I plugged in my Arduino into a sub port and is recognized into port /dev/ttyACM0 on my Ubuntu 16.04 LTS GNU/Linux running computer, as seen in dmesg:
[ 3269.509330] cdc_acm 1-6:1.0: ttyACM0: USB ACM device
[ 3312.346228] usb 1-6: USB disconnect, device number 6
[ 3329.402161] usb 1-6: new full-speed USB device number 7 using xhci_hcd
[ 3329.532105] usb 1-6: New USB device found, idVendor=2341, idProduct=0001
[ 3329.532114] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[ 3329.532120] usb 1-6: Product: Arduino Uno
[ 3329.532126] usb 1-6: Manufacturer: Arduino (www.arduino.cc)
[ 3329.532131] usb 1-6: SerialNumber: 6493234363835111B171
[ 3329.532394] usb 1-6: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 3329.533486] cdc_acm 1-6:1.0: ttyACM0: USB ACM device
So I try to open the serial console over my arduino and I get the following error:
Error opening serial port '/dev/ttyACM0'. Try consulting the documentation at http://playground.arduino.cc/Linux/All#Permission
Further investigation shows that /dev/ttyACM0 is in group tty instead of dialout as ls -l /dev/ttyACM0 command shows:
ls -l /dev/ttyACM0
crw--w---- 1 root tty 166, 0 Μάι 10 16:06 /dev/ttyACM0
Also my user is in dialout group as well as groups command shows:
pcmagas adm tty uucp dialout cdrom sudo dip plugdev lpadmin sambashare docker lxd wireshark
Do you know how I will set back the /dev/ttyACM0 into dialout group or make arduino recognized into a different port eg. /dev/arduino0 instead of /dev/ttyACM0 ?
Your user is in the dialout and tty groups so it should not matter which. You may have a udev rule which is messing around with permissions and group ownership.
The problem I see here is group read access has been removed.
This is how the Arduino appears on my system.
crw-rw---- 1 root dialout 166, 0 xxxxxxxxxxxx /dev/ttyACM0
The following article covers "cannot open port" problems and how to fix them.
https://hackingmajenkoblog.wordpress.com/2016/08/24/diagnosing-arduino-problems-in-linux/
Same here with Linux Mint 18.
In the end some stray service enabled the ttyACMx devices to be as write only with grout tty. By disabling them fixed the issue. On Ubuntu 16.04 I dit it via theese commands:
$ sudo systemctl stop serial-getty@ttyACM0
$ sudo systemctl disable serial-getty@ttyACM0
