
leds[36] = CRGB::Red;
leds[35] = CRGB::Red;
leds[28] = CRGB::Red;
leds[27] = CRGB::Red;
// left brake light
leds[227] = CRGB::Red;
leds[228] = CRGB::Red;
leds[219] = CRGB::Red;
leds[220] = CRGB::Red;
FastLED.show();
delay(200);
leds[42] = CRGB::Red;
leds[43] = CRGB::Red;
leds[44] = CRGB::Red;
leds[45] = CRGB::Red;
leds[37] = CRGB::Red;
leds[29] = CRGB::Red;
leds[21] = CRGB::Red;
leds[20] = CRGB::Red;
leds[19] = CRGB::Red;
leds[18] = CRGB::Red;
leds[26] = CRGB::Red;
leds[34] = CRGB::Red;
// left brake light
leds[234] = CRGB::Red;
leds[235] = CRGB::Red;
leds[236] = CRGB::Red;
leds[237] = CRGB::Red;
leds[226] = CRGB::Red;
leds[221] = CRGB::Red;
leds[210] = CRGB::Red;
leds[211] = CRGB::Red;
leds[212] = CRGB::Red;
leds[213] = CRGB::Red;
leds[218] = CRGB::Red;
leds[229] = CRGB::Red;
FastLED.show();
delay(200);
leds[49] = CRGB::Red;
leds[50] = CRGB::Red;
leds[51] = CRGB::Red;
leds[52] = CRGB::Red;
leds[53] = CRGB::Red;
leds[46] = CRGB::Red;
leds[38] = CRGB::Red;
leds[30] = CRGB::Red;
leds[22] = CRGB::Red;
leds[14] = CRGB::Red;
leds[13] = CRGB::Red;
leds[12] = CRGB::Red;
leds[11] = CRGB::Red;
leds[10] = CRGB::Red;
leds[9] = CRGB::Red;
leds[17] = CRGB::Red;
leds[25] = CRGB::Red;
leds[33] = CRGB::Red;
leds[41] = CRGB::Red;
leds[54] = CRGB::Red;
// left brake light
leds[241] = CRGB::Red;
leds[242] = CRGB::Red;
leds[243] = CRGB::Red;
leds[244] = CRGB::Red;
leds[245] = CRGB::Red;
leds[246] = CRGB::Red;
leds[233] = CRGB::Red;
leds[230] = CRGB::Red;
leds[217] = CRGB::Red;
leds[214] = CRGB::Red;
leds[201] = CRGB::Red;
leds[202] = CRGB::Red;
leds[203] = CRGB::Red;
leds[204] = CRGB::Red;
leds[205] = CRGB::Red;
leds[206] = CRGB::Red;
leds[209] = CRGB::Red;
leds[222] = CRGB::Red;
leds[225] = CRGB::Red;
leds[238] = CRGB::Red;
FastLED.show();
delay(200);
leds[63] = CRGB::Red;
leds[62] = CRGB::Red;
leds[61] = CRGB::Red;
leds[60] = CRGB::Red;
leds[59] = CRGB::Red;
leds[58] = CRGB::Red;
leds[57] = CRGB::Red;
leds[56] = CRGB::Red;
leds[55] = CRGB::Red;
leds[47] = CRGB::Red;
leds[39] = CRGB::Red;
leds[31] = CRGB::Red;
leds[23] = CRGB::Red;
leds[15] = CRGB::Red;
leds[7] = CRGB::Red;
leds[6] = CRGB::Red;
leds[5] = CRGB::Red;
leds[4] = CRGB::Red;
leds[3] = CRGB::Red;
leds[2] = CRGB::Red;
leds[1] = CRGB::Red;
leds[8] = CRGB::Red;
leds[16] = CRGB::Red;
leds[24] = CRGB::Red;
leds[32] = CRGB::Red;
leds[40] = CRGB::Red;
leds[48] = CRGB::Red;
leds[0] = CRGB::Red;
// left brake light
leds[255] = CRGB::Red;
leds[254] = CRGB::Red;
leds[253] = CRGB::Red;
leds[252] = CRGB::Red;
leds[251] = CRGB::Red;
leds[250] = CRGB::Red;
leds[249] = CRGB::Red;
leds[248] = CRGB::Red;
leds[247] = CRGB::Red;
leds[232] = CRGB::Red;
leds[231] = CRGB::Red;
leds[216] = CRGB::Red;
leds[215] = CRGB::Red;
leds[200] = CRGB::Red;
leds[199] = CRGB::Red;
leds[198] = CRGB::Red;
leds[197] = CRGB::Red;
leds[196] = CRGB::Red;
leds[195] = CRGB::Red;
leds[194] = CRGB::Red;
leds[193] = CRGB::Red;
leds[192] = CRGB::Red;
leds[207] = CRGB::Red;
leds[208] = CRGB::Red;
leds[223] = CRGB::Red;
leds[224] = CRGB::Red;
leds[239] = CRGB::Red;
leds[240] = CRGB::Red;
FastLED.show();
delay(30);
oldButtonState3 == HIGH; // so this block can only run once
//(buttonState3 == LOW && oldButtonState3 == HIGH)
if(buttonState3 == LOW) {
// turn LED off:
FastLED.setBrightness(DIM);
// Set the first led back to black for 1 second
FastLED.show();
delay(30);
oldButtonState3 == LOW;
Okay I couldn't post the whole code because only 9k character limit so it is in two parts
It keeps running the loop when I have all the black coding at the front.
It works fine when the black coding is not there.
Please edit your posts and change them to use code tags for the code. It will then appear in a reasonable size box with a scroll bar. It will still need to be across two posts, but I'm sure we can soon show you how to shrink it down to a reasonable size, and help with your original question.
For example
// left brake light
becomes
// left brake light
for (int i = 234; i <= 229; i++) leds[i] = CRGB::Red;
Also do you rely need all those libraries? I can't see any of them being used apart from the Neopixel one.
The problem is all that superfluous verbiage makes it hard to see the actual code structure.
ho ly sh . . . .
those 64 lines can be reduced to
for (int z = 0; z < 64; z++;) {
leds[z] = CRGB::Red;
Same goes for all of those other monstrosities. No wonder your code is long.
And second that with 'wth is with all of those libraries', please explain your setup, what are all the things you are having the Arduino do.
I was trying to figure out how to group the LED's! Okay I will clean up the code and re-post!
Thanks for the help so far this is HUGE (pun intended haha)
#define DIM 10
#define ALL 0-255
// turn tail lights black quickly
leds[z] = CRGB::Black;
for (int b = 192; z < 256; z++;) {
leds[b] = CRGB::Black;
FastLED.show();
delay(200);
// Turn the center 4 led red for 1 second
//left brake light
FastLED.show();
delay(200);
// Turn the next ring led red for 1 second
// left brake light
FastLED.show();
delay(200);
// Turn the third ring led red for 1 second
// left brake light
FastLED.show();
delay(200);
// Turn the fourth ring red for 1 second
// left brake light
FastLED.show();
delay(30);
// turn both tail light dim red
leds[b] = CRGB::Red;
FastLED.show();
delay(30);
Better but still away to go.
When you have a load of LEDs that do not have consecutive numbers you use an other array as a list or look up table of these array numbers. So for example when you want to turn on the center four lights you first define the array that contains the numbers and then use the array contents as the LED array you want to change.
// outside of a function define:-
byte center4 = {36,35,28,27};
// then inside a function use
for (int b = 0; b<4; b++;) {
leds[center4[b]] = CRGB::RED;
That will help a lot the longer the list goes on.
Can you explain why you need both center4 and b? Seems like center4 should already call out those numbers?
Also what does b++ mean?
Read up and watch some videos about 'for loops'. You need to understand it. You also seem to be missing a few closing brackets }
The variable center4 is an array, in C you need to access each element one at a time by using a sutiable index given in the square braces.
If you just used b then you would turn on just LEDs 0 to 3. As center4 is an array then the first element of that array returns 36. So center4[0] returns 36, that is the number of LED you want to turn on. The variable b is called the loop index that goes from zero to less than four which is 3.
The operation ++ adds one to the variable it is placed next to. So b++ means what ever the value of b was, add one to it.
So here is a shorter version that works except:
The brake code is looping - I want button three to do the code once and stay bright until I release.
The blinkers are working good - EXCEPT I would like the non blinking light to stay at the 10 brightness (DIM)
#define DIM 10
// constant variables
// Set the right tail light to black for 1 second
for (int i = 0; i <= 63; i++)
// Set the left tail light to black for 1 second
for (int j = 192; j <= 255; j++)
leds[j] = CRGB::Red;
FastLED.show();
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState1 == HIGH) {
//LEFT TURN SIGNAL
leds[j] = CRGB::Black;
for (int a = 192; a <= 220; a++)
leds[a] = CRGB::Red;
FastLED.show();
delay(100);
leds[a] = CRGB::Black;
FastLED.show();
delay(30);
FastLED.show();
delay(100);
FastLED.show();
delay(30);
FastLED.show();
delay(100);
FastLED.show();
delay(30);
FastLED.show();
delay(100);
FastLED.show();
delay(30);
FastLED.show();
delay(100);
FastLED.show();
delay(30);
Second half of the code:
// RIGHT TURN SIGNAL
if (buttonState2 == HIGH) {
leds[i] = CRGB::Black;
FastLED.show();
delay(100);
FastLED.show();
delay(30);
FastLED.show();
delay(100);
FastLED.show();
delay(30);
FastLED.show();
delay(100);
FastLED.show();
delay(30);
FastLED.show();
delay(100);
FastLED.show();
delay(30);
FastLED.show();
delay(100);
FastLED.show();
delay(30);
Needed a third :(
//BRAKE LIGHT
if(buttonState3 == HIGH){
// Set the right tail light black
FastLED.show();
delay(200);
// left brake light
FastLED.show();
delay(200);
// left brake light
FastLED.show();
delay(200);
// left brake light
FastLED.show();
delay(200);
// left brake light
FastLED.show();
delay(30);
oldButtonState3 = HIGH; // so this block can only run once
// turn LED off:
delay(30);
This is heavy going.
The reply #15 was to show you how to light LEDs in a loop where the LED number do not follow each other but are in an arbitrary sequence. I gave you one short example. I expected you to apply that technique to all the rest of the turged code you had, so you did not need three posts to get your code over.
FastLED.show();
Can you double check your coding here - because it is not working.
byte center4 []= {36,35,28,27};
just forgot the []
which you should've picked up on if you read up on arrays once they were mentioned. Maybe you're unaware there's a reference section (https://www.arduino.cc/en/Reference/Array).
how do i declare b in the scope? I figured out the brackets but can't figure out how to declare b
int b
is declaring b. (https://www.arduino.cc/en/Reference/VariableDeclaration)
And this (https://www.arduino.cc/en/Reference/Scope), since you'll ask about it without trying to find it yourself.
Looks like you typed in the code wrong for that bit. It is delclaired inside the if statement and is in scope between the {. } of the if.
Figured it out - you had an extra ) and ; i think.
Here is my code thats around 22% memory and not 56+% memory like before.
So how do I get the brightness to stay dim on the non directional light and for the brake code to stop looping?
#define DIM 10
FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds,NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.show();
//LEFT TURN SIGNAL
for (int f = 192; f <= 255; f++)
leds[f] = CRGB::Black;
FastLED.show();
delay(30);
// FIRST ARROW RED
byte firstArrow20[] = {192,193,194,195,196,197,198,199,201,202,203,204,205,206,210,211,212,213,219,220};
for (int g = 0; g<20; g++) {
leds[firstArrow20[g]] = CRGB::Red;
FastLED.show();
delay (100);
// FIRST ARROW BLACK
leds[firstArrow20[g]] = CRGB::Black;
FastLED.show();
delay (30);
// SECOND ARROW RED
byte secondArrow8[] = {207,209,221,227,228,218,214,200};
for (int h = 0; h<8; h++) {
leds[secondArrow8[h]] = CRGB::Red;
FastLED.show();
delay (100);
// SECOND ARROW BLACK
leds[secondArrow8[h]] = CRGB::Black;
FastLED.show();
delay (30);
// THIRD ARROW RED
byte thirdArrow8[] = {208,222,226,236,235,229,217,215};
for (int k = 0; k<8; k++) {
leds[thirdArrow8[k]] = CRGB::Red;
FastLED.show();
delay (100);
// THIRD ARROW BLACK
leds[thirdArrow8[k]] = CRGB::Black;
FastLED.show();
delay (30);
// FOURTH ARROW RED
byte fourthArrow8[] = {223,225,237,243,244,234,230,216};
for (int l = 0; l<8; l++) {
leds[fourthArrow8[l]] = CRGB::Red;
FastLED.show();
delay (100);
// FOURTH ARROW BLACK
leds[fourthArrow8[l]] = CRGB::Black;
FastLED.show();
delay (30);
// FIFTH ARROW RED
byte fifthArrow8[] = {224,238,242,252,251,245,233,231};
for (int m = 0; m<8; m++) {
leds[fifthArrow8[m]] = CRGB::Red;
FastLED.show();
delay (100);
// FIFTH ARROW BLACK
leds[fifthArrow8[m]] = CRGB::Black;
FastLED.show();
delay (30);
FastLED.show();
delay(30);
// SIXTH ARROW RED
byte sixthArrow20[] = {56,57,58,59,60,61,62,63,49,50,51,52,53,54,42,43,44,45,35,36};
for (int n = 0; n<20; n++) {
leds[sixthArrow20[n]] = CRGB::Red;
FastLED.show();
delay (100);
// SIXTH ARROW BLACK
leds[sixthArrow20[n]] = CRGB::Black;
FastLED.show();
delay (30);
// SEVENTH ARROW RED
byte seventhArrow8[] = {48,55,46,41,37,34,28,27};
for (int o = 0; o<8; o++) {
leds[seventhArrow8[o]] = CRGB::Red;
FastLED.show();
delay (100);
// SEVENTH ARROW BLACK
leds[seventhArrow8[o]] = CRGB::Black;
FastLED.show();
delay (30);
// EIGTH ARROW RED
byte eigthArrow8[] = {47,40,33,38,26,29,19,20};
for (int p = 0; p<8; p++) {
leds[eigthArrow8[p]] = CRGB::Red;
FastLED.show();
delay (100);
// EIGHT ARROW BLACK
leds[eigthArrow8[p]] = CRGB::Black;
FastLED.show();
delay (30);
// NINTH ARROW RED
byte ninthArrow8[] = {39,32,25,30,21,18,12,11};
for (int q = 0; q<8; q++) {
leds[ninthArrow8[q]] = CRGB::Red;
FastLED.show();
delay (100);
// NINTH ARROW BLACK
leds[ninthArrow8[q]] = CRGB::Black;
FastLED.show();
delay (30);
// TENTH ARROW RED
byte tenthArrow8[] = {31,24,22,17,13,10,4,3};
for (int r = 0; r<8; r++) {
leds[tenthArrow8[r]] = CRGB::Red;
FastLED.show();
delay (100);
// TENTH ARROW BLACK
leds[tenthArrow8[r]] = CRGB::Black;
FastLED.show();
delay (30);
//BRAKE LIGHT
FastLED.show();
delay(200);
//CENTER 4
byte center4[] = {36,35,28,27,227,228,219,220};
for (int b = 0; b<8; b++) {
leds[center4[b]] = CRGB::Red;
FastLED.show();
delay(200);
// FIRST RING
byte firstRing12[] = {42,43,44,45,37,29,21,20,19,18,26,34,234,235,236,237,226,221,210,211,212,213,218,229};
for (int c = 0; c<24; c++) {
leds[firstRing12[c]] = CRGB::Red;
FastLED.show();
delay(200);
// SECOND RING
byte secondRing20[] = {49,50,51,52,53,46,38,30,22,14,13,12,11,10,9,17,25,33,41,54,241,242,243,244,245,246,233,230,217,214,201,202,203,204,205,206,209,222,225,238};
for (int d = 0; d<40; d++) {
leds[secondRing20[d]] = CRGB::Red;
}FastLED.show();
delay (200);
// THIRD RING
byte thirdRing28[] = {63,62,61,60,59,58,57,56,55,47,39,31,23,15,7,6,5,4,3,2,1,0,8,16,24,32,40,48,255,254,253,252,251,250,249,248,247,232,231,216,
215,200,199,198,197,196,195,194,193,192,207,208,223,224,239,240};
for (int e = 0; e<56; e++) {
leds[thirdRing28[e]] = CRGB::Red;
FastLED.show();
delay (200);
// turn LED off:
Black is 0,0,0. You'll have to write crgb to whatever you think works for 'dim'. E.g. 80,0,0 for dim red.
Is that to make the brake light stop looping? Because I am not calling black for the left and right non blinker sections.
Do i need to use a latch function?
What latch function?
If you want the LEDs to stop on for the whole time a button is pressed just hold your code in a while loop.
while(digitalRead(pin) == pressed) { } // where the variable pressed is the logic level you get when the button is held down.
