Arduino Forum
Topics => Interactive Art => Topic started by: LimuloLab on Mar 03, 2011, 09:50 pm
Title: Ultrasonic sensor SRF04 - Arduino uno
Post by: LimuloLab on Mar 03, 2011, 09:50 pm
Hello everyone,
Here I expose my own concerns: I'm working on an interactive installatio and I find myself having to interface an ultrasonic sensor, SRF04 Daventech model with Arduino One.
From the technical manual that I downloaded from http://www.robot-electronics.co.uk/htm/srf04tech.htm seems that this sensor has an average current consumption that is around 30mA. I know that Arduino can provide a maximum current equal to 20mA.
My fear is that, by linking the two systems, they can be damaged.
Am I worrying for nothing? if not, how can I do to connect the two systems without risk of damage?
Thank you in advance
bye
nicola
Title: Re: Ultrasonic sensor SRF04 - Arduino uno
Post by: retrolefty on Mar 03, 2011, 10:43 pm
I think you are confusing arduino digital output pin current limits (40ma max, 20-30 recommended) with the power supply current required for this sensor. As the sensor's Vcc (to power the sensor) would wire to the Arduino's +5vdc power pin, it would have no problem suppling the current required for this sensor.
Lefty
Post by: LimuloLab on Mar 03, 2011, 11:11 pm
thank you very much of your teaching retrolefty.
so I should just connect the things as follows:
1) sensor grount ---> Arduino ground;
2) Trigger Pulse Input <---- Arduino digital output;
3) Echo Pulse Output ------> Arduino input;
4) sensor supply 5V <----- Arduino 5v pin.
is it correct?
nicola
Post by: retrolefty on Mar 04, 2011, 02:29 am
is it correct?
nicola
Correct
