Arduino Forum
Using Arduino => Project Guidance => Topic started by: devasri on Nov 10, 2017, 06:26 pm
Title: Im at a dead end...
Post by: devasri on Nov 10, 2017, 06:26 pm
We want the duty cycle of the pwm out to be proportional to the delay in timing of both square signals, if its leading it will output on one ocr pin if it is lagging, it goes to the other, based on which value comes first. Also we have to wait for the program to change both values of the signals, PORTA and PORTB, to compare the delay, which i think its not doing correctly. for testing purposes we're inputting 1 hz square waves so we can see the output, but for the real deal it should be 40khz square waves, but its not working, and I am also not great with arduino (my first time) I am not sure why our code isn't working properly. Is there another way to do this or what should we try and change? Thanks!
#include <avr/io.h>
#include <avr/interrupt.h>
#define CLK 16000000UL
bool t1_changed = false;
bool t2_changed = false;
 // Serial.begin(115200);
  noInterrupts();
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM20);
  TCCR2B = _BV(CS22);
  OCR2A = 0;
  OCR2B = 0;
  TCNT2 = 0;
  //TIMSK2 |= (1 << TOIE2);
  interrupts();
  attachInterrupt(0, t1_ISR, RISING);     //enable interrupt service routines on pins 2 and 3
  attachInterrupt(1, t2_ISR, RISING);
volatile unsigned int t1;
volatile unsigned int t2;
//volatile unsigned int oldt1, oldt2;
 // noInterrupts();
  //noInterrupts();
  //t1_changed = false;
  //t2_changed = false;
 PORTC=PORTB-PORTA;
    if(SREG & 4)
      OCR2A = (PORTB ^ PORTA);   //duty cycle   50%
      OCR2B = 0;
    else if(PORTA == PORTB)
      OCR2A = 0;
      OCR2B = 0;
      OCR2A = 0;
      OCR2B = (PORTA ^ PORTB);
      //OCR2A = 0;
    cli();
 // t1_changed=true;
  //t2_changed=true;
  //interrupts();
void t1_ISR()
  //Serial.println("ISR");
  PORTA = TCNT2;
  //t1_changed = true;
   Serial.println("PORTA is:");
   Serial.println(PORTA);
  //oldt1=t1;
void t2_ISR()
  //Serial.println("ISR2");
  PORTB = TCNT2;
 // t2_changed = true;
    Serial.println("PORTB is:");
    Serial.println(PORTB);
 // oldt2=t2;
Title: Re: Im at a dead end...
Post by: Delta_G on Nov 10, 2017, 06:28 pm
That's an awful lot of bare-metal code for a first timer.  Nothing like jumping straight into the deep end and relying on the lifeguards to save you.
Don't do serial stuff inside your ISR.  Serial relies on interrupts that are turned off during your ISR.
Post by: Delta_G on Nov 10, 2017, 06:30 pm
PORTC=PORTB-PORTA;
What are you thinking this line will do?  I doubt it does what you think. But it's hard to tell what you expected.
Similarly with this one, what do you expect to have happen with this?
PORTA = TCNT2;
Post by: Robin2 on Nov 10, 2017, 07:27 pm
You should be aware that not all the pins on a Port are available to you. Some of the pins have special functions and you should take care not to change them.
If you use the digitalWriteFast library it is almost as fast as port manipulation and it makes code a lot easier to understand.
...R
Post by: wvmarle on Nov 11, 2017, 01:43 pm
PORTA and PORTB are complete 8-bit registers, handling multiple ports.
I suppose you are interested in reading only two specific pins, so you have to look into reading those specific bits.
Post by: devasri on Nov 11, 2017, 08:12 pm
I changed those to regular variables as well, but the timers still don't sync, so the comparison is always off for the time delay we need as the pwm duty cycle
#include <avr/io.h>
  noInterrupts();
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(9, OUTPUT);
  TCCR2A = _BV(COM2A0) | _BV(COM2B1) | _BV(WGM20);
  TCCR2B = _BV(CS22);
  OCR2A = 0;
  OCR2B = 0;
  TCNT2 = 0;
  interrupts();
  while(!(t1_changed && t2_changed))
  Serial.println(t2 ^ t1);
  noInterrupts();
  t1_changed = false; t2_changed = false;
    if(t1 < t2)
      OCR2A = t2 ^ t1;   //duty cycle   50%
      OCR2B = 0;
    else if(t2 < t1)
      OCR2B = t1 ^ t2;
      OCR2A = 0;
 // t1_changed=true;
  //t2_changed=true;
  interrupts();
void t1_ISR()
  t1 = TCNT2;
  t1_changed = true;
   // Serial.println(t1);
  //oldt1=t1;
void t2_ISR()
  t2 = TCNT2;
  t2_changed = true;
   // Serial.println(t2);
 // oldt2=t2;
Post by: Robin2 on Nov 11, 2017, 08:28 pm
You can't do this
because both variables occupy two bytes and part of the value could be changed by the ISR while you are reading the values
Do it like this
if (t1_changed == true) {
  noInterrupts();
   t1Copy = t1;
   newT1Copy = true; // not sure if this is needed
   t1_changed =  false;
  interrupts();
if (t2_changed == true) {
  noInterrupts();
   t2Copy = t2;
   newT2Copy = true;
   t2_changed =  false;
  interrupts();
and then in the rest of your code use t1Copy and t2Copy
...R
Post by: devasri on Nov 11, 2017, 09:15 pm
thanks!
