Hi Guys.
I am working on a project for stepper motor control in two mode: 1. Locally by pressing buttons, 2. through serial.
What I want:
1. Local control - a button to enable local control, forward and backward movements by press & hold their respective buttons. A fourth button I added for resetting.
2. Serial Control: Various different movements by sending keys.
For local control, I already have a working code (greatly based on Example 5 (http://www.schmalzhaus.com/EasyDriver/Examples/EasyDriverExamples.html)):
For serial control, I tested a working code posted in here (https://learn.sparkfun.com/tutorials/easy-driver-hook-up-guide?_ga=2.5974067.106990392.1515514487-1212774323.1509654567).).
Now I am trying to combine these both codes. Result is:
#include <AccelStepper.h>
int Stepping = false;
// Define the stepper and the pins it will use
AccelStepper stepper1(AccelStepper::DRIVER, 2, 3);
const int buttonPin = 11;
const int ledPin = 12;
const int restPin = 13;
//Variables
int buttonState = 0;
int flag=0;
#define stp 2
#define dir 3
#define MS1 4
#define MS2 5
// Define our three input button pins
#define LEFT_PIN 9
#define STOP_PIN 11
#define RIGHT_PIN 10
#define EN 6
// Define our analog pot input pin
#define SPEED_PIN 0
// Define our maximum and minimum speed in steps per second (scale pot to these)
#define MAX_SPEED 5000
#define MIN_SPEED 0.1
char user_input;
int x;
int y;
int state;
// The only AccelStepper value we have to set here is the max speeed, which is higher than we'll ever go
stepper1.setMaxSpeed(10000.0);
// Set up the three button inputs, with pullups
pinMode(LEFT_PIN, INPUT_PULLUP);
pinMode(STOP_PIN, INPUT_PULLUP);
pinMode(RIGHT_PIN, INPUT_PULLUP);
digitalWrite(LEFT_PIN, HIGH);
digitalWrite(STOP_PIN, HIGH);
digitalWrite(RIGHT_PIN, HIGH);
digitalWrite(restPin, HIGH);
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(EN, OUTPUT);
pinMode(stp, OUTPUT);
pinMode(dir, OUTPUT);
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
resetEDPins(); //Set step, direction, microstep and enable pins to default states
Serial.begin(9600); //Open Serial connection for debugging
Serial.println("Begin motor control");
Serial.println();
//Print function list for user selection
Serial.println("Enter number for control option:");
Serial.println("1. Turn at default microstep mode.");
Serial.println("2. Reverse direction at default microstep mode.");
Serial.println("3. Turn at 1/8th microstep mode.");
Serial.println("4. Step forward and reverse directions.");
Serial.println();
void(*resetFunc) (void) = 0;
static float current_speed = 0.0; // Holds current motor speed in steps/second
static int analog_read_counter = 1000; // Counts down to 0 to fire analog read
static char sign = 0; // Holds -1, 1 or 0 to turn the motor on/off and control direction
static int analog_value = 0; // Holds raw analog value.
//If button pressed...
if (buttonState == LOW) {
if ( flag == 0){
digitalWrite(ledPin, HIGH);
digitalWrite(EN, LOW);
flag=1; //change flag variable
//...twice, turn led off!
else if ( flag == 1){
digitalWrite(ledPin, LOW);
digitalWrite(EN, HIGH);
flag=0; //change flag variable again
delay(200);
// If a switch is pushed down (low), set the sign value appropriately
if (digitalRead(LEFT_PIN) == 0) {
sign = 1;
else if (digitalRead(RIGHT_PIN) == 0) {
sign = -1;
if ((digitalRead(LEFT_PIN) == 1) && digitalRead(RIGHT_PIN) == 1)
sign = 0;
// We only want to read the pot every so often (because it takes a long time we don't
// want to do it every time through the main loop).
if (analog_read_counter > 0) {
analog_read_counter--;
else {
analog_read_counter = 3000;
// Now read the pot (from 0 to 1023)
analog_value = analogRead(SPEED_PIN);
// Give the stepper a chance to step if it needs to
stepper1.runSpeed();
// And scale the pot's value from min to max speeds
current_speed = sign * (((analog_value/1023.0) * (MAX_SPEED - MIN_SPEED)) + MIN_SPEED);
// Update the stepper to run at this new speed
stepper1.setSpeed(current_speed);
// This will run the stepper at a constant speed
int RESET = digitalRead(restPin);
if (RESET == LOW)
resetFunc();
while(Serial.available()){
user_input = Serial.read(); //Read user input and trigger appropriate function
digitalWrite(EN, LOW); //Pull enable pin low to allow motor control
if (user_input =='1')
StepForwardDefault();
else if(user_input =='2')
ReverseStepDefault();
else if(user_input =='3')
SmallStepMode();
else if(user_input =='4')
ForwardBackwardStep();
Serial.println("Invalid option entered.");
resetEDPins();
//Reset Easy Driver pins to default states
void resetEDPins()
digitalWrite(stp, LOW);
digitalWrite(dir, LOW);
digitalWrite(MS1, LOW);
digitalWrite(MS2, LOW);
//Default microstep mode function
void StepForwardDefault()
Serial.println("Moving forward at default step mode.");
digitalWrite(dir, LOW); //Pull direction pin low to move "forward"
for(x= 1; x<1000; x++) //Loop the forward stepping enough times for motion to be visible
digitalWrite(stp,HIGH); //Trigger one step forward
delay(1);
digitalWrite(stp,LOW); //Pull step pin low so it can be triggered again
delay(1);
Serial.println("Enter new option");
Serial.println();
//Reverse default microstep mode function
void ReverseStepDefault()
Serial.println("Moving in reverse at default step mode.");
digitalWrite(dir, HIGH); //Pull direction pin high to move in "reverse"
for(x= 1; x<1000; x++) //Loop the stepping enough times for motion to be visible
delay(1);
delay(1);
Serial.println();
// 1/8th microstep foward mode function
void SmallStepMode()
Serial.println("Stepping at 1/8th microstep mode.");
digitalWrite(MS1, HIGH); //Pull MS1, and MS2 high to set logic to 1/8th microstep resolution
digitalWrite(MS2, HIGH);
for(x= 1; x<5000; x++) //Loop the forward stepping enough times for motion to be visible
delay(1);
delay(1);
Serial.println();
//Forward/reverse stepping function
void ForwardBackwardStep()
Serial.println("Alternate between stepping forward and reverse.");
for(x= 1; x<5; x++) //Loop the forward stepping enough times for motion to be visible
//Read direction pin state and change it
state=digitalRead(dir);
if(state == HIGH)
else if(state ==LOW)
digitalWrite(dir,HIGH);
for(y=1; y<1000; y++)
delay(1);
delay(1);
Serial.println("Enter new option:");
Serial.println();
Problem is:
My local control for forward and backward movements doesn't work.
Now, If I disable:
My local controls are working but serial controls are affected since I disabled the stepping function.
I believe AccelStepper.h has some compatibility issues with MS1 and MS2.
I will be thankful if you guys can help me sort out this problem.
Thanks.
Z
Working code for local control:
//Variables
int flag=0;
#define stp 2
#define dir 3
#define MS1 4
#define MS2 5
#define LEFT_PIN 9
#define STOP_PIN 11
#define EN 6
#define SPEED_PIN 0
/* pinMode(stp, OUTPUT);
pinMode(MS2, OUTPUT);*/
if ( flag == 0){
delay(200);
sign = 1;
sign = -1;
sign = 0;
else {
if (RESET == LOW)
resetFunc();
Working code for serial control:
SparkFun Easy Driver Basic Demo
Toni Klopfenstein @ SparkFun Electronics
March 2015
https://github.com/sparkfun/Easy_Driver
Simple demo sketch to demonstrate how 5 digital pins can drive a bipolar stepper motor,
using the Easy Driver (https://learn.sparkfun.com/tutorials/easy-driver-hook-up-guide?_ga=2.5974067.106990392.1515514487-1212774323.1509654567). Also shows the ability to change
microstep size, and direction of motor movement.
Development environment specifics:
Written in Arduino 1.6.0
This code is beerware; if you see me (or any other SparkFun employee) at the local, and you've found our code helpful, please buy us a round!
Distributed as-is; no warranty is given.
Example based off of demos by Brian Schmalz (designer of the Easy Driver).
//Declare pin functions on Redboard
#define stp 2
#define dir 3
#define MS1 4
#define MS2 5
#define EN 6
//Declare variables for functions
char user_input;
int x;
int y;
int state;
Serial.println();
Serial.println();
//Main loop
SmallStepMode();
resetEDPins();
void resetEDPins()
delay(1);
delay(1);
Serial.println();
delay(1);
delay(1);
Serial.println();
delay(1);
delay(1);
Serial.println();
if(state == HIGH)
delay(1);
delay(1);
Serial.println();
When I look at the two working programs I don't see any common style between them. The "serial" program has several functions whereas the "local" program uses loop() for everything.
I think it will be easier to extend the "serial" program to respond to your buttons rather than trying to merge what you have.
But before doing that you need to change the way you are reading the serial data because your use of WHILE block everything until it completes.
You need to have a variable (or maybe a few) that holds the state for the motor movements. That variable can then be updated either from a button press or as a result of data received via serial. Doing it that way means that the motor movements neither know nor care where the command comes from.
Have a look at the examples in Serial Input Basics (http://forum.arduino.cc/index.php?topic=396450.0) - simple reliable ways to receive data. See how the examples collect the data, save it and let the Arduino get on with other things.
...R
Planning and Implementing a Program (http://forum.arduino.cc/index.php?topic=261445.0)
Hi Robin,
Thanks again.
I somewhat solved the problem using this logic:
/* pinMode(MS1, OUTPUT);
if(Serial.available()){
***Serial Control code***
else {
***Local Control code***
I did some basic tests and the code is working..
I will be thankful if you could post a snippet for:
Thanks,
Z
See the links in Reply #2. I had assumed you would study them carefully before replying.
...R
...R
Hi Robin,
Sorry for late reply.
I was sick till now..
I went through your examples (really great!). I also needed to use the idea of parsing.
For example, I wanted to input "number of steps".
I used Serial.parseInt() function instead.
if (Serial.find("s")) {
StepNumber = Serial.parseInt();
Serial.print("Step number: " );
Serial.print(StepNumber);
// for example: "s5000\n":
Only problem is, this Serial.find block is making the code (motor) run slower by almost 1 sec.
Upon then I tired to combine your example 5 with the this code.
// Example 5 - Receive with start- and end-markers combined with parsing
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
int StepNumber = 0;
// variables to hold the parsed data
char messageFromPC[numChars] = {0};
int integerFromPC = 0;
float floatFromPC = 0.0;
boolean newData = false;
#define stp 2
#define dir 3
#define MS1 4
#define MS2 5
#define EN 6
char user_input;
int x;
int y;
int state;
Serial.println("Enter data in this style <STEP, 1000> ");
Serial.println();
Serial.println();
Serial.println();
recvWithStartEndMarkers();
if (newData == true) {
strcpy(tempChars, receivedChars);
// this temporary copy is necessary to protect the original data
// because strtok() used in parseData() replaces the commas with \0
parseData();
showParsedData();
newData = false;
SmallStepMode();
resetEDPins();
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void parseData() { // split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars,","); // get the first part - the string
strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
int result = strcmp(messageFromPC, "STEP");
if (result == 0){
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
integerFromPC = atoi(strtokIndx); // convert this part to an integer
StepNumber = integerFromPC;
else{
integerFromPC = 0;
void showParsedData() {
Serial.print("Message ");
Serial.println(messageFromPC);
Serial.print("Integer ");
Serial.println(integerFromPC);
void resetEDPins()
for(x= 1; x<StepNumber; x++) //Loop the forward stepping enough times for motion to be visible
delay(1);
delay(1);
Serial.println();
for(x= 1; x<StepNumber; x++) //Loop the stepping enough times for motion to be visible
delay(1);
delay(1);
Serial.println();
delay(1);
delay(1);
Serial.println();
if(state == HIGH)
delay(1);
delay(1);
Serial.println();
Here parseData() function is modified to work in a way that it will set the integer value to StepNumber only if string entered was STEP.
But the code doesn't function properly.
I would be thankful if you could look into this.
Thanks.
Z
From Reply #5 ...
It would make a lot more sense to parse all the data before analysing whether the data is useful
But I suspect that has little to do with the problem.
What is the purpose of this
user_input = Serial.read();.
when you should be using recvWithStartEndMarkers() for all the input.
...R
Thanks Robin,
It's ok now..
I guess it is fulfilling the purpose well.
Thanks again for your help :)
