Arduino Forum
Using Arduino => Networking, Protocols, and Devices => Topic started by: srandrup on Jan 31, 2011, 10:22 am
Title: POSTrequest instance won't process request when pin is HIGH
Post by: srandrup on Jan 31, 2011, 10:22 am
I have tried to make a sketch that posts a request to a REST-service every time a button is pushed and every time it's released.
I'm a using a Black Widow-board with wifi.
Sadly it doesn't work as i excpected. When i push the button (and hold it) the POSTrequest.submit() is called, but the createBody() function is not called by the POSTrequest instance. So nothing happens. But when i release the button, a new POSTrequest.submit() is called and now the createBody() function is called and the POSTrequest is executed. Sometimes a button-push and -release results in a single http post and sometimes it results in two posts..?
It seems that the POSTrequest instance won't process a request as long as the button is pressed...?
Can someone explain this behavior?
#include <WiServer.h>
#define WIRELESS_MODE_INFRA   1
#define WIRELESS_MODE_ADHOC   2
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,1,2};   // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1};   // router or gateway IP address
//unsigned char local_ip[] = {192,168,100,2};   // IP address of WiShield
//unsigned char gateway_ip[] = {192,168,100,1};   // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0};   // subnet mask for the local network
const prog_char ssid[] PROGMEM = {"XXXX"};      // max 32 bytes
unsigned char security_type = 3;   // 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"XXXX"};   // max 64 characters
prog_uchar wep_keys[] PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d,   // Key 0
              0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,   // Key 1
              0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,   // Key 2
              0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00   // Key 3
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
void printData(char* data, int len)
      Serial.println("printData");
  while (len-- > 0) {
    Serial.print(*(data++));
int pin2State = LOW;         // variable for reading the pushbutton status
const int pin2 = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
char deviceId[] = "1";
char hostName[] = "sensor.zonosoft.com";
//char hostName[]  = "192.168.1.104";
char url[]  = "/SensorService.svc/SaveMeasurement";
uint8 ip[] = {195,128,175,40};
//uint8 ip[] = {192,168,1,104};
POSTrequest sendInfo(ip, 80, hostName, url, createBody);
String _dataToSend;
    Serial.println("Setup...");
     WiServer.init(NULL);
     WiServer.enableVerboseMode(true);
//     sendInfo.setReturnFunc(printData);
     pinMode(ledPin, OUTPUT);
     pinMode(pin2, INPUT);
     Serial.println("Setup finished");
void createBody()
   Serial.println("createBody");
  Serial.println(_dataToSend);
  WiServer.print(_dataToSend);
    int newPin2State = digitalRead(pin2);
    if (pin2State != newPin2State)
        Serial.println("pin2 changed");
        _dataToSend = "{\"Mt\":\"";
        _dataToSend += + deviceId;
        _dataToSend += ";2"; //pin2
        if (newPin2State == HIGH)
          _dataToSend += ";1";
          _dataToSend += ";0";
        _dataToSend += "\"}";
        sendInfo.submit();
        Serial.println("After submit");
        digitalWrite(ledPin, pin2State);
    WiServer.server_task();
    delay(10);
      pin2State = newPin2State;
      Serial.println("After WiServer.server_task()");
Title: Re: POSTrequest instance won't process request when pin is HIGH
Post by: PaulS on Jan 31, 2011, 12:21 pm
pin2State should ALWAYS be set to newPin2State.
Post by: srandrup on Jan 31, 2011, 12:51 pm
Hi Paul
should be equal to:
Post by: PaulS on Jan 31, 2011, 01:58 pm
should be equal to:
The second snippet should replace the first snippet. They are not equal, though.
