Arduino Forum
Development => Other Software Development => Topic started by: BenoitB on Jan 19, 2018, 04:06 pm
Title: ArduinoJson 5.13.0 is out!
Post by: BenoitB on Jan 19, 2018, 04:06 pm
I just released a new version of ArduinoJson (https://arduinojson.org/?utm_source=arduino&utm_medium=forum), a library to serialize and deserialize JSON documents.
This new version brings a few improvements concerning the duplication of strings.
New rules for string duplications
When a program adds a string, ArduinoJson stores it differently depending on the type of the string.
In previous versions, ArduinoJson stored a pointer when the string was a plain old C string (char*, const char*, char[]), but stored a copy when the string had any other type (String, Flash strings...).
ArduinoJson 5.13 changes the rules: now, only const char* are stored with a pointer, all other string types are duplicated, which greatly simplifies our programs.
Example
Since older versions stored char[] strings with a pointer, we used to see curious behavior when adding strings in a loop. To prevent ArduinoJson for storing the same pointer (an thus the same string) several times, we had to call JsonBuffer::strdup() (https://arduinojson.org/api/jsonbuffer/strdup/?utm_source=arduino&utm_medium=forum):
JsonArray& array = jsonBuffer.createArray();
for (int i=0; i<3; i++) {
    char buffer[16];
    sprintf(buffer, "iteration %d", 0);
    array.add(jsonBuffer.strdup(buffer)); // <- need to duplicate :-(
array.printTo(Serial);
Thanks to the implicit duplication of char*, we can simplify this program to:
    char buffer[16];
    array.add(buffer); // <- implicit duplication :-)
Improvement to RawJson()
RawJson() is a special function to insert raw JSON fragments in a JsonArray (https://arduinojson.org/api/jsonarray/?utm_source=arduino&utm_medium=forum) or a JsonObject (https://arduinojson.org/api/jsonobject/?utm_source=arduino&utm_medium=forum).
In previous versions, RawJson() only accepted const char* as an argument; now, in ArduinoJson 5.13, it also accepts String objects and Flash strings too.
But there is more: strings marked with RawJson() obey to the same duplication rules as other strings.
Here is an example:
JsonObject& root = jsonBuffer.createObject();
root["coord"] = RawJson(F("{\"lat\":48.74801,\"lon\":2.293491}"));
Bye bye strdup()
The new rules for string duplication make JsonBuffer::strdup() (https://arduinojson.org/api/jsonbuffer/strdup/?utm_source=arduino&utm_medium=forum) useless.
In ArduinoJson 5.13, JsonBuffer::strdup() (https://arduinojson.org/api/jsonbuffer/strdup/?utm_source=arduino&utm_medium=forum) is flagged as deprecated, so you'll have a compilation warning if your program uses it.
I'll probably remove the function in a future release, so I encourage you to update your programs.
How to get ArduinoJson 5.13.0?
You can download this new version from the Arduino Library Manager (https://www.arduino.cc/en/Guide/Libraries).
If you don't use the Arduino IDE, you can download the single header version (https://github.com/bblanchon/ArduinoJson/releases/download/v5.13.0/ArduinoJson-v5.13.0.h).
As usual, you can try the library on wandbox.org:
* JsonParserExample (https://wandbox.org/permlink/ueuDi8j1bED2bXxC)
* JsonGeneratorExample (https://wandbox.org/permlink/PfOxXA3X99CDTsmG)
Title: Re: ArduinoJson 5.13.0 is live!
Post by: robtillaart on Jan 19, 2018, 06:51 pm
Thanks for sharing!
