Arduino Forum
Products => Arduino Due => Topic started by: redflood on Aug 25, 2017, 07:51 am
Title: Disable all external Interrupt except UART AND USART interrupts
Post by: redflood on Aug 25, 2017, 07:51 am
Dear everyone,
I have two problems as below:
How can I disable all external interrupts except UART AND USART interrupts when using Arduino Due?
And how can I reset an IO to initial state (Not Input and Output mode)?
Please help me to solve that problems, thank you!
Title: Re: Disable all external Interrupt except UART AND USART interrupts
Post by: ard_newbie on Aug 25, 2017, 08:33 am
You are supposed to know what your code is doing, i.e. what interrupts have been enabled in which peripheral.
E.g. for UART:
You have somewhere :
UART->UART_IER = ......;
NVIC_EnableIRQ(UART_IRQn);
Conversely, if you have enabled somewhere an interrupt for TC0 and you don't need it anymore, you can write this:
NVIC_ClearPendingIRQ (TC0_IRQn);
NVIC_Disable IRQ(TC0_IRQn);
However, Systick or Hardfault interrupts will still fire.
If you have an external interrupt with an attachinterrupt() somewhere, you can disable it with a detachinterrupt().
I guess you could even use a noInterrupts(); to stop peripheral interrupts and write e.g.:
NVIC_EnableIRQ(UART_IRQn);  and NVIC_EnableIRQ(USART0_IRQn); to select interrupts from UART and USART0.
For PIO, they are in Input state enable by default.
Post by: redflood on Aug 25, 2017, 08:51 am
Hi ard_newbie,
Thank for your reply,
Firstly, I configured an external interrupt on a Pin for capturing a pulse (almost 0.01-1Mhz), and also configure a USART2 to communicate with another board.
Everything is fine (communication and capturing pulse) if the input pulse at low frequency (0.01-0.1 Mhz), but when the pulse at high frequency (0.1-1Mhz) then I can not communicate with other board.
If I don't configure to capture the pulse, the communication is fine also (even though the input pulse at high frequency). Then I am doubting about I did not detach interrupt pin in a right way.
I only used detachInterrupt(pin) but it does not solve my problem, then I also try to set the pin for capturing pulse to output mode, however no luck!.
detachInterrupt(pin);
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
After reading your reply,
I tried
noInterrupts();
NVIC_EnableIRQ(USART2_IRQn);
Serial2.println(bf0);
interrupts();
Can you give me a suggestion to solve this problem
Post by: ard_newbie on Aug 25, 2017, 09:53 am
Although you didn't post all your code, at 1 MHz, you fire your attached interrupt every 1 us. Meanwhile, a Serial.println can take about 1 ms.
You should use a Timer Capture instead and avoid Serial printing at every pulse edge.  Buffer your results and at the end of your experiment, print only what is necessary.
