Arduino Forum
Using Arduino => Audio => Topic started by: Stian on Feb 03, 2011, 01:15 am
Title: Im having trouble communicating to a PGA2310 chip
Post by: Stian on Feb 03, 2011, 01:15 am
Hi all!
Im working on a volume controller, based on Texas Instrument`s PGA2310 Digital volume-controller chip, but im having some trouble making it work at all.
Here is how my code looks:
#include "SPI.h"
const int PGA_CS_PIN = 48;
const int PGA_SCLK_PIN = 52;
const int PGA_SDI_PIN = 51;
int timedelay = 100;
int volumeLevel = 55;
pinMode(PGA_CS_PIN,OUTPUT);
pinMode(PGA_SCLK_PIN,OUTPUT);
pinMode(PGA_SDI_PIN,OUTPUT);
digitalWrite(PGA_CS_PIN,HIGH);
digitalWrite(PGA_SCLK_PIN,HIGH);
digitalWrite(PGA_SDI_PIN,HIGH);
void PGA_set_volume(byte value)
 byte shifted_val = (value << 1);
digitalWrite(PGA_CS_PIN, LOW); // assert CS
SPI_write(shifted_val); // right value (0..255)
digitalWrite(PGA_CS_PIN, HIGH); // deassert CS
Serial.print(shifted_val);
static inline void SPI_write(byte out_spi_byte)
byte i;
// loop thru each of the 8-bits in the byte
 for (i=0; i < 8; i++) {
// strobe clock
digitalWrite(PGA_SCLK_PIN, LOW);
// send the bit (we look at the high order bit and 'print' that to the remtoe device)
if (0x80 & out_spi_byte) // MSB is set
digitalWrite(PGA_SDI_PIN, HIGH);
digitalWrite(PGA_SDI_PIN, LOW);
// unstrobe the clock
digitalWrite(PGA_SCLK_PIN, HIGH);
out_spi_byte <<= 1; // left-shift the byte by 1 bit
// Reset the volumeLevel if it goes over 128. I think it can actually go to 255.
//if (volumeLevel > 254) {
//volumeLevel = 1;
// Set the volume
PGA_set_volume(volumeLevel);
delay(timedelay);
volumeLevel = volumeLevel + 1;
And using the serial communication too see what the arduino says to the chip, this is what comes:
 "$&(*,.02468:<>@BDFHJLNPRTVXZ\^`bdfhjlnprtvxz|~???????
I have no idea why this happens, Ive just started with arduino so im basically an extremely newbie... :o
Some of this code comes from what linux-works once posted, basically its the only thing i can find, except linux-works PGA23XX library witch i dont now how works.
Can some one help sort this out?
Thanks,
Stian
Title: Re: Im having trouble communicating to a PGA2310 chip
Post by: Stian on Feb 03, 2011, 02:45 am
Maybe this post belongs under "Programming Questions", could a moderator move it for me if so?
Post by: Stian on Feb 03, 2011, 02:26 pm
Found a new code for it: http://code.google.com/p/dccn-lab/source/browse/trunk/audiovolume/Arduino/pga2311_volume_control/pga2311_volume_control.pde?r=59 (http://code.google.com/p/dccn-lab/source/browse/trunk/audiovolume/Arduino/pga2311_volume_control/pga2311_volume_control.pde?r=59)
This one seems to be working good.
I also breadboarded the project a little more professional, should SDI, CLK, CS, ZCEN, MUTE have pulldown and pullup resistors?
Atleast, now i am using:
SDI: 100k pulldown
CLK: 100k pullup
CS: 100k pulldown
ZCEN: 47k pulldown
MUTE: 47k pulldown
Post by: Grumpy_Mike on Feb 03, 2011, 09:59 pm
Simply no.
You only need pull up resistors on open collector inputs, and pull down when you don't want pins to float during initialisation.
Post by: Stian on Feb 04, 2011, 08:46 am
Okey then.
Post by: opet on Mar 20, 2011, 02:06 pm
I'm currently trying to do the same thing, replacing a normal volume pot with a digital arduino based solution. I haven't seen any schematics of how anyone have connected the actual amp to the PGA2310 and I was wondering if it requires any additional hardware. Or do I just connect the lines and that's it?
Thanks in advance!
√ėyvind
