Arduino Forum
Using Arduino => LEDs and Multiplexing => Topic started by: gourish on Feb 12, 2018, 01:39 pm
Title: 16*128 dot matrix display connection
Post by: gourish on Feb 12, 2018, 01:39 pm
hi
i tried a code of 16*32 dot matrix on 16* 128 dot matrix display.
#include "myMATRIX.h"
#define RowA_Pin 2
#define RowB_Pin 3
#define RowC_Pin 4
#define RowD_Pin 5
#define OE_Pin 6
#define Red_Pin 7
#define Green_Pin 8
#define CLK_Pin 9
#define STB_Pin 10
void setup ()
     myMatrix.Init(Red_Pin,Green_Pin,CLK_Pin,RowA_Pin,RowB_Pin,RowC_Pin,RowD_Pin,OE_Pin,STB_Pin);
 myMatrix.clearScreen();
 myMatrix.printString(5,8,yellow,black,"Demo");
it gives me output on the display but it is repeating the displayed text after some pixel again.
is there any other pin configuration and library for 16*128 dot matrix display?
thank you
Title: Re: 16*128 dot matrix display connection
Post by: Jakub12 on Feb 12, 2018, 01:44 pm
Use md Parola and md_max  library. Over there you can decide how many modules are in your display like :
#define MAX_DEVICES 12
Post by: Jakub12 on Feb 12, 2018, 02:02 pm
You can find this libraries here:
(http://i68.tinypic.com/16bkaaf.jpg)
And later you can find some examples , in your case that will be zones , because you want to display something in certain space of display:
(http://i64.tinypic.com/eb6hj8.jpg)
Good luck !
Post by: marco_c on Feb 12, 2018, 09:41 pm
Is your matrix controlled by the MAX7219 IC? You provide no details of the type of matrix you are using.
With the 7219IC this means that there are more matrices than the software thinks there are. When you update the display, the serial data communications pushed the 'current' data off the end of the 'known' modules into the others, which will show the old display as was previously on the 'known' modules before they were updated.
You need to find somewhere in the library that has the number of modules and change that to be those for your matrix.
If they are not controlled by the MAX7219, then this explanation may not be correct for your matrix.
Post by: gourish on Feb 13, 2018, 05:25 am
Thank you..
40-inch 101cm ios And Android Wifi wireless remote Programmable Advertising LED Display Board, Bright Red led sign for Busines
i dont know whether it uses max7219 ic..
Post by: gourish on Feb 13, 2018, 06:07 am
in this library there is nothing mentioned about the connection for r1,g1 and r2,g2
