Arduino Forum
Using Arduino => Microcontrollers => Topic started by: olivier_arduino on Dec 10, 2017, 03:19 pm
Title: need help porting TMRh20's RF24 library to ESP32
Post by: olivier_arduino on Dec 10, 2017, 03:19 pm
I am trying to drive a nrf24l01+ with a ESP32 so that I can connect a bunch of coin cell nrf24 nodes to the web.
I have done some research but I have found very few things about using the nrf24 with the ESP32.
To have tmrh20's RF24 library compile, I made to following change to the library:
in nRFL01.h in commented out this line:
//#define NOP           0xFF
in RF24.cpp I replaced
*buf++ = _SPI.transfer(NOP);
by
*buf++ = _SPI.transfer(0xff);
in RF24_config.h
I added
    #elif defined (ESP_H)
    #include <pgmspace.h>
    #define PRIPSTR "%s"
just after line 135
Those changes allow the library to compile with no warnings.
I used the lastest ESP32 arduino core downloaded from the github repo as well as the latest version of the RF24 library from github.
I am trying to run the getting started sketch from the library with a few modif:
* Getting Started example sketch for nRF24L01+ radios
* This is a very basic example of how to send data from one node to another
* Updated: Dec 2014 by TMRh20
#include <SPI.h>
#include "RF24.h"
/****************** User Config ***************************/
/***      Set this radio as radio number 0 or 1         ***/
bool radioNumber = 0;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(5,18); //CE, CSN
byte addresses[][6] = {"1Node","2Node"};
// Used to control whether this node is sending or receiving
bool role = 0;
  Serial.println(F("RF24/examples/GettingStarted"));
  Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
  SPI.begin();
  SPI.setFrequency(2000000);
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(0);
  if (radio.begin()) { Serial.println("OK!"); }
  else{ Serial.println("too bad!"); }
  delay(5000);
  // Set the PA Level low to prevent power supply related issues since this is a
// getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
  radio.setPALevel(RF24_PA_LOW);
  // Open a writing and reading pipe on each radio, with opposite addresses
  if(radioNumber){
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1,addresses[0]);
  }else{
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1,addresses[1]);
  // Start the radio listening for data
  radio.startListening();
                void loop(){}
I have tried playing with different SPI parameters with no success. I lowered the frequency to 2Mbs and try to set the SPI in mode 0, MSBFIRST with no success.
On the hardware side I use:
- DOIT ESP32 DEVKIT v1
- a nrf24 adapter (the one with the power regulator and cap)
- a basic module
I tried swapping the cable, module, adapter with no success.
I power the dev board through USB and with an external beefy regulated power supply. I have a large cap (470uF) between (GND and 3.3V).
The connection are as follow:
 CE->GPIO18
CSN -> GPIO05
MISO -> GPIO12
MOSI -> GPIO13
CLK-> GPIO14
IRQ-> unconnected
My guess is there is a problem with the SPI communication protocol. The radio.begin() always fails....
 I am running out of idea and I am fairly new with ESP32 (although I have some experience using nRF24 with atmega), Any help would be greatly appreciated!
Title: Re: need help porting TMRh20's RF24 library to ESP32
Post by: pert on Dec 10, 2017, 03:38 pm
I'm sure that works but I think the intent of the code would be more obvious and maybe less fragile if you used the ESP32 macro instead of the include guard macro. I would consider the former to be more of a public API and the latter to not be guaranteed stable.
Post by: olivier_arduino on Dec 10, 2017, 09:15 pm
Yes indeed, I was not sure what to use. I ll try with ESP32 instead of ESP_h.
Post by: olivier_arduino on Dec 11, 2017, 02:41 pm
ok, I just did not wire the SPI properly, how embarrassing...
Please have a look at the issue thread here if you are trying to work with nrf24l01 and ESP32 with arduino core: https://github.com/nRF24/RF24/issues/393
