Arduino Forum
Using Arduino => General Electronics => Topic started by: srnet on May 08, 2018, 11:59 pm
Title: Very low quiescent current regulator for ESP32 board
Post by: srnet on May 08, 2018, 11:59 pm
I have a ESP32 board running nicley with a deep sleep current of 8uA.
That is with a LoRa device, 2kbyte FRAM, TC74 temperature sensor and a 0.96" OLED display.
The regulator is a HTC7333 (IQ 4uA typical), which is capable of 250mA and is fine until you use the WiFi. The large startup current pulse of the WiFi (250mA+) causes a brown out, so the ESP32 really deserves a regulator capable of 500mA or more, even when there is a 1000uF capacitor across the ESP32 supply rails.
I have spent a while searching the Farnell\Element Web site, and whilst there are 3.3V regulators out there with a circa 250mV drop out the smallest IQ I have found is 35uA for a XC6210. Intended power supply is 4 x AA Alkalkine batteries. I dont want to use a regulator with a shutdown pin.
So does anyone know of an 3.3V LDO regulator, 500mA+, with a quiescent current of less than 35uA ?
Title: Re: Very low quiescent current regulator for ESP32 board
Post by: ted on May 09, 2018, 01:31 am
Reduce startup current by resistor, what is the normal current after startup ?
Post by: ted on May 09, 2018, 01:36 am
Show that capacitor on the drawing with  WiFi connection
Post by: srnet on May 09, 2018, 07:25 am
A resistor could reduce the startup current but would also reduce the supply voltage, which in turn would make the brownout problem worse.
A 500mA capable LDO (MCP1825) and large capacitor across the ESP32 supply rails, does cure the problem, but that regulator has an IQ of 120uA.
So I would like to find a similar regulator with a much lower IQ.
Post by: larsgregersen on May 09, 2018, 09:20 am
How about using two regulators? One for the ESP32 and one for the wifi circuit?
You could even use the ESP32 to control the shutdown pin of the regulator that is supplying the wifi?
Post by: srnet on May 09, 2018, 09:27 am
The ESP32 has the WiFi built in, you cannot power the WiFi seperatly.
Post by: larsgregersen on May 09, 2018, 09:55 am
The ESP32 has the WiFi built in, you cannot power the WiFi separately.
Sorry, I thought that there was a way to inject power in to the wifi directly.
I haven't used this device, but a LP5912 from TI might work (500 mA, QI is 30 uA).
Alternatively, you can use a boost converter?
Post by: srnet on May 09, 2018, 10:36 am
Thats a possibility, I originally did not consider the very small SMT components, but it might be feasible to hand assemble that device and arrange a pad underneath for heat dissipation.
To be avoided really and not sure how many switchers have an ultra low Iq. In addition one of the main functions of the board will be as a LoRa transceiver device. LoRa operates at up to 20dB below noise and some switchers can significantly affect the very weak signals.
Post by: Wawa on May 09, 2018, 01:01 pm
Did you try more than 1000uF on the power rail, and were they low-ESR tantalum.
Leo..
Post by: srnet on May 09, 2018, 01:21 pm
Leo..
No, but I did try a 470uF low ESR electrolytic, that did not cure the problem with the 250mA regulator, although with the the 500mA was OK.
I dont have a 1000uF + tant, and they are non-cheap.
Post by: ted on May 09, 2018, 01:39 pm
The resistor you need is 10 -20 ohm, calculate voltage drop.
Without schematic -  it look like you discharging 1000uF capacitor by voltage regulator that why you burned it, increasing value of capacitor make situation worse.
Maybe this will work.
http://www.analog.com/media/en/technical-documentation/data-sheets/1086ffs.pdf (http://www.analog.com/media/en/technical-documentation/data-sheets/1086ffs.pdf)
google - voltage regulator low Quiescient Current
Post by: PieterP on May 09, 2018, 05:50 pm
You need smaller capacitors in parallel with your electrolytic caps. Even low-ESR electrolytics are too slow to be used without tantalum or ceramic caps.
I'm sorry, but that's just bull.
Adding a resistor in series will just make the brownout worse.
Pieter
Post by: ted on May 09, 2018, 05:56 pm
double bull - limiting the current will protect .....
Post by: PieterP on May 09, 2018, 06:34 pm
Modern regulators don't get damaged by short current surges. They have short circuit protection and thermal shutdown. The OP didn't say that he blew up the regular. The problem here is the brownout.
Post by: srnet on May 09, 2018, 06:49 pm
They are there already, 100nF and 4u7 ceramics.
This particular brownout issue with the ESP32 is well known and cured by using an appropriate regulator and large capacitor, in addition to the normal precautions.
I have since found that Infeon do a couple of SOIC8 500mA regulators, they have an Iq of 30uA.
Post by: ted on May 09, 2018, 08:48 pm
OK put resistor there
Post by: cybergogo on Oct 05, 2018, 04:11 pm
Hi all,
I'm working on a project involving ESP8266s and ESP32s, those modules have either AMS1117 or XC6204 as voltage regulators, which both have their flaws.
I found that bad boy on mouser:
https://www.mouser.fr/ProductDetail/Diodes-Incorporated/AP2114H-33TRG1?qs=%2fha2pyFadugWS8g%2fH4pkMFNdHEG%2fY1v6HBXdJPKa9HkPJYgXp9KYwA%3d%3d
Quiescent  is at 65uA, output is 1A, vdrop is 0.45v.
Do you think it would be a good candidate to replace an AMS1117 (which has high quiescent) or A xc6204 (which is low output current) ?
Post by: skeezoo on Jun 05, 2019, 11:22 am
Hello,
probably a little late but just in case someone came across this topic
the HT7833 is a 500ma 4uA Iq
