Arduino Forum
Using Arduino => LEDs and Multiplexing => Topic started by: kaitoukid93 on Aug 04, 2017, 03:15 pm
Title: LED indicator for data pin
Post by: kaitoukid93 on Aug 04, 2017, 03:15 pm
hello, Im controlling ws2812b using an arduino nano(ambilight), and the data sent out by D3
I just want to make a normal led (like TX and RX led) to show me that the D3 is working
can someone help me?
thanks
Title: Re: LED indicator for data pin
Post by: larryd on Aug 04, 2017, 03:57 pm
This should help:
//Demonstrates how to control one pixel
#include <Adafruit_NeoPixel.h>
#define PIN        3
#define PixelCount 1
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PixelCount, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.setPixelColor(0, 0);
  strip.show(); // Initialize all pixels to 'off'
} //END of   s e t u p ( )
  //turn on one neo pixel
  strip.setPixelColor(0, strip.Color(255, 0, 0));     //Red
  //strip.setPixelColor(0,strip.Color(0, 255, 0));      //Green
  //strip.setPixelColor(0,strip.Color(0, 0, 255));      //Blue
  //strip.setPixelColor(0,strip.Color(255, 255, 255));  //White
  strip.show();
  strip.setPixelColor(0, strip.Color(0, 0, 0));         //Turn off pixel
  strip.show();
} // END of      l o o p ( )
Post by: kaitoukid93 on Aug 04, 2017, 09:28 pm
thanks. but my purpose was to use only the D3 to control the led strip ambbilight and by the way light up the indicator
Post by: larryd on Aug 04, 2017, 09:46 pm
You are going to have to explain things better.
Give us a link to your hardware.
Show us a good schematic of your circuit.
Show us a good image of your wiring.
Post by: kaitoukid93 on Aug 04, 2017, 11:17 pm
I said, it's like the Tx Rx led, blinking means Tx or Rx is working
so I want to make a similar one but with the D3 pin
(http://2.pik.vn/2017cc74f38b-f696-47ed-a2b2-983b3e9074c7.jpg)
Post by: Wawa on Aug 04, 2017, 11:20 pm
Use pin 13.
That will flash the onboard LED.
Leo..
Post by: larryd on Aug 04, 2017, 11:32 pm
Add a LED and a series 470Ω  resistor on pin 3  then connect to GND/+5V similar to D1 or D2 in the attached image.
(https://i.imgur.com/HCRzgrC_d.jpg?maxwidth=640&shape=thumb&fidelity=high)
Post by: Grumpy_Mike on Aug 05, 2017, 06:09 am
In that circuit connect a 470R resistor to the free end of the LED and then the other end of the resistor to ground.
It will flash when ever you call the show method.
Post by: kaitoukid93 on Aug 05, 2017, 07:25 am
thanks all of you
thankssssss
