Arduino Forum
Development => Other Software Development => Topic started by: rtek1000 on Nov 06, 2017, 05:42 am
Title: UTFT_DDIG: display seven-segment numbers (faster than using character font)
Post by: rtek1000 on Nov 06, 2017, 05:42 am
This library (UTFT_DDIG) extends the UTFT_DLB library, which in turn extends the UTFT library.
So both libraries are needed.
UTFT DDIG was made to improve the display response time of seven-segment numbers, the accepted value is between 0-9 and 10-15 (A-F)
You can control:
- Position,
- Width,
- Height,
- Thickness (Minimum segment thickness: 2 px)
- Color
Test: https://youtu.be/amKvzLVV9GM
(The red number originates in the font made for the UTFT library, the green color numbers are generated in the library code UTFT_DDIG)
[Please ask for help only via forum, maybe I can not answer]
The UTFT_DLB library enables the use of ttf font previously converted by the ttf2c_vc2003.exe tool
(Usage: ttf2c_vc2003.exe size font.ttf font.c)
[size is a number, I tryed 12, 50 and 150 all works fine]
{you need add "const" declaration on file font.c}
uint8_t fontNameSize[] PROGMEM =
const uint8_t fontNameSize[] PROGMEM =
UTFT:
http://www.rinkydinkelectronics.com/library.php?id=51
UTFT_DLB:
https://sites.google.com/site/dlbarduino/downloads
